[ExM Users] Debugging suggests for 'Turbine not compiled with Python support' error
lschult2 lschult2 at masonlive.gmu.edu
Thu May 25 11:24:59 CDT 2017
Trying to implement an EMEWS setup which is based on swift/t. I get the error 'Turbine not compiled with Python support' when I run the swift script but have done testing per the EMEWS tutorial to ensure that the python code used does work as expected. I've found the error output comes from this portion of the python.c of the swift/t code:
static int
Python_Eval_Cmd(ClientData cdata, Tcl_Interp *interp,
int objc, Tcl_Obj *const objv[])
return turbine_user_errorv(interp,
"Turbine not compiled with Python support");
I am not sure how to go about determining what is the root cause of this to fix it. Any suggestions on how to debug is greatly appreciated.
--Laura
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20170525/7265ebd6/attachment.html>
More information about the ExM-user mailing list
