itaps-parallel Re: Parallel Interface philosophical comments
Tim Tautges
tautges at mcs.anl.gov
Thu Oct 25 15:53:58 CDT 2007
Onkar Sahni wrote:
>>> There are multiple things which I want to make clear:
>>> (a) Part is not necessarily an entity-set (some implementations may
>>> choose
>>> it to be). Moreover, operations supported on entity-sets do not have to
>>> work on parts for implementations which do not consider parts as
>>> entity-sets.
>> My understanding from the last boot camp was that we did need to support
>> current iMesh entity set functions on part handles. I could see in some
>> cases a particular implementation not supporting a few functions, but on
>> the other hand, many of the iPart functions in your proposal have direct
>> analogs in the iMesh entity set functions.
> I agree that all of mesh-specific functions, like iMesh_getEntities,
> iMesh_getAllVtxCoords, iMesh_initEntIter etc., will be made
> compatible/enabled to work with part handles (that will fall under Req. 14
> of req. doc. with CVS rev. 1.14).
> For clarification, by operations on entity sets I meant set-specific
> operations/functions, like iMesh_addEntToSet, iMesh_rmvEntFromSet,
> iMesh_subtract, iMesh_intersect, iMesh_unite etc. My understanding, from
> the last boot camp, is that these functions will not be enabled to accept
> part-handles.
I'm fine with that for set booleans, but for remove/add, I'm not sure.
How will a partitioner go about building partition sets? And, if you
have things like part edges and part vertices (fig 3 in your pmodel1.3
document), why not use the set parent/child relation functions to
retrieve those relations instead of having new functions for that?
Infact, just wandering why we call, for example,
> iMesh_subtract and not iMesh_subtractSets?
That's something that's bugged me for awhile too, it's more historical
than anything.
> Please let me know the functions (in our proposal) you think have
> direct-analogs and we will try to look into them (for the ones you
> mentioned in one of your previous responses, i.e.,
> iProcParts_getPartIdArrOnProc and iProcParts iterator, I do not really see
> any direct-analogs).
>>> (b) Allowing part-handles to be used along with root-set-handle,
>>> entity-set-handle etc. is only required for existing iMesh functions
>>> (not
>>> for new ones, see next point). Infact, I see a potential problem here,
>>> consider a specific case where user wants to get entities in an specific
>>> entity-set for only a specific part; how will we support it?
>> I'm not sure I understand this statement, and the comment down by your
>> signature below. Are you saying you're ok supporting current iMesh
>> functions on part handles, but that maybe future ones might be
>> unsupported?
> I meant functions that fall under Req. 14 of req. doc. with CVS rev. 1.14
> (assuming those are mesh-specific functions) will be enabled to accept
> root-set-, entity-set- and part-handles. I am not sure what you mean by
> future ones, if you are thinking about future releases/versions of our
> code then specific functions enabled to take part-handles now will be
> supported later, say, functions iMesh_getEntities, iMesh_getAllVtxCoords,
> iMesh_initEntIter are ones (say where we agree to allow part-handles) then
> we will support them in future releases/versions of our code.
I was referring to your statement below, "For existing functions we can
support compatibility with part-handles but main concern is for new ones
(which doesn't do existing/same things).". Maybe by "new ones" you
meant the functions for this parallel interface?
>>> (c) The new interface functions, we need to define for parts (to support
>>> parallel requirements/functionalities), will take part-handles as input
>>> and not any set-handles (if some implementation wants to use entity-sets
>>> for parts they can have part-handle and entity-set-handle as one and the
>>> same).
>> I agree that it will have to be an error if an application passes in a
>> set handle representing a set and not a part to one of the functions
>> expecting a part handle. It'll have to be up to the implementation to
>> decide how to do that (using casting, looking for the tag designating
>> part-type sets, etc.)
> I guess I am not sure what you mean by set-handle not representing a part
> (or part-type sets). In our implementation there will be no set-handle
> representing a part (or part-type sets) rather there will be part-handle.
> I think there is a strong distinction between these two things, i.e.,
> set/set-handle and part/part-handle (as a part need not necessarily be a
> set in an implementation so why call part-type set or set-handle
> representing a part).
Sorry, I should have said "part handle" or "set handle" instead of
part-type set.
- tim
> - Onkar
>> - tim
>>>> iRel is for relating data between different interfaces. As I
>>>> understand
>>>> it, we are building parallel functionality as part of iMesh.
>>>> Therefore,
>>>> we shouldn't need to use iRel for this.
>>>>> There are a number of groups that use classification as the primary
>>>>> mode
>>>>> of interaction for doing things similar to how the RPI group does.
>>>>> Just
>>>>> as we would not want you to have redo all your parallel work to do
>>>>> things strictly from a classification perspective, we do not expect
>>>>> that
>>>>> the ITAPS parallel interface will require RPI to re-do all its
>>>>> parallel
>>>>> adaptive work (years worth of work dating back to the mid-90's when we
>>>>> were the first to do it) that is being used for SciDAC applications to
>>>>> fit with a specific one way of doing things.
>>>>> By the way, some feel the classification is a simple and powerful way
>>>>> to
>>>>> do things and mesh sets are actually substantial extra overhead to a
>>>>> well defined model of using classification. In my experience, I would
>>>>> love to have both classification and reverse classification at all
>>>>> times, since depending on the question being asked, one is a faster
>>>>> way
>>>>> to answer it. However, due to the extra data and headache of keeping
>>>>> things correctly set, most I know tend to focus on one and use the
>>>>> other
>>>>> temporary manner when its advantageous.
>>>> I'm not advocating that we do things only with reverse classification,
>>>> I
>>>> agree we need to be able to go both ways. I'm just arguing that if we
>>>> do pass part handles through the interface, then we operate on those
>>>> part handles using existing functions, rather than make new ones that
>>>> do
>>>> virtually the same thing.
>>> For existing functions we can support compatibility with part-handles
>>> but
>>> main concern is for new ones (which doesn't do existing/same things).
>>> - Onkar
>>>> - tim
>>>>> Mark
>>>>> Tim Tautges wrote:
>>>>>> Onkar Sahni wrote:
>>>>>>> Hi all,
>>>>>>> Here are some of my questions and comments on ITAPS parallel
>>>>>>> interface:
>>>>>>> 1) Is there a difference between "instance" and "handle" in ITAPS
>>>>>>> terminology (or are there any definition for these)? (I may have
>>>>>>> missed it
>>>>>>> if this was resolved/defined in previous ITAPS interfaces like
>>>>>>> iMesh).
>>>>>> We use the generic term "handle" as an identifier for entities,
>>>>>> entity
>>>>>> sets, the interface itself, and tags. In our C headers, these are
>>>>>> typedef'd to void*. There are also iterators, which we haven't
>>>>>> really
>>>>>> called handles, but could be referred to that way.
>>>>>>> 2) For situations where we want to support multi-parts per
>>>>>>> processor/process:
>>>>>>> (a) How do we want to distinguish between processor/process level
>>>>>>> functionalities against part level ones (keeping user- and
>>>>>>> implementation-convenience and efficiency in mind)? Ones which would
>>>>>>> fall
>>>>>>> under processor level are, like list of parts on processor, MPI_Rank
>>>>>>> etc.,
>>>>>>> whereas ones which would fall under part level are, like neighboring
>>>>>>> parts
>>>>>>> (not procs.) etc. Further, there could be ones where users wants to
>>>>>>> get/iterate mesh entities (and get adjacencies) at a processor
>>>>>>> and/or
>>>>>>> part
>>>>>>> level.
>>>>>> Processor-level queries are on the iMesh instance, part-level queries
>>>>>> are on the entity set representing the part. Our iterator functions
>>>>>> operate on both (with processor-level queries simply using the root
>>>>>> set).
>>>>>>> (b) Assuming a part-handle is supported, how can user/application
>>>>>>> get
>>>>>>> access to it (say on a processor where part resides)? Basically will
>>>>>>> there
>>>>>>> be a way to directly access the part-handle (like part iterator at
>>>>>>> iProcParts level) or user has to access it through tags/tag names,
>>>>>>> in
>>>>>>> which case user has to figure out what is the tag/tag name for a
>>>>>>> particular part (and who defines these tags/tag names).
>>>>>> I advocate having both: a conventional tag given to parts, so that
>>>>>> you
>>>>>> can find sets that are parts by looking for sets with that tag; and
>>>>>> also having a convenience function (as part of the parallel
>>>>>> extensions
>>>>>> to iMesh) which returns all the parts in the given instance (i.e. on
>>>>>> the processor). Note an important capability here for this function
>>>>>> is to pass in an optional tag name/handle indicating the partition
>>>>>> you're asking about. That allows multiple partitions to co-exist,
>>>>>> which is important for some applications.
>>>>>>> 3) How general we want to be in interface for different data
>>>>>>> models/implementations (as in future we may want to incorporate/fit
>>>>>>> other
>>>>>>> implementations), especially between serial and parallel data. Two
>>>>>>> possibilities for data models I can think of are: (a) one (serial)
>>>>>>> data
>>>>>>> model is enhanced to store parallel information and (b) serial one
>>>>>>> is
>>>>>>> supplemented by a separate parallel one to support parallel
>>>>>>> functionalities (in possibility (b) all parallel-specific
>>>>>>> information
>>>>>>> is
>>>>>>> stored in a separate data to serial-specific data). We could design
>>>>>>> interface that would fit both possibilities, this is the reason why
>>>>>>> we
>>>>>>> included iPartMesh (section 3.4) level functions which are specific
>>>>>>> to
>>>>>>> parallel functionalities in mesh (and passing handle to serial data
>>>>>>> in
>>>>>>> these interface will not work for second possibility (b)). I do not
>>>>>>> know
>>>>>>> how much relevant is this.
>>>>>> I think it's very important to put the parallel data into our
>>>>>> existing
>>>>>> data models, or extend the data model if that can't be done (which I
>>>>>> doubt, since I've already embedded this information in our current
>>>>>> data model). This is important because it allows us to use current
>>>>>> tools to examine parallel data. Note also that one may sometimes be
>>>>>> examining parallel data in a serial environment (e.g. running a
>>>>>> partitioner in serial), so we shouldn't restrict accessing parallel
>>>>>> data to a parallel environment.
>>>>>> - tim
>>>>>>> Let me know if you have questions.
>>>>>>> Vitus, due to above questions I did not respond to your comments. I
>>>>>>> do not
>>>>>>> know if above questions and comments make things clear. If you still
>>>>>>> have
>>>>>>> anything specific please let us know.
>>>>>>> Karen, Is there a way to create an email list for this subcommittee
>>>>>>> as if
>>>>>>> we want to add (and remove) people (and it will keep record of all
>>>>>>> the
>>>>>>> messages). I have added Ting in this response as she is also working
>>>>>>> on
>>>>>>> this stuff from RPI side.
>>>>>>> Thanks,
>>>>>>> Onkar
>>>>>>>> Hi all,
>>>>>>>> I'd like to re-iterate what I think should be the general
>>>>>>>> behavior of
>>>>>>>> functions in the parallel interface. IMO, we should take advantage
>>>>>>>> of
>>>>>>>> the simple yet powerful data model we already have for iMesh. That
>>>>>>>> means using mesh sets for things which are obviously sets, and
>>>>>>>> using
>>>>>>>> the
>>>>>>>> functions which already exist for accessing data in those sets. I
>>>>>>>> think
>>>>>>>> it does make sense in certain cases to make convenience functions
>>>>>>>> in
>>>>>>>> the
>>>>>>>> parallel interface for accessing e.g. all the sets which represent
>>>>>>>> parts
>>>>>>>> of a partition, on a current processor or globally, but I think we
>>>>>>>> should minimize these.
>>>>>>>> Based on the general behavior described above, I think many of
>>>>>>>> the
>>>>>>>> functions proposed for global ids and parts/partitions already
>>>>>>>> exist
>>>>>>>> in
>>>>>>>> iMesh. For example, iPart_getGlobalID, iPart_createGlobalID,
>>>>>>>> iProcParts_getPartIdArrOnProc, iProcParts iterator functions, etc.
>>>>>>>> - tim
>>>>>>>> "You will keep in perfect peace him whose mind is
>>>>>>>> steadfast, because he trusts in you." Isaiah 26:3
>>>>>>>> Tim Tautges Argonne National Laboratory
>>>>>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>>>>>> phone: (608) 263-8485 1500 Engineering Dr.
>>>>>>>> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
