[ExM Users] Implicit blocking on foreach construct?
Timothy Stitt (TGAC)
Timothy.Stitt at tgac.ac.uk
Thu Mar 19 05:32:38 CDT 2015
Tim,
Thanks. Following your suggestions/example I was able to massage my own code to do what I need now. It took a couple of days working with Swift/T but the whole data-flow mindset has now kicked in and briefly banished the typical sequential instruction thinking. It all makes sense now.
Cheers.
Timothy Stitt PhD / Head of Scientific Computing
The Genome Analysis Centre (TGAC)
http://www.tgac.ac.uk/
p: +44 1603 450378
e: timothy.stitt at tgac.ac.uk<mailto:timothy.stitt at tgac.ac.uk>
From: Tim Armstrong <tim.g.armstrong at gmail.com<mailto:tim.g.armstrong at gmail.com>>
Date: Tuesday, 17 March 2015 21:20
To: Timothy Stitt <timothy.stitt at tgac.ac.uk<mailto:timothy.stitt at tgac.ac.uk>>
Cc: "exm-user at lists.mcs.anl.gov<mailto:exm-user at lists.mcs.anl.gov>" <exm-user at lists.mcs.anl.gov<mailto:exm-user at lists.mcs.anl.gov>>
Subject: Re: [ExM Users] Implicit blocking on foreach construct?
Hi Tim,
It's possible if you reformulate the problem in terms of data flow- there's no direct way in Swift to ask "is the loop finished" - but there is a way to ask "is the data being computed by the loop finished".
The "wait" construct - it lets you execute a block of code after a bit of data is assigned.
E.g. a trivial example is
int x = do_some_computation();
wait (x) {
trace("x is done!");
If you're building an array of files or similar, it's a little more complicated:
import io;
import files;
file x[];
wait deep (x) {
trace("Done");
foreach i in [1:10] {
file tmp<"/tmp/swift-tmp-" + i + ".txt">;
tmp = write("");
x[i] = tmp;
This only prints "Done" once all of the files have been written. The wait deep ensures that everything in the array is completely built.
I'm also not sure about your use case, but Swift has some built-in support for generating temporary files - Justin Wozniak was recently working on improving that.
- Tim
On 17 March 2015 at 15:08, Timothy Stitt (TGAC) <Timothy.Stitt at tgac.ac.uk<mailto:Timothy.Stitt at tgac.ac.uk>> wrote:
Hi all,
Is there a way to add explicit blocking to the end of the foreach construct? I have the following logic which doesn't work right now as the delete_files() routine is assumed to be concurrent with the foreach block when I want it to execute after the foreach block is completed for all workers:
foreach { do some work creating temp files}
delete_files() // delete temp files using an app function
Tim.
p: +44 1603 450378<tel:%2B44%201603%20450378>
ExM-user mailing list
ExM-user at lists.mcs.anl.gov<mailto:ExM-user at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20150319/40bd4f33/attachment.html>
More information about the ExM-user
