itaps-parallel Re: Parallel Interface philosophical comments
Onkar Sahni
osahni at scorec.rpi.edu
Thu Oct 25 10:44:57 CDT 2007
>> There are multiple things which I want to make clear:
>> (a) Part is not necessarily an entity-set (some implementations may
>> choose
>> it to be). Moreover, operations supported on entity-sets do not have to
>> work on parts for implementations which do not consider parts as
>> entity-sets.
> My understanding from the last boot camp was that we did need to support
> current iMesh entity set functions on part handles. I could see in some
> cases a particular implementation not supporting a few functions, but on
> the other hand, many of the iPart functions in your proposal have direct
> analogs in the iMesh entity set functions.
I agree that all of mesh-specific functions, like iMesh_getEntities,
iMesh_getAllVtxCoords, iMesh_initEntIter etc., will be made
compatible/enabled to work with part handles (that will fall under Req. 14
of req. doc. with CVS rev. 1.14).
For clarification, by operations on entity sets I meant set-specific
operations/functions, like iMesh_addEntToSet, iMesh_rmvEntFromSet,
iMesh_subtract, iMesh_intersect, iMesh_unite etc. My understanding, from
the last boot camp, is that these functions will not be enabled to accept
part-handles. Infact, just wandering why we call, for example,
iMesh_subtract and not iMesh_subtractSets?
Please let me know the functions (in our proposal) you think have
direct-analogs and we will try to look into them (for the ones you
mentioned in one of your previous responses, i.e.,
iProcParts_getPartIdArrOnProc and iProcParts iterator, I do not really see
any direct-analogs).
>> (b) Allowing part-handles to be used along with root-set-handle,
>> entity-set-handle etc. is only required for existing iMesh functions
>> (not
>> for new ones, see next point). Infact, I see a potential problem here,
>> consider a specific case where user wants to get entities in an specific
>> entity-set for only a specific part; how will we support it?
> I'm not sure I understand this statement, and the comment down by your
> signature below. Are you saying you're ok supporting current iMesh
> functions on part handles, but that maybe future ones might be
> unsupported?
I meant functions that fall under Req. 14 of req. doc. with CVS rev. 1.14
(assuming those are mesh-specific functions) will be enabled to accept
root-set-, entity-set- and part-handles. I am not sure what you mean by
future ones, if you are thinking about future releases/versions of our
code then specific functions enabled to take part-handles now will be
supported later, say, functions iMesh_getEntities, iMesh_getAllVtxCoords,
iMesh_initEntIter are ones (say where we agree to allow part-handles) then
we will support them in future releases/versions of our code.
>> (c) The new interface functions, we need to define for parts (to support
>> parallel requirements/functionalities), will take part-handles as input
>> and not any set-handles (if some implementation wants to use entity-sets
>> for parts they can have part-handle and entity-set-handle as one and the
>> same).
> I agree that it will have to be an error if an application passes in a
> set handle representing a set and not a part to one of the functions
> expecting a part handle. It'll have to be up to the implementation to
> decide how to do that (using casting, looking for the tag designating
> part-type sets, etc.)
I guess I am not sure what you mean by set-handle not representing a part
(or part-type sets). In our implementation there will be no set-handle
representing a part (or part-type sets) rather there will be part-handle.
I think there is a strong distinction between these two things, i.e.,
set/set-handle and part/part-handle (as a part need not necessarily be a
set in an implementation so why call part-type set or set-handle
representing a part).
- Onkar
> - tim
>>> iRel is for relating data between different interfaces. As I
>>> understand
>>> it, we are building parallel functionality as part of iMesh.
>>> Therefore,
>>> we shouldn't need to use iRel for this.
>>>> There are a number of groups that use classification as the primary
>>>> mode
>>>> of interaction for doing things similar to how the RPI group does.
>>>> Just
>>>> as we would not want you to have redo all your parallel work to do
>>>> things strictly from a classification perspective, we do not expect
>>>> that
>>>> the ITAPS parallel interface will require RPI to re-do all its
>>>> parallel
>>>> adaptive work (years worth of work dating back to the mid-90's when we
>>>> were the first to do it) that is being used for SciDAC applications to
>>>> fit with a specific one way of doing things.
>>>> By the way, some feel the classification is a simple and powerful way
>>>> to
>>>> do things and mesh sets are actually substantial extra overhead to a
>>>> well defined model of using classification. In my experience, I would
>>>> love to have both classification and reverse classification at all
>>>> times, since depending on the question being asked, one is a faster
>>>> way
>>>> to answer it. However, due to the extra data and headache of keeping
>>>> things correctly set, most I know tend to focus on one and use the
>>>> other
>>>> temporary manner when its advantageous.
>>> I'm not advocating that we do things only with reverse classification,
>>> I
>>> agree we need to be able to go both ways. I'm just arguing that if we
>>> do pass part handles through the interface, then we operate on those
>>> part handles using existing functions, rather than make new ones that
>>> do
>>> virtually the same thing.
>> For existing functions we can support compatibility with part-handles
>> but
>> main concern is for new ones (which doesn't do existing/same things).
>> - Onkar
>>> - tim
>>>> Mark
>>>> Tim Tautges wrote:
>>>>> Onkar Sahni wrote:
>>>>>> Hi all,
>>>>>> Here are some of my questions and comments on ITAPS parallel
>>>>>> interface:
>>>>>> 1) Is there a difference between "instance" and "handle" in ITAPS
>>>>>> terminology (or are there any definition for these)? (I may have
>>>>>> missed it
>>>>>> if this was resolved/defined in previous ITAPS interfaces like
>>>>>> iMesh).
>>>>> We use the generic term "handle" as an identifier for entities,
>>>>> entity
>>>>> sets, the interface itself, and tags. In our C headers, these are
>>>>> typedef'd to void*. There are also iterators, which we haven't
>>>>> really
>>>>> called handles, but could be referred to that way.
>>>>>> 2) For situations where we want to support multi-parts per
>>>>>> processor/process:
>>>>>> (a) How do we want to distinguish between processor/process level
>>>>>> functionalities against part level ones (keeping user- and
>>>>>> implementation-convenience and efficiency in mind)? Ones which would
>>>>>> fall
>>>>>> under processor level are, like list of parts on processor, MPI_Rank
>>>>>> etc.,
>>>>>> whereas ones which would fall under part level are, like neighboring
>>>>>> parts
>>>>>> (not procs.) etc. Further, there could be ones where users wants to
>>>>>> get/iterate mesh entities (and get adjacencies) at a processor
>>>>>> and/or
>>>>>> part
>>>>>> level.
>>>>> Processor-level queries are on the iMesh instance, part-level queries
>>>>> are on the entity set representing the part. Our iterator functions
>>>>> operate on both (with processor-level queries simply using the root
>>>>> set).
>>>>>> (b) Assuming a part-handle is supported, how can user/application
>>>>>> get
>>>>>> access to it (say on a processor where part resides)? Basically will
>>>>>> there
>>>>>> be a way to directly access the part-handle (like part iterator at
>>>>>> iProcParts level) or user has to access it through tags/tag names,
>>>>>> in
>>>>>> which case user has to figure out what is the tag/tag name for a
>>>>>> particular part (and who defines these tags/tag names).
>>>>> I advocate having both: a conventional tag given to parts, so that
>>>>> you
>>>>> can find sets that are parts by looking for sets with that tag; and
>>>>> also having a convenience function (as part of the parallel
>>>>> extensions
>>>>> to iMesh) which returns all the parts in the given instance (i.e. on
>>>>> the processor). Note an important capability here for this function
>>>>> is to pass in an optional tag name/handle indicating the partition
>>>>> you're asking about. That allows multiple partitions to co-exist,
>>>>> which is important for some applications.
>>>>>> 3) How general we want to be in interface for different data
>>>>>> models/implementations (as in future we may want to incorporate/fit
>>>>>> other
>>>>>> implementations), especially between serial and parallel data. Two
>>>>>> possibilities for data models I can think of are: (a) one (serial)
>>>>>> data
>>>>>> model is enhanced to store parallel information and (b) serial one
>>>>>> is
>>>>>> supplemented by a separate parallel one to support parallel
>>>>>> functionalities (in possibility (b) all parallel-specific
>>>>>> information
>>>>>> is
>>>>>> stored in a separate data to serial-specific data). We could design
>>>>>> interface that would fit both possibilities, this is the reason why
>>>>>> we
>>>>>> included iPartMesh (section 3.4) level functions which are specific
>>>>>> to
>>>>>> parallel functionalities in mesh (and passing handle to serial data
>>>>>> in
>>>>>> these interface will not work for second possibility (b)). I do not
>>>>>> know
>>>>>> how much relevant is this.
>>>>> I think it's very important to put the parallel data into our
>>>>> existing
>>>>> data models, or extend the data model if that can't be done (which I
>>>>> doubt, since I've already embedded this information in our current
>>>>> data model). This is important because it allows us to use current
>>>>> tools to examine parallel data. Note also that one may sometimes be
>>>>> examining parallel data in a serial environment (e.g. running a
>>>>> partitioner in serial), so we shouldn't restrict accessing parallel
>>>>> data to a parallel environment.
>>>>> - tim
>>>>>> Let me know if you have questions.
>>>>>> Vitus, due to above questions I did not respond to your comments. I
>>>>>> do not
>>>>>> know if above questions and comments make things clear. If you still
>>>>>> have
>>>>>> anything specific please let us know.
>>>>>> Karen, Is there a way to create an email list for this subcommittee
>>>>>> as if
>>>>>> we want to add (and remove) people (and it will keep record of all
>>>>>> the
>>>>>> messages). I have added Ting in this response as she is also working
>>>>>> on
>>>>>> this stuff from RPI side.
>>>>>> Thanks,
>>>>>> Onkar
>>>>>>> Hi all,
>>>>>>> I'd like to re-iterate what I think should be the general
>>>>>>> behavior of
>>>>>>> functions in the parallel interface. IMO, we should take advantage
>>>>>>> of
>>>>>>> the simple yet powerful data model we already have for iMesh. That
>>>>>>> means using mesh sets for things which are obviously sets, and
>>>>>>> using
>>>>>>> the
>>>>>>> functions which already exist for accessing data in those sets. I
>>>>>>> think
>>>>>>> it does make sense in certain cases to make convenience functions
>>>>>>> in
>>>>>>> the
>>>>>>> parallel interface for accessing e.g. all the sets which represent
>>>>>>> parts
>>>>>>> of a partition, on a current processor or globally, but I think we
>>>>>>> should minimize these.
>>>>>>> Based on the general behavior described above, I think many of
>>>>>>> the
>>>>>>> functions proposed for global ids and parts/partitions already
>>>>>>> exist
>>>>>>> in
>>>>>>> iMesh. For example, iPart_getGlobalID, iPart_createGlobalID,
>>>>>>> iProcParts_getPartIdArrOnProc, iProcParts iterator functions, etc.
>>>>>>> - tim
>>>>>>> "You will keep in perfect peace him whose mind is
>>>>>>> steadfast, because he trusts in you." Isaiah 26:3
>>>>>>> Tim Tautges Argonne National Laboratory
>>>>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>>>>> phone: (608) 263-8485 1500 Engineering Dr.
>>>>>>> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
