[ExM Users] Problem Building exm v0.8.0 on Linux
Timothy Stitt (TGAC) Timothy.Stitt at tgac.ac.uk
Tue Aug 11 15:17:18 CDT 2015
Thanks for the prompting Tim. I just disabled the Python integration and it built successfully.
Much appreciated…
Tim.
Timothy Stitt PhD / Head of Scientific Computing
The Genome Analysis Centre (TGAC), Room 204b
http://www.tgac.ac.uk/
p: +44 1603 450378
e: timothy.stitt at tgac.ac.uk<mailto:timothy.stitt at tgac.ac.uk>
From: Tim Armstrong <tim.g.armstrong at gmail.com<mailto:tim.g.armstrong at gmail.com>>
Date: Tuesday, 11 August 2015 21:01
To: Timothy Stitt <timothy.stitt at tgac.ac.uk<mailto:timothy.stitt at tgac.ac.uk>>
Cc: "exm-user at lists.mcs.anl.gov<mailto:exm-user at lists.mcs.anl.gov>" <exm-user at lists.mcs.anl.gov<mailto:exm-user at lists.mcs.anl.gov>>
Subject: Re: [ExM Users] Problem Building exm v0.8.0 on Linux
It looks like it's not pointed correctly at python - what Python settings did you have enabled in your settings file?
- Tim
On 11 August 2015 at 12:43, Timothy Stitt (TGAC) <Timothy.Stitt at tgac.ac.uk<mailto:Timothy.Stitt at tgac.ac.uk>> wrote:
Thanks Tim.
I commented out the optimised build option and rebuilt. Unfortunately, it didn’t get any better. I’ve attached the full build log.
I also ran 'make check_includes'. The output is as follows:
[stittt at v0267] /tgac/software/testing/exm/0.8.0/src/turbine > make check_includes
  CHECK.SH
Not found: python2.7/Python.h
Not found: tests/staticapp-1.c
Not found: tests/staticapp-bundled-1.c
Cheers,
Tim.
p: +44 1603 450378<tel:%2B44%201603%20450378>
Date: Tuesday, 11 August 2015 18:04
Hi Tim,
 There isn't an obvious smoking gun in there. If we had the full output to see how far it got that might provide some hints.
I can suggest a couple of other things to try to dig down into the cause. First, you could try running make check_includes in turbine/code - that will report if a header is missing, which can cause a silent build failure. Second, it looks like you're doing an optimised build - you could try doing a non-optimised build and see if that succeeds.
- Tim
On 11 August 2015 at 08:55, Timothy Stitt (TGAC) <Timothy.Stitt at tgac.ac.uk<mailto:Timothy.Stitt at tgac.ac.uk>> wrote:
Dear support,
I’ve been wrestling with building exm v0.8.0 on our RHEL 6.0 Linux system. I’m using gcc v4.9.1.
When building the Turbine package it fails with the following:
<snip>
Preparing config files: please wait...
configure: creating ./config.status
config.status: creating src/turbine/turbine-version.h
config.status: creating src/turbine/module.mk<http://module.mk>
config.status: creating src/util/module.mk<http://module.mk>
config.status: creating src/util/debug-tokens.tcl
config.status: creating src/tcl/module.mk<http://module.mk>
config.status: creating src/tcl/adlb/module.mk<http://module.mk>
config.status: creating src/tcl/blob/module.mk<http://module.mk>
config.status: creating src/tcl/c-utils/module.mk<http://module.mk>
config.status: creating src/tcl/mpe/module.mk<http://module.mk>
config.status: creating src/tcl/julia/module.mk<http://module.mk>
config.status: creating src/tcl/python/module.mk<http://module.mk>
config.status: creating src/tcl/r/module.mk<http://module.mk>
config.status: creating src/tcl/static-pkg/module.mk<http://module.mk>
config.status: creating src/tcl/turbine/module.mk<http://module.mk>
config.status: creating src/executables/module.mk<http://module.mk>
config.status: creating lib/module.mk<http://module.mk>
config.status: creating scripts/main-wrap/module.mk<http://module.mk>
config.status: creating scripts/submit/module.mk<http://module.mk>
config.status: creating scripts/submit/cobalt/module.mk<http://module.mk>
config.status: creating scripts/submit/cray/module.mk<http://module.mk>
config.status: creating scripts/submit/ec2/module.mk<http://module.mk>
config.status: creating scripts/submit/pbs/module.mk<http://module.mk>
config.status: creating scripts/submit/slurm/module.mk<http://module.mk>
config.status: creating scripts/turbine-config.sh
config.status: creating scripts/turbine-build-config.sh
config.status: creating tests/module.mk<http://module.mk>
config.status: creating tests/runbin.zsh
config.status: creating Makefile
config.status: creating config.h
config.status: config.h is unchanged
  MKSTATIC_DEPSsrc/executables/turbine_sh.manifest.d
  DEPsrc/tcl/static-pkg/static-pkg.d
  MKSTATIC_DEPStests/staticapp-bundled-1.manifest.d
  MKSTATIC_DEPStests/staticapp-1.manifest.d
  TCLsrc/util/debug.h
  MKSTATICsrc/executables/turbine_sh.c
  DEPsrc/tcl/turbine/tcl-turbine.d
  DEPsrc/tcl/adlb/tcl-adlb.d
  DEPsrc/tcl/julia/tcl-julia.d
  DEPsrc/util/debug.d
  DEPsrc/turbine/executors/noop_executor.d
  DEPsrc/turbine/async_exec.d
  DEPsrc/turbine/worker.d
  DEPsrc/turbine/cache.d
  DEPsrc/turbine/turbine.d
  DEPsrc/executables/turbine_sh.d
  CCsrc/tcl/static-pkg/static-pkg.o
  CCsrc/turbine/turbine.o
  CCsrc/turbine/cache.o
  CCsrc/turbine/worker.o
  CCsrc/turbine/executors/noop_executor.o
  CCsrc/turbine/async_exec.o
  CCsrc/util/debug.o
  CCsrc/tcl/julia/tcl-julia.o
  CCsrc/tcl/adlb/tcl-adlb.o
src/turbine/executors/noop_executor.c: In function ‘noop_execute’:
src/turbine/executors/noop_executor.c:174:8: warning: variable ‘found_slot’ set but not used [-Wunused-but-set-variable]
   bool found_slot = false;
src/turbine/worker.c: In function ‘task_error’:
src/turbine/worker.c:102:7: warning: unused variable ‘rc’ [-Wunused-variable]
   int rc = asprintf(&msg, "\n%s%s", prefix, command);
src/turbine/async_exec.c: In function ‘launch_error’:
src/turbine/async_exec.c:482:7: warning: unused variable ‘rc’ [-Wunused-variable]
   int rc = asprintf(&msg, "Turbine %s worker task error in: %s",
src/turbine/async_exec.c: In function ‘callback_error’:
src/turbine/async_exec.c:501:7: warning: unused variable ‘rc’ [-Wunused-variable]
   int rc = asprintf(&msg, "Turbine %s worker task error in callback: %s",
  ARlib/libtclturbinestatic.a
src/tcl/adlb/tcl-adlb.c: In function ‘adlb_setup_comm’:
src/tcl/adlb/tcl-adlb.c:384:7: warning: variable ‘rc’ set but not used [-Wunused-but-set-variable]
   int rc;
src/tcl/adlb/tcl-adlb.c: In function ‘tcl_dict_to_packed_container’:
src/tcl/adlb/tcl-adlb.c:2132:1: warning: label ‘exit_err’ defined but not used [-Wunused-label]
 exit_err:
src/tcl/adlb/tcl-adlb.c: In function ‘tcl_list_to_packed_multiset’:
src/tcl/adlb/tcl-adlb.c:2192:1: warning: label ‘exit_err’ defined but not used [-Wunused-label]
 exit_err:
src/tcl/adlb/tcl-adlb.c: In function ‘packed_struct_to_tcl_dict’:
src/tcl/adlb/tcl-adlb.c:2247:17: warning: unused variable ‘name’ [-Wunused-variable]
     const char *name = field_names[i];
src/tcl/adlb/tcl-adlb.c: In function ‘get_compound_type’:
src/tcl/adlb/tcl-adlb.c:5100:1: warning: label ‘exit_err’ defined but not used [-Wunused-label]
 exit_err:
src/tcl/adlb/tcl-adlb.c: In function ‘ADLB_Subscript_Impl’:
src/tcl/adlb/tcl-adlb.c:5645:11: warning: unused variable ‘sub’ [-Wunused-variable]
     char *sub = Tcl_GetStringFromObj(objv[i + 2], &sub_len);
src/tcl/adlb/tcl-adlb.c: In function ‘adlb_datum2tclobj’:
src/tcl/adlb/tcl-adlb.c:2707:22: warning: ‘tmp.value’ may be used uninitialized in this function [-Wmaybe-uninitialized]
   adlb_datum_storage tmp;
src/tcl/adlb/tcl-adlb.c:2739:17: warning: ‘tmp.length’ may be used uninitialized in this function [-Wmaybe-uninitialized]
       *result = Tcl_NewStringObj(tmp.STRING.value,
src/tcl/adlb/tcl-adlb.c: In function ‘ADLB_Enumerate_Cmd’:
src/tcl/adlb/tcl-adlb.c:3017:8: warning: ‘include_vals’ may be used uninitialized in this function [-Wmaybe-uninitialized]
   bool include_vals;
src/tcl/adlb/tcl-adlb.c:3016:8: warning: ‘include_keys’ may be used uninitialized in this function [-Wmaybe-uninitialized]
   bool include_keys;
src/tcl/adlb/tcl-adlb.c: In function ‘ADLB_Refcount_Incr_Cmd’:
src/tcl/adlb/tcl-adlb.c:4791:22: warning: ‘mode’ may be used uninitialized in this function [-Wmaybe-uninitialized]
   adlb_refcount_type mode;
src/tcl/adlb/tcl-adlb.c: In function ‘ADLB_Parse_Subscript’:
src/tcl/adlb/tcl-adlb.c:5498:15: warning: ‘tmp_sub.length’ may be used uninitialized in this function [-Wmaybe-uninitialized]
   sub->length += to_append.length;
src/tcl/adlb/tcl-adlb.c:5404:22: note: ‘tmp_sub.length’ was declared here
       adlb_subscript tmp_sub;
src/tcl/adlb/tcl-adlb.c: In function ‘ADLB_Create_Nested_Impl.isra.52’:
src/tcl/adlb/tcl-adlb.c:4340:8: warning: ‘retrieved.write_refs’ may be used uninitialized in this function [-Wmaybe-uninitialized]
     if (retrieved.write_refs <= 0)
In file included from src/tcl/adlb/tcl-adlb.c:71:0:
./src/tcl/util.h:164:5: warning: ‘retrieved.id<http://retrieved.id>’ may be used uninitialized in this function [-Wmaybe-uninitialized]
     turbine_tcl_condition_failed(interp, objv[0], format, ## args); \
src/tcl/adlb/tcl-adlb.c:4333:14: note: ‘retrieved.id<http://retrieved.id>’ was declared here
     adlb_ref retrieved;
exm-setup.zsh: turbine: build FAILED
</snip>
I see various warnings but no errors in the above…yet the setup fails. I would be grateful if you could provide some assistance in diagnosing what is happening.
Much appreciated,
Tim.
ExM-user mailing list
ExM-user at lists.mcs.anl.gov<mailto:ExM-user at lists.mcs.anl.gov>
https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20150811/01e98c56/attachment-0001.html>
More information about the ExM-user mailing list
