itaps-parallel Mesh machine turning off this wed
Tim Tautges
tautges at mcs.anl.gov
Tue Oct 28 17:23:56 CDT 2008
So, I'm not sure who's using the mesh machine right now, but I can't
even get a login prompt. That makes it kinda tough to install paraview,
or do anything else there for that matter. Note: you shouldn't be using
this machine to test very large or memory-intensive jobs, since we
wouldn't be running those kinds of jobs for the tutorial anyway. It
also makes it difficult for others trying to test their stuff.
- tim
Devine, Karen D wrote:
> Hi, Tim. Thanks for your reply. One concern is that we do final testing of
> the examples on the machine that we will actually use in the tutorial. I
> did not realize Argonne was taking a truck to SC! Will they have the mesh
> machine set up on a network during the workweek before SC so that we can
> re-run our final tests there? We will look bad if we have to troubleshoot
> problems (paths, installations, incompatibilities, etc.) during the
> tutorial.
> Karen
> On 10/28/08 12:36 PM, "Tim Tautges" <tautges at mcs.anl.gov> wrote:
>> I'm considering having Jason make his machine available for itaps people
>> for testing/development and taking the mesh machine down to SC. Does
>> anyone (Lori?) know how many tutorial attendees we may have? Depending
>> on the number, we could fit them on a single machine.
>> The issue of damage to the machine shouldn't be significant, ANL is
>> sending a truck down, and I'm guessing there's a lot more important
>> equipment in there that they're counting on making it down there.
>> - tim
>>> Tim:
>>> Based on the responses from the people developing examples, taking the mesh
>>> machine away would be detrimental to our ability to have good examples for
>>> SC08. Ting is working hard to perfect her iMeshP implementation, as we
>>> exercise features and uncover issues. Vitus and I are updating our examples
>>> as the FMDB implementation matures. Ryan needs time to port and test his
>>> examples. We also need time for the guinea pigs to walk through the
>>> examples on the machine, to ensure that they really work and make sense.
>>> And we still need ParaView to be installed on the machine (can one of your
>>> sysadmins do that for us?).
>>> In short, we need a Plan B. Using remote log-ins from SC08 to Wisconsin is
>>> the best plan I can think of. This plan allows us to continue working on
>>> the implementations and examples, removes the risk of damage to the machine
>>> during transit, and eliminates the need for you to set up the machine on
>>> SC's network on, presumably, Saturday. It does have drawbacks, with slower
>>> connection speeds and the need for a Wisconsin person to be on call for
>>> reboots.
>>> What ideas do you have?
>>> Thanks.
>>> Karen
>>> On 10/27/08 12:15 PM, "Tim Tautges" <tautges at mcs.anl.gov> wrote:
>>>> Hi all,
>>>> I'll be turning off the mesh machine this Wed and taking it down to
>>>> ANL for shipment to SC. So, all software should be on that machine by
>>>> then. The machine has a cd drive and usb, so you can also bring it for
>>>> installation at SC, but no guarantees things will work well that way.
>>>> - tim
>>>> "You will keep in perfect peace him whose mind is
>>>> steadfast, because he trusts in you." Isaiah 26:3
>>>> Tim Tautges Argonne National Laboratory
>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>> phone: (608) 263-8485 1500 Engineering Dr.
>>>> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
