itaps-parallel Diagram of set-based parallel data
Onkar Sahni
osahni at scorec.rpi.edu
Wed Dec 19 12:55:01 CST 2007
Why do we have to expose that to interface. Actually reading that "even if
they weren't represented that way underneath" makes me wonder more why we
need exposure (say, of "sets") at interface level.
It (interface) actually becomes a burden (and confusion) for users in
using it (think in terms of convenience) and also learning about it. To be
honest and neutral user, to some extent I already feel iMesh interface is
burdensome.
Moreover, (I have said this before) in future if another implementation
wants to be ITAPS compliant (through interface) then it basically has to
follow this legacy.
- Onkar
> This is a description of how parts and partitions could be represented
> using sets. They could also be presented that way through the
> interface, even if they weren't represented that way underneath (see my
> next reply, to Mark's message).
> Inter-part boundaries weren't mentioned to keep the figure simple. I
> would put them in as child sets of the Part or other inter-part boundary
> sets, containing a subset of the 2d or 1d entities.
> - tim
> Onkar Sahni wrote:
>> Is this description of MOAB's implementation details for ITAPS parallel
>> requirements and functionality? OR is this something all implementations
>> under ITAPS will be required?
>> Btw, just curios under "all sets" in cartoon there was no mention of
>> inter-part boundaries?
>> - Onkar
>>> Hi all,
>>> As promised, attached is a cartoon describing set-based parallel
>>> data. Note I've stuck to the simplest example (as wisely advocated by
>>> Mark S). I show the representation of the same mesh in the serial and
>>> 3-processor cases. I don't show ghosted elements, for simplicity,
>>> though those "fit" in the model.
>>> PARALLEL
>>> In the parallel representation, each processor has a set it understands
>>> as "partition1" (labeled "Partn1"). In this example, on each
>>> processor,
>>> that set contains one set corresponding to the part assigned to that
>>> processor. The part set contains 3d entities assigned to that
>>> processor. In this example, all 3d entities are objects in the
>>> decomposition, therefore each 3d entity is a member of exactly one
>>> Part.
>>> There are other entity sets defined in this mesh, including a boundary
>>> condition set (BC1), material sets (Matl1, Matl2), and
>>> application-defined sets (App1-App3). In this example, the BC1 set
>>> contains faces in the mesh (2d elements), but not all of them. Matl1
>>> and Matl2 are meant to form a covering over 3d elements, defining the
>>> materials for those elements. Application-defined sets are for
>>> arbitrary groupings. Whether such "shared" sets would exist on
>>> processors even if there were no set contents on those processors is
>>> currently implementation-defined, though maybe there should be a common
>>> convention for that.
>>> Some of the sets on each processor are implicitly linked with sets on
>>> other processors. For example, the Partn1 set on each processor is
>>> linked to the corresponding sets on other procs. For this set, that
>>> means that if the mesh were ever to be assembled in a single file, the
>>> contents of Partn1 on various processors would all go into a single
>>> set,
>>> which would be assigned the union of all tags on that set on all
>>> processors. Presumably those tags would all be the same. Similarly,
>>> BC1 and Matl1, Matl2 are sets that are implicitly linked and which
>>> would
>>> be combined. App1-App3 are application-defined sets which would be
>>> considered separate, even if the mesh was written to a single file.
>>> Note that the decision or designation of which sets across the
>>> processors are really the same sets is application- or
>>> implementation-defined. In MOAB, we do it based on tag and optionally
>>> tag value. So, for example, any set with a "MATERIAL_SET" tag whose
>>> value is the same is understood to be the same set. This is used in
>>> the
>>> HDF5-based file writer in MOAB, which writes a single file in parallel
>>> from all processors.
>>> SERIAL
>>> In the serial case, all sets having implicitly-defined counterparts on
>>> other processors have been combined. Thus, part sets (Part1-Part3) are
>>> contained in the Partn1 set, and there are single BC1, Matl1 and Matl2
>>> sets. App1-App3 are still separate, since they were not designated to
>>> be the same sets. The Part1-Part3 sets and Matl1-Matl2 sets are
>>> different coverings of all 3d entities in this mesh for this example.
>>> The BC1 set includes a subset of 2d entities in the mesh.
>>> DISCUSSION
>>> As I've mentioned before, I've implemented MOAB's parallel reader such
>>> that any collection of sets which forms a covering over the things I
>>> want to partition can be used to define the partition. Thus, in this
>>> example, one could use Matl1/Matl2 as the part sets. In this case,
>>> those sets would serve multiple purposes. Similarly, I don't see any
>>> reason we shouldn't allow a given part set to be a member of multiple
>>> partitions.
>>> Part sets should also be allowed to include sets; in this case, maybe
>>> the sets are the objects in the partition. This would be a very nice
>>> thing to use for e.g. hypergraph partitioning methods.
>>> Counter-intuitively, I would lean toward using contains relations to go
>>> down that hypergraph hierarchy. If a given implementation did not
>>> implement Parts as legitimate entity sets, then this property could be
>>> used to reduce bookkeeping for adaptive applications, e.g. have the
>>> part
>>> contain sets which themselves contain 3d elements of a given material
>>> or
>>> geometric volume. Of course, that assumes you're using sets for those
>>> other things...
>>> This method for representing partitions also has the following
>>> benefits:
>>> - allows multiple partitions to exist in the same
>>> file/instance/database
>>> - would allow current set operations to be used to query contents of
>>> - parallel view is only different when asking about parallel data; in
>>> other cases it looks the same as serial interface
>>> - other parts of RPI partition model can be embedded similarly, by
>>> using
>>> sets related to part sets using parent/child relations
>>> I'll be elaborating on this at the SIAM mtg in March, as well as
>>> pulling
>>> in other examples where sets can be used to do various things. I guess
>>> that means I've already started my talk, which has to be some sort of
>>> record for me!
>>> Comments welcome, fire when ready!
>>> - tim
>>> "You will keep in perfect peace him whose mind is
>>> steadfast, because he trusts in you." Isaiah 26:3
>>> Tim Tautges Argonne National Laboratory
>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>> phone: (608) 263-8485 1500 Engineering Dr.
>>> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
