itaps-parallel FMDB libraries are updated on mesh machine
txie at scorec.rpi.edu txie at scorec.rpi.edu
Wed Nov 5 10:37:52 CST 2008
Hi all,
I just updated FMDB libraries on mesh machine (Tim's machine) based on the
latest iMeshP.h version. The main modifications are name changes on some
iMeshP functions. The paths to the libraries are:
/usr/local/itaps/FMDB_iMeshP/     (iMeshP enabled, for parallel)
/usr/local/itaps/FMDB_iMesh/      (iMesh enabled, for serial)
Please see the following changes from Karen's last email, and make sure
that   your program still works if it uses FMDB_iMeshP. Also let me know
if you find any problems. Thanks.
Ting
> Changes:
> -  Reformatted many, many, many comments for Doxygen.  (Anyone feel like
> proofreading??)
> -  Changed function names for consistency with our conventions:
>     iMeshP_Wait  ->  iMeshP_waitForRequest
>     iMeshP_WaitAll  ->  iMeshP_waitForAllRequests
>     iMeshP_WaitAny  ->  iMeshP_waitForAnyRequest
>     iMeshP_WaitEnt  ->  iMeshP_waitForRequestEnt
>     iMeshP_Test  ->  iMeshP_testRequest
>     iMeshP_load  -> iMeshP_loadAll
>     iMeshP_save  -> iMeshP_saveAll
>     iMeshP_createGhostEnts  -> iMeshP_createGhostEntsAll
>     iMeshP_deleteGhostEnts  ->  iMeshP_deleteGhostEntsAll
> -  Removed iMeshP_Status from the interface; it was defined only as a
> handle, and we didn't give the apps a way to access any of its data.
> -  Removed some "const" keywords where I thought they didn't make sense.
> -  Removed redundant argument num_ghost_rules from iMeshP_getGhostEntInfo.
> -  In iMeshP_pushTags and its siblings, change the tag argument to a
> source-tag argument; added a destination tag argument.
> Out-standing questions and things to do:
> - In iMeshP_exchEntArrToPartsAll, what are implementations using for the
> command_code?  Should I make this an enumerated type?   Or just "yes/no"
> for
> migration?  (Yes == migrate entity, no == create only a copy).
> - In iMeshP_exchEntArrToPartsAll, how are implementations interpreting the
> update_ghost argument?
> - In iMeshP_exchEntArrToPartsAll, what adjacencies are being migrated with
> the entities in the arguments?  Downward adjacencies only?  Is the
> ownership
> of the downward adjacencies automatically changed to something that "makes
> sense"?  (I think Ting raised this issue before but I don't recall that we
> resolved her questions.)
> -  How is the offset array in iMeshP_replaceOnPartBdry used?  I guessed
> the
> following; Onkar, let me know if it is correct.  If it is correct, do we
> need offset_size?
>       offset  (In)  Index into new_entities; old_entities[i]
>                     is replaced by new_entities[offset[i]] to
>                     new_entities[offset[i+1]-1].
> -  Resolve Jason's recent questions about creating ghost entities.
> -  Add functions to either pull or accumulate tag data as proposed by
> Jason.
> -  Update iMeshP functions to reflect changes in iMesh, if any, to
> iMesh_getAllVtxCoords and iMesh_getVtxCoordIndex as outlined by Jason.
> Karen
More information about the itaps-parallel mailing list
