itaps-parallel Hello hands on
Devine, Karen D
kddevin at sandia.gov
Fri Nov 7 15:23:59 CST 2008
Lori:
Thanks for the suggestions. I made separate loops for exercises two and
three so that the loop structure would be clearer. And I instructed
students to use iBase_ALL_TYPES in exercise 2; I had used it in the solution
as well.
My Hello/DOCUMENTS directory contains links to RPI's iMesh.h, iMeshP.h and
iBase.h files, as those are the ones used in building the examples and the
FMDB implementation.
Karen
On 11/6/08 12:30 PM, "Lori A. Diachin" <diachin2 at llnl.gov> wrote:
> Hi Karen and All,
> Opinion question - do you think folks will find it difficult to
> understand the first couple of exercises in Hello given that they
> haven't seen the detailed slides on the parallel interface yet? What do
> you think of doing a similar, but simpler MyFirst_iMesh.cpp as their
> first morning exercise, and then moving them to this one?
> Exercise 2 - do you want to tell them what entity type to use? I
> used iBase_ALL_TYPES
> I missed the loop on partsSize in exercise 2 and inserted it myself.
> It may be best to
> to insert it after the EXERCISE 2 label as that's where I started
> reading, even though
> it's relevant to both exercise 2 and 3
> Other than that I think it went well - very nicely documented and clear
> instructions.
> Lori
More information about the itaps-parallel
