[Fwd: Re: itaps-parallel Today's phone conf]
Onkar Sahni osahni at scorec.rpi.edu
Wed Dec 19 17:48:00 CST 2007
I would like to see feasibility of option (d), which was original proposal
by Carl of overloading first arg. of iMesh instance with either part or
partition instances, note considering parts and partitions as instances
not handles (I do not know all differences between "instance" and "handle"
under ITAPS terminology except that a handle can be id- or index- based.).
If option (d) is out, then I am leaning towards (b) too.
- Onkar
> At this point, we're looking at a comparison between:
> a)  Adding args to about 10 functions, for both serial and parallel.
> Requires: universal agreement about what a null handle is, or else
> definition of an implementation-specific global variable that apps can
> use to find out what the null handle is for that impl.  Also, for every
> call, the function has to identify which args it was passed and dispatch
> accordingly (creating more functions internal to the interface,
> probably, but not user-visible).  Changes to serial code.
> b)  Leaving those 10 functions alone in serial, and adding parallel
> versions.  Requires: adding probably one function for each of the
> originals in the parallel interface.  My guess from the current document
> on parallel is that we'll be looking at >100 functions already, so this
> may or may not be considered significant. Serial code left untouched.
> c)  Adding some magic to squish three args into one in parallel.
> Requires: A function to squish (and unsquish, internally) the args;
> therefore, extra effort for the app and impl for each of those 10
> functions every time they're called (even in serial, probably).
> Depending on how the squishing is done, risk of handle collision.
> Personally, I think I'd lean towards b, given these three alternatives,
> provided of course that my count of the number of functions involved
> holds up.
> Carl
> Dr. Carl Ollivier-Gooch, P.Eng.                   Voice: +1-604-822-1854
> Associate Professor                                 Fax: +1-604-822-2403
> Department of Mechanical Engineering             email: cfog at mech.ubc.ca
> University of British Columbia              http://www.mech.ubc.ca/~cfog
> Vancouver, BC  V6T 1Z4                  http://tetra.mech.ubc.ca/ANSLab/
More information about the itaps-parallel mailing list
