itaps-parallel Reminder: Phone Conference Wednesday Oct 31 at 9am PDT
Tim Tautges
tautges at mcs.anl.gov
Tue Oct 30 17:55:56 CDT 2007
Devine, Karen D. wrote:
> Reminder: We will have a subcommittee phone conference on Wednesday Oct 31
> at 9am PDT. Lori will host using the usual phone numbers.
> Here is a tentative agenda. We'll stick to big picture issues, rather than
> deal with frightening syntax or ghostly spiritual issues.
> - Having just caught up on the email discussions, I have to thank Carl for
> doing a great job of putting the discussions into a consistent framework.
> In the "no good deed goes unpunished" spirit, I'd like Carl to begin the
> discussions by summarizing his model. Then I'd like Onkar, Tim and Vitus to
> say whether or not Carl's description supports the functionality they need
> and whether their subsections of the interface (submitted for draft zero)
> are, or can be made to be, consistent with that description.
> HOMEWORK: Read Carl's latest email and be prepared to say how it fits with
> your subsection of draft zero.
Hairy, scary big-picture issue:
I'd also like a discussion of the proposal I've put forward, which I've
attached (in a format derived from Carl's writeup, hope that helps
compare). This isn't a comment that Carl's description doesn't work,
just that IMO it may not be the best way to do it.
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/itaps-parallel/attachments/20071030/a0ab7675/attachment.txt>
More information about the itaps-parallel
