itaps-parallel Proposal for handling queries with parts, sets, and partitions
Tim Tautges tautges at mcs.anl.gov
Tue Dec 18 10:39:58 CST 2007
As usual, I picked the wrong telecon to miss.  There should be some rule
about not allowing major interface change proposals coming out on
Thursday after COB (in the midwest) and essentially ratifying those
changes Monday morning.  But anyway...
Carl Ollivier-Gooch wrote:
> Hello, all.
> During our last telecon, I had what I thought was an idea that would
> unify the parallel query for sets stuff.  At the time, the idea was
> vaguely formed, and I hadn't thought through all of the consequences.  I
> may still not have, but I've at least got it to the point of being ready
> to drag it out into the light of day.
> Essentially, the issue is that we want to have much the same set of
> queries for mesh instances, parts, and partitions, but we haven't worked
> out how to handle this without exploding the number of functions.
> In the serial interface, we have lots of queries that take both a mesh
> instance and an entity set argument.  In the now more-or-less deprecated
> SIDL paradigm, the mesh instance in an object (in the C++ sense), and we
> unified global and entity set calls by creating a root set that is,
> essentially, shorthand for "everything in the mesh instance".
I think the above is a very useful thing to keep in mind.  The two
things that change when you go from there to parallel is that a) mesh
instances together form a collection that in some way describes a global
mesh, and b) some sets can be thought of as spanning processors, but
only implicitly (that is, we don't assume the handles are the same).
> In parallel, the mesh instance resides at the process level in a
> partition / process / part heirarchy (black / red, green in the attached
> picture; yes, it's a very obvious illustration, but perhaps useful for
> reference) .  We also want to be able to query partitions and parts
> (although for partitions we only want to query for numbers of things,
> not lists of things).  Also, we'd like to able to query sets other than
> the root set (like that lovely blue set that spans a bunch of parts...).
I think it's the other way around: the part/partition resides in the
mesh instance.  In parallel, there's an implicit relation between a
partition on one processor and on another processor, such that both/all
processors understand that their local partition information is a piece
of a collection over all processors.  This model reduces to the trivial
case for a single processor, both for partition(s) in mesh instances and
parts in partitions.
> I propose that we think about both parts and mesh instances as coverings
> of the global mesh (they are), and that we also think about parts, mesh
> instances, and the partition as containing -all- data about some
> (topologically and/or geometrically compact subset) or all of the global
> mesh (as opposed to entity sets, which are deliberately more selective).
>  Yes, I know they're all collections of entities, but stick with me
> while I justify why I think this semantic distinction is worthwhile.
> Also yes, we haven't decided yet (have we?) whether a part will
> officially contain everything or just the entities that were
> partitioned; I don't -think- that any of what I'm about to propose is
> adversely affected, either way.
I don't think the partition can be a covering of the whole mesh on a
given processor.  Given a collection of 2d and 3d elements, you need to
distinguish between the 2d elements that are just adjacent to objects in
the partition and the 2d elements which are in fact objects in the
partition.
I did not see anything following which justifies the semantic
distinction you're talking about.
> Finally, it's worth noting that, while a partition contains many parts
> distributed over many processes, each process is associated with a
> unique partition (MPI communicator or equivalent) and each part is
> associated both with a unique process and a unique partition.  So
> specifying both part handle and partition handle is actually redundant.
Each part is associated with a unique partition and process, but each
process is not associated with a unique partition.  There may be
multiple partitions in use at any given time, and a given process may be
responsible for one or more parts in each partition.  Take parallel
contact detection for instance.  One partition is over volume elements,
the other is over faces on the skin of those elements.  Processors
participate in calculations for both partitions at different times.
Specifying both a part and partition handle may not be strictly
redundant, and in terms of implementation I don't think it's useful to
to require that the partition be derivable from the part handle.  I do
think that in most cases, an application will know the partition that's
being dealt with.  For the few cases where a part is a member of
multiple partitions (if we want to allow that, and I don't see a major
reason why not to), there should be a function to get the partition(s)
that a part is a member of.
> Given that backgroun, I propose that we overload our current query
> functions so that any place where a mesh instance is currently usable, a
> part handle or partition handle is also usable, and continue to use
> either a bona fide entity set or the (global placeholder) root set as
> the second argument.  In this scenario, we would have, for instance:
>             / partition handle
> getNumOfType| mesh instance    , root set handle   , type, result, err )
>             \ part handle        entity set handle
> The other iMesh function that is obviously of this type is getNumOfTopo.
> A somewhat larger collection of functions would be able to take both
> mesh instances and part handles as the first argument, but not partition
> handles: getAllVtxCoords, getVtxCoordIndex, getEntities.
> My guess is that iterator functions will fall into the second category.
> Many of the set queries (number of sets, number of children, identities
> of sets and children) are a bit more ambiguous here, to my surprise:
> essentially, if you ask for the number of sets contained in a given set
> for a particular part, you presumably mean the number of contained sets
> that intersect that part.  While I don't have a problem with that
> definition, I'm not sure it's an entirely straightforward one, either
> conceptually or in implementation.  But I haven't thought about it in a
> great deal of detail, either...  One way to finesse this would be to
> create sets at the part level rather than the mesh instance level; then
> all is easy again.
So again, I go back to asking: what are the core needs that prevent us
from using sets as both parts and partitions?  The entity set mechanism
was designed with this specific usage in mind.
I know some haven't fully implemented sets, but is that going to be more
difficult than the degree of interface changes being discussed here?
The things that are missing in sets for use as partitions and parts are
exactly the extensions we'll already need in sets for going to parallel,
no matter what we choose for partition and part representation.
Specifically, we'll need some notion of a correspondence between sets on
different processors, to handle boundary conditions on mesh spanning
processors.
I'll make a diagram equivalent to Carl's today, maybe that will make
things a bit clearer.
- tim
> Now, there are a couple of beneath-the-hood requirements for
> implementations here:
> 1.  All part handles must be unique, even in the presence of multiple
>     partitions.  Pointer-type handles will easily satisfy this;
>     integer-type handles may need to reserve some bits for partition ID
>     and some for part ID.
> 2.  In most (all?) implementations, finding the result for calls with
>     (part handle, entity set handle...) will require an implementation
>     to do some sort of intersection internally.  This will prove
>     especially challenging for iterator in the presence of mesh
>     modification and/or migration.
> I recognize also that this paradigm shift potentially ambiguates the use
> of calls like addEntToSet for adding entities to a part; we can either
> overload those functions (probably renamed to addEntToCollection) or
> create new addEntToPart functions (I think there are only going to be
> four of these: add/rmv single/array).
> Okay, so there's my proposal.  I'll now stand back and let people poke
> holes in the idea; that may not prove to be too difficult.
> Carl
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
