itaps-parallel FMDB libraries are updated on mesh machine
Lori A. Diachin
diachin2 at llnl.gov
Wed Nov 5 12:48:58 CST 2008
I think I came across this as well - Vitus, what did you do to get it
compile?
Lori
Vitus Leung wrote:
> Ting,
> I think I may have come across that already. I did manage to eventually
> compile.
> Vitus
> On Wed, 2008-11-05 at 10:58 -0700, txie at scorec.rpi.edu wrote:
>> Hi all,
>> I just worked with Alex on the mesh adaptivity example, and found the
>> latest FMDB_iMeshP version may (or may not) cause name mangling errors
>> during compiling. I will check this problem, and let you know once I
>> finish.
>> Thanks for your patience.
>> Ting
>>> Hi all,
>>> I'll copy everything over to the other machine sometime tomorrow
>>> before noon. I've already copied most things once (yesterday). I'm
>>> only copying what's under /usr/local/itaps; if you want something else
>>> copied too, let me know.
>>> - tim
>>>> Hi all,
>>>> I just updated FMDB libraries on mesh machine (Tim's machine) based on
>>>> the
>>>> latest iMeshP.h version. The main modifications are name changes on some
>>>> iMeshP functions. The paths to the libraries are:
>>>> /usr/local/itaps/FMDB_iMeshP/ (iMeshP enabled, for parallel)
>>>> /usr/local/itaps/FMDB_iMesh/ (iMesh enabled, for serial)
>>>> Please see the following changes from Karen's last email, and make sure
>>>> that your program still works if it uses FMDB_iMeshP. Also let me know
>>>> if you find any problems. Thanks.
>>>> Ting
>>>>> Changes:
>>>>> - Reformatted many, many, many comments for Doxygen. (Anyone feel
>>>>> like
>>>>> proofreading??)
>>>>> - Changed function names for consistency with our conventions:
>>>>> iMeshP_Wait -> iMeshP_waitForRequest
>>>>> iMeshP_WaitAll -> iMeshP_waitForAllRequests
>>>>> iMeshP_WaitAny -> iMeshP_waitForAnyRequest
>>>>> iMeshP_WaitEnt -> iMeshP_waitForRequestEnt
>>>>> iMeshP_Test -> iMeshP_testRequest
>>>>> iMeshP_load -> iMeshP_loadAll
>>>>> iMeshP_save -> iMeshP_saveAll
>>>>> iMeshP_createGhostEnts -> iMeshP_createGhostEntsAll
>>>>> iMeshP_deleteGhostEnts -> iMeshP_deleteGhostEntsAll
>>>>> - Removed iMeshP_Status from the interface; it was defined only as a
>>>>> handle, and we didn't give the apps a way to access any of its data.
>>>>> - Removed some "const" keywords where I thought they didn't make
>>>>> sense.
>>>>> - Removed redundant argument num_ghost_rules from
>>>>> iMeshP_getGhostEntInfo.
>>>>> - In iMeshP_pushTags and its siblings, change the tag argument to a
>>>>> source-tag argument; added a destination tag argument.
>>>>> Out-standing questions and things to do:
>>>>> - In iMeshP_exchEntArrToPartsAll, what are implementations using for
>>>>> the
>>>>> command_code? Should I make this an enumerated type? Or just
>>>>> "yes/no"
>>>>> for
>>>>> migration? (Yes == migrate entity, no == create only a copy).
>>>>> - In iMeshP_exchEntArrToPartsAll, how are implementations interpreting
>>>>> the
>>>>> update_ghost argument?
>>>>> - In iMeshP_exchEntArrToPartsAll, what adjacencies are being migrated
>>>>> with
>>>>> the entities in the arguments? Downward adjacencies only? Is the
>>>>> ownership
>>>>> of the downward adjacencies automatically changed to something that
>>>>> "makes
>>>>> sense"? (I think Ting raised this issue before but I don't recall that
>>>>> we
>>>>> resolved her questions.)
>>>>> - How is the offset array in iMeshP_replaceOnPartBdry used? I guessed
>>>>> the
>>>>> following; Onkar, let me know if it is correct. If it is correct, do
>>>>> we
>>>>> need offset_size?
>>>>> offset (In) Index into new_entities; old_entities[i]
>>>>> is replaced by new_entities[offset[i]] to
>>>>> new_entities[offset[i+1]-1].
>>>>> - Resolve Jason's recent questions about creating ghost entities.
>>>>> - Add functions to either pull or accumulate tag data as proposed by
>>>>> Jason.
>>>>> - Update iMeshP functions to reflect changes in iMesh, if any, to
>>>>> iMesh_getAllVtxCoords and iMesh_getVtxCoordIndex as outlined by Jason.
>>>>> Karen
>>> "You will keep in perfect peace him whose mind is
>>> steadfast, because he trusts in you." Isaiah 26:3
>>> Tim Tautges Argonne National Laboratory
>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>> phone: (608) 263-8485 1500 Engineering Dr.
>>> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
