itaps-parallel [Fwd: Re: Parallel Interface philosophical comments]
Tim Tautges
tautges at mcs.anl.gov
Wed Oct 24 14:36:44 CDT 2007
[Forwarding for archival]
-------- Original Message --------
Subject: Re: Parallel Interface philosophical comments
Date: Tue, 23 Oct 2007 18:14:41 -0400 (EDT)
To: Tim Tautges <tautges at mcs.anl.gov>
CC: Mark Shephard <shephard at scorec.rpi.edu>, Devine, Karen D.
<kddevin at sandia.gov>, Kenneth Jansen <kjansen at scorec.rpi.edu>, Ting
Xie <txie at scorec.rpi.edu>, Vitus Leung <vjleung at sandia.gov>, Carl
Ollivier-Gooch <cfog at mech.ubc.ca>, Lori A. Diachin
<diachin2 at llnl.gov>, Jason Kraftcheck <kraftche at cae.wisc.edu>,
Knupp, Patrick <pknupp at sandia.gov>
References: <C338DFBB.B5CD%kddevin at sandia.gov>
<471CA0EE.8020904 at mcs.anl.gov>
<56567.128.113.131.145.1193166547.squirrel at www.scorec.rpi.edu>
<471E4FC7.80003 at mcs.anl.gov> <471E578B.10803 at scorec.rpi.edu>
<471E5EFE.20700 at mcs.anl.gov>
>> I was under the impression at the bootcamp that we agreed that those
>> that have operational parallel capabilities support it through either
>> reverse classification (via mesh sets) or classification and that we
>> would support both approaches through iPart. However, you last couple of
>> emails appear to go back to the old argument of we must do the minimal
>> thing and since meshsets (reverse classification) are in there that is
>> the only way.
>> By the way, if I understand correctly our existing data-model has the
>> ability to support reverse classification (meshsets) and classification
>> through iRel, so should the parallel model. Yes, that means more
>> functions than only one or the other way, but both approaches exist. (In
>> addition, I still do not equate functionality and data model - it
>> someone meets the functionality I really do not give a crap about their
>> data model.)
> My understanding of our boot camp discussions was that we would
> reference parts using a part handle, and that the part handle would be
> usable in iMesh functions taking an entity set handle. This is
> analogous to how the root set handle is used.
There are multiple things which I want to make clear:
(a) Part is not necessarily an entity-set (some implementations may choose
it to be). Moreover, operations supported on entity-sets do not have to
work on parts for implementations which do not consider parts as
entity-sets.
(b) Allowing part-handles to be used along with root-set-handle,
entity-set-handle etc. is only required for existing iMesh functions (not
for new ones, see next point). Infact, I see a potential problem here,
consider a specific case where user wants to get entities in an specific
entity-set for only a specific part; how will we support it?
(c) The new interface functions, we need to define for parts (to support
parallel requirements/functionalities), will take part-handles as input
and not any set-handles (if some implementation wants to use entity-sets
for parts they can have part-handle and entity-set-handle as one and the
same).
> iRel is for relating data between different interfaces. As I understand
> it, we are building parallel functionality as part of iMesh. Therefore,
> we shouldn't need to use iRel for this.
>> There are a number of groups that use classification as the primary mode
>> of interaction for doing things similar to how the RPI group does. Just
>> as we would not want you to have redo all your parallel work to do
>> things strictly from a classification perspective, we do not expect that
>> the ITAPS parallel interface will require RPI to re-do all its parallel
>> adaptive work (years worth of work dating back to the mid-90's when we
>> were the first to do it) that is being used for SciDAC applications to
>> fit with a specific one way of doing things.
>> By the way, some feel the classification is a simple and powerful way to
>> do things and mesh sets are actually substantial extra overhead to a
>> well defined model of using classification. In my experience, I would
>> love to have both classification and reverse classification at all
>> times, since depending on the question being asked, one is a faster way
>> to answer it. However, due to the extra data and headache of keeping
>> things correctly set, most I know tend to focus on one and use the other
>> temporary manner when its advantageous.
> I'm not advocating that we do things only with reverse classification, I
> agree we need to be able to go both ways. I'm just arguing that if we
> do pass part handles through the interface, then we operate on those
> part handles using existing functions, rather than make new ones that do
> virtually the same thing.
For existing functions we can support compatibility with part-handles but
main concern is for new ones (which doesn't do existing/same things).
- Onkar
> - tim
>> Mark
>> Tim Tautges wrote:
>>> Onkar Sahni wrote:
>>>> Hi all,
>>>> Here are some of my questions and comments on ITAPS parallel
>>>> interface:
>>>> 1) Is there a difference between "instance" and "handle" in ITAPS
>>>> terminology (or are there any definition for these)? (I may have
>>>> missed it
>>>> if this was resolved/defined in previous ITAPS interfaces like iMesh).
>>> We use the generic term "handle" as an identifier for entities, entity
>>> sets, the interface itself, and tags. In our C headers, these are
>>> typedef'd to void*. There are also iterators, which we haven't really
>>> called handles, but could be referred to that way.
>>>> 2) For situations where we want to support multi-parts per
>>>> processor/process:
>>>> (a) How do we want to distinguish between processor/process level
>>>> functionalities against part level ones (keeping user- and
>>>> implementation-convenience and efficiency in mind)? Ones which would
>>>> fall
>>>> under processor level are, like list of parts on processor, MPI_Rank
>>>> etc.,
>>>> whereas ones which would fall under part level are, like neighboring
>>>> parts
>>>> (not procs.) etc. Further, there could be ones where users wants to
>>>> get/iterate mesh entities (and get adjacencies) at a processor and/or
>>>> part
>>>> level.
>>> Processor-level queries are on the iMesh instance, part-level queries
>>> are on the entity set representing the part. Our iterator functions
>>> operate on both (with processor-level queries simply using the root
>>> set).
>>>> (b) Assuming a part-handle is supported, how can user/application get
>>>> access to it (say on a processor where part resides)? Basically will
>>>> there
>>>> be a way to directly access the part-handle (like part iterator at
>>>> iProcParts level) or user has to access it through tags/tag names, in
>>>> which case user has to figure out what is the tag/tag name for a
>>>> particular part (and who defines these tags/tag names).
>>> I advocate having both: a conventional tag given to parts, so that you
>>> can find sets that are parts by looking for sets with that tag; and
>>> also having a convenience function (as part of the parallel extensions
>>> to iMesh) which returns all the parts in the given instance (i.e. on
>>> the processor). Note an important capability here for this function
>>> is to pass in an optional tag name/handle indicating the partition
>>> you're asking about. That allows multiple partitions to co-exist,
>>> which is important for some applications.
>>>> 3) How general we want to be in interface for different data
>>>> models/implementations (as in future we may want to incorporate/fit
>>>> other
>>>> implementations), especially between serial and parallel data. Two
>>>> possibilities for data models I can think of are: (a) one (serial)
>>>> data
>>>> model is enhanced to store parallel information and (b) serial one is
>>>> supplemented by a separate parallel one to support parallel
>>>> functionalities (in possibility (b) all parallel-specific information
>>>> is
>>>> stored in a separate data to serial-specific data). We could design
>>>> interface that would fit both possibilities, this is the reason why we
>>>> included iPartMesh (section 3.4) level functions which are specific to
>>>> parallel functionalities in mesh (and passing handle to serial data in
>>>> these interface will not work for second possibility (b)). I do not
>>>> know
>>>> how much relevant is this.
>>> I think it's very important to put the parallel data into our existing
>>> data models, or extend the data model if that can't be done (which I
>>> doubt, since I've already embedded this information in our current
>>> data model). This is important because it allows us to use current
>>> tools to examine parallel data. Note also that one may sometimes be
>>> examining parallel data in a serial environment (e.g. running a
>>> partitioner in serial), so we shouldn't restrict accessing parallel
>>> data to a parallel environment.
>>> - tim
>>>> Let me know if you have questions.
>>>> Vitus, due to above questions I did not respond to your comments. I
>>>> do not
>>>> know if above questions and comments make things clear. If you still
>>>> have
>>>> anything specific please let us know.
>>>> Karen, Is there a way to create an email list for this subcommittee
>>>> as if
>>>> we want to add (and remove) people (and it will keep record of all the
>>>> messages). I have added Ting in this response as she is also working
>>>> on
>>>> this stuff from RPI side.
>>>> Thanks,
>>>> Onkar
>>>>> Hi all,
>>>>> I'd like to re-iterate what I think should be the general
>>>>> behavior of
>>>>> functions in the parallel interface. IMO, we should take advantage
>>>>> of
>>>>> the simple yet powerful data model we already have for iMesh. That
>>>>> means using mesh sets for things which are obviously sets, and using
>>>>> the
>>>>> functions which already exist for accessing data in those sets. I
>>>>> think
>>>>> it does make sense in certain cases to make convenience functions in
>>>>> the
>>>>> parallel interface for accessing e.g. all the sets which represent
>>>>> parts
>>>>> of a partition, on a current processor or globally, but I think we
>>>>> should minimize these.
>>>>> Based on the general behavior described above, I think many of the
>>>>> functions proposed for global ids and parts/partitions already exist
>>>>> in
>>>>> iMesh. For example, iPart_getGlobalID, iPart_createGlobalID,
>>>>> iProcParts_getPartIdArrOnProc, iProcParts iterator functions, etc.
>>>>> - tim
>>>>> "You will keep in perfect peace him whose mind is
>>>>> steadfast, because he trusts in you." Isaiah 26:3
>>>>> Tim Tautges Argonne National Laboratory
>>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>>> phone: (608) 263-8485 1500 Engineering Dr.
>>>>> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
