itaps-parallel FMDB libraries are updated on mesh machine
txie at scorec.rpi.edu
Wed Nov 5 11:58:49 CST 2008
Hi all,
I just worked with Alex on the mesh adaptivity example, and found the
latest FMDB_iMeshP version may (or may not) cause name mangling errors
during compiling. I will check this problem, and let you know once I
finish.
Thanks for your patience.
Ting
> Hi all,
> I'll copy everything over to the other machine sometime tomorrow
> before noon. I've already copied most things once (yesterday). I'm
> only copying what's under /usr/local/itaps; if you want something else
> copied too, let me know.
> - tim
> txie at scorec.rpi.edu wrote:
>> Hi all,
>> I just updated FMDB libraries on mesh machine (Tim's machine) based on
>> the
>> latest iMeshP.h version. The main modifications are name changes on some
>> iMeshP functions. The paths to the libraries are:
>> /usr/local/itaps/FMDB_iMeshP/ (iMeshP enabled, for parallel)
>> /usr/local/itaps/FMDB_iMesh/ (iMesh enabled, for serial)
>> Please see the following changes from Karen's last email, and make sure
>> that your program still works if it uses FMDB_iMeshP. Also let me know
>> if you find any problems. Thanks.
>> Ting
>>> Changes:
>>> - Reformatted many, many, many comments for Doxygen. (Anyone feel
>>> like
>>> proofreading??)
>>> - Changed function names for consistency with our conventions:
>>> iMeshP_Wait -> iMeshP_waitForRequest
>>> iMeshP_WaitAll -> iMeshP_waitForAllRequests
>>> iMeshP_WaitAny -> iMeshP_waitForAnyRequest
>>> iMeshP_WaitEnt -> iMeshP_waitForRequestEnt
>>> iMeshP_Test -> iMeshP_testRequest
>>> iMeshP_load -> iMeshP_loadAll
>>> iMeshP_save -> iMeshP_saveAll
>>> iMeshP_createGhostEnts -> iMeshP_createGhostEntsAll
>>> iMeshP_deleteGhostEnts -> iMeshP_deleteGhostEntsAll
>>> - Removed iMeshP_Status from the interface; it was defined only as a
>>> handle, and we didn't give the apps a way to access any of its data.
>>> - Removed some "const" keywords where I thought they didn't make
>>> sense.
>>> - Removed redundant argument num_ghost_rules from
>>> iMeshP_getGhostEntInfo.
>>> - In iMeshP_pushTags and its siblings, change the tag argument to a
>>> source-tag argument; added a destination tag argument.
>>> Out-standing questions and things to do:
>>> - In iMeshP_exchEntArrToPartsAll, what are implementations using for
>>> the
>>> command_code? Should I make this an enumerated type? Or just
>>> "yes/no"
>>> for
>>> migration? (Yes == migrate entity, no == create only a copy).
>>> - In iMeshP_exchEntArrToPartsAll, how are implementations interpreting
>>> the
>>> update_ghost argument?
>>> - In iMeshP_exchEntArrToPartsAll, what adjacencies are being migrated
>>> with
>>> the entities in the arguments? Downward adjacencies only? Is the
>>> ownership
>>> of the downward adjacencies automatically changed to something that
>>> "makes
>>> sense"? (I think Ting raised this issue before but I don't recall that
>>> we
>>> resolved her questions.)
>>> - How is the offset array in iMeshP_replaceOnPartBdry used? I guessed
>>> the
>>> following; Onkar, let me know if it is correct. If it is correct, do
>>> we
>>> need offset_size?
>>> offset (In) Index into new_entities; old_entities[i]
>>> is replaced by new_entities[offset[i]] to
>>> new_entities[offset[i+1]-1].
>>> - Resolve Jason's recent questions about creating ghost entities.
>>> - Add functions to either pull or accumulate tag data as proposed by
>>> Jason.
>>> - Update iMeshP functions to reflect changes in iMesh, if any, to
>>> iMesh_getAllVtxCoords and iMesh_getVtxCoordIndex as outlined by Jason.
>>> Karen
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
