itaps-parallel tutorial comments
Vitus Leung vjleung at sandia.gov
Wed Nov 5 18:25:12 CST 2008
I have separated the tutorial from iZoltan.  The tutorial can now be
found in Load_Balance.
Vitus
On Wed, 2008-11-05 at 15:11 -0700, isenburg1 at llnl.gov wrote:
> hello vitus,
> i just tried out your tutorial. works great .. i had just a few
> hickups (see below)! i think your "Zoltan" would be a good fit after
> "Hello" and before "Smooth". Maybe you could create a single directory
> for the two exercises similar to the structure of "Hello" and "Smooth" ?
> below are my comments for the two tutorials
> cheers
> martin
> comments for tutorial1
> - in EXERCISE 3 it took me  while to figure out to use argv[2]
> - when i type 'make' it wrongly tells me
>     "To build the iMeshPZoltan C++ test program, type
>        gmake ZOLTAN_ARCH=desired_arch fmdbzoltan"
> - you should add the following variables to EXCERCISE 4 unless you
> left them out on purpose
>    int parts_size, parts_allocated = 0;
> - in the Hands_on file it should say to run. not the added './'
>    mpirun -np 4 ./fmdbzoltan 4 part.sms REGION tmp
> comments for tutorial2
> - change comment "delete the partition" to "destroy the partition"
> - change comment "delete the part" to "destroy the part"
> - if the user does not use "VTK" as option in iMeshP_saveAll and then runs
>     mpirun -np 4 ./fmdbzoltan 4 part.sms REGION repart
> the code crashes. instead the user should call
>    mpirun -np 4 ./fmdbzoltan 4 part.sms REGION repart.sms
> which will work either way.
More information about the itaps-parallel mailing list
