itaps-parallel [Fwd: Subcommittee for Parallel Interface Definition: Global IDs]
Tim Tautges
tautges at mcs.anl.gov
Wed Oct 24 14:38:25 CDT 2007
[Forwarding for archival]
-------- Original Message --------
Subject: Subcommittee for Parallel Interface Definition: Global IDs
Date: Mon, 15 Oct 2007 09:13:28 -0600
To: Onkar Sahni <osahni at scorec.rpi.edu>, Mark Shephard
<shephard at scorec.rpi.edu>, Kenneth Jansen <kjansen at scorec.rpi.edu>,
Tim Tautges <tautges at mcs.anl.gov>, Vitus Leung <vjleung at sandia.gov>,
Karen Devine <kddevin at sandia.gov>, Carl Ollivier-Gooch
<cfog at mech.ubc.ca>, Lori A. Diachin <diachin2 at llnl.gov>, Jason
Kraftcheck <kraftche at cae.wisc.edu>, Knupp, Patrick <pknupp at sandia.gov>
Honored Parallel Interface Subcommittee members:
Please note that Step 0 of the Parallel Interface draft is due today.
Step 0: draft what functions are needed in each
category; due Oct 15.
Step 1: agree on what functions are needed in each
category; due Oct. 18.
Step 2: formalize the syntax for those functions;
due Oct 25.
Step 3: review and revise output from Steps 1 and 2,
and write first draft; due Nov. 16.
Global Queries: Argonne (Tim)
Global IDs: Sandia (Vitus, Karen)
Partition Model: RPI (Mark, Ken, Onkar)
Partitioned Mesh: UBC (Carl)
So we should circulate our draft of functions today and have a lively
discussion for the rest of the week.
Toward that end, the Global IDs function list is attached (GlobalIDs.txt).
Please respond to all with your comments.
The original email of tasks (draftzero_assignments.txt) is also attached in
case you already deleted the email of assignments. Let me know if you need
more info.
Karen
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/itaps-parallel/attachments/20071024/d8aae1a4/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/itaps-parallel/attachments/20071024/d8aae1a4/attachment-0001.obj>
More information about the itaps-parallel
