[ExM Users] Swift/T using wrong Python
Matthew Turk matthewturk at gmail.com
Tue Apr 21 11:23:03 CDT 2015
Hi all,
I set up Swift/T for the first time the other day and had similar
problems getting it to use my custom-built Python.  I was able to get
exm-settings.sh to be recognized, but then during execution it failed.
I ended up having to set both PYTHONHOME *and* LD_PRELOAD, where
LD_PRELOAD had to have both the MPI .so file and the libpython2.7.so
included.  After that it worked just fine.
-Matt
On Tue, Apr 21, 2015 at 11:19 AM, Ozik, Jonathan <jozik at anl.gov> wrote:
> Tim,
> I’ve tried to set the PYTHONHOME variable a few times to see if I can force
> the right python version to be found but I have yet to be successful.
> Jonathan
> On Apr 21, 2015, at 9:54 AM, Tim Armstrong <tim.g.armstrong at gmail.com>
> wrote:
> It looks like the environment variable PYTHONHOME=/path/to/anaconda needs to
> be set for it to look in the right places for the packages.  I'm looking to
> see if we can automatically set this up so that it does the right thing in
> future.
> - Tim
> On 20 April 2015 at 18:24, Ozik, Jonathan <jozik at anl.gov> wrote:
>> Tim,
>> Just for kicks I tried to create a standalone conda environment for Python
>> 2.7 and used that as my PYTHON_INSTALL location but I still am seeing
>> incorrect sys.version, platform.python_version(), etc. Not sure what’s going
>> on, but like I said earlier, it doesn’t seem to affect the running of the
>> code.
>> Jonathan
>> On Apr 20, 2015, at 4:56 PM, Jonathan Ozik <jozik at anl.gov> wrote:
>> Tim,
>> I had:
>> PYTHON_INSTALL=/Users/jozik/anaconda
>> I had to go in and undo some of the attempts I had made to fix the issue
>> (but probably just exacerbated it), and now with everything back to its
>> initial settings I get the intended:
>> Using Python lib directory: /Users/jozik/anaconda/lib
>> Using Python lib name:      python2.7
>> If I ignore what I’m seeing returned by sys.version, it does look like the
>> correct Python version is being picked up, at least based on the modules
>> that are available. Maybe the sys.version issue is associated with the
>> subtle issue you mentioned?
>> In any case, thank you for the help.
>> Jonathan
>> On Apr 20, 2015, at 9:46 AM, Tim Armstrong <tim.g.armstrong at gmail.com>
>> wrote:
>> What did you have PYTHON_INSTALL set to in exm-settings?  It should be
>> printing the directory/name there.
>> I was actually able to replicate a similar problem, which may not be what
>> you were seeing.  There's a subtle issue with ordering of library
>> dependencies where it was picking up the system Python library rather than
>> the other one in some cases.
>> - Tim
>> On 19 April 2015 at 23:28, Ozik, Jonathan <jozik at anl.gov> wrote:
>>> I’m not an Autoconf expert, so take this with a grain of salt, but the
>>> two lines in the turbine configure script:
>>>     echo "Using Python lib directory: ${USE_PYTHON_LIBDIR}"
>>>     echo "Using Python lib name:      ${USE_PYTHON_NAME}”
>>> were showing:
>>> Using Python lib directory: .
>>> Using Python lib name:      1
>>> so I looked at how those variables were being derived, and it looks like
>>> there might be some issues there.
>>> Also, exm-settings.sh doesn’t mention the --with-python-lib option
>>> either.
>>> As for the sys.version issue that I’m seeing, it’s really strange,
>>> because it is possible that sys.version is not correct, as odd as that may
>>> sound. I know that sys.executable is not always correct, but I thought I
>>> could trust sys.version. The python that is being used definitely has
>>> modules installed that are not in the version of python that’s being
>>> reported. Odd. But the good news is that I’m now able to move on with what
>>> we’re actually trying to do.
>>> Thanks again for helping me think through this,
>>> Jonathan
>>> On Apr 19, 2015, at 9:21 PM, Tim Armstrong <tim.g.armstrong at gmail.com>
>>> wrote:
>>> Hmm, so it's probably picking up the system Python by default.   This may
>>> be an oversight on our part - I'm creating a bug to look into it.  Our build
>>> should be linking it to your other python library but isn't.
>>> As a workaround, you can override this with the DYLD_LIBRARY_PATH
>>> environment variable on Mac OS X.
>>> If you add the directory with your preferred python .dylib file to that
>>> environment variable, it should link against that version of python instead
>>> of the system one.
>>> E.g.
>>> export DYLD_LIBRARY_PATH=/path/to/anaconda/lib
>>> I *think* this should give you a way to work around it in the meantime.
>>> - Tim
>>> On 19 April 2015 at 20:19, Ozik, Jonathan <jozik at anl.gov> wrote:
>>>> Thanks Tim. Here’s what I get on OS X:
>>>> XioMBP:swift_simphony_example_DEAP jozik$ otool -L
>>>> /Users/jozik/work/swift_t/install/turbine/lib/libtclturbine.dylib
>>>> /Users/jozik/work/swift_t/install/turbine/lib/libtclturbine.dylib:
>>>> (compatibility version 0.0.0, current version 0.0.0)
>>>> /Users/jozik/work/swift_t/install/lb/lib/libadlb.dylib (compatibility
>>>> /Users/jozik/work/swift_t/install/c-utils/lib/libexmcutils.dylib
>>>> /usr/local/opt/tcl-tk/lib/libtcl8.6.dylib (compatibility version 8.6.0,
>>>> current version 8.6.3)
>>>> /usr/local/lib/libmpi.12.dylib (compatibility version 13.0.0, current
>>>> version 13.4.0)
>>>> libpython2.7.dylib (compatibility version 2.7.0, current version 2.7.0)
>>>> libz.1.dylib (compatibility version 1.0.0, current version 1.2.8)
>>>> /usr/local/lib/libsz.2.dylib (compatibility version 3.0.0, current
>>>> version 3.0.0)
>>>> /usr/local/lib/libhdf5.8.dylib (compatibility version 9.0.0, current
>>>> version 9.2.0)
>>>> /usr/local/lib/libhdf5_hl.8.dylib (compatibility version 9.0.0, current
>>>> version 9.2.0)
>>>> /usr/local/lib/libpmpi.12.dylib (compatibility version 13.0.0, current
>>>> version 13.4.0)
>>>> /usr/lib/libSystem.B.dylib (compatibility version 1.0.0, current version
>>>> 1213.0.0)
>>>> /usr/local/Cellar/gcc/4.9.2/lib/gcc/x86_64-apple-darwin14.0.0/4.9.2/libgcc_s.1.dylib
>>>> (compatibility version 1.0.0, current version 1.0.0)
>>>> Which doesn’t answer our question of which libpython2.7.dylib is being
>>>> linked to… If there’s a build log file that you want to point me to, I can
>>>> do some more digging.
>>>> Jonathan
>>>> On Apr 19, 2015, at 7:36 PM, Tim Armstrong <tim.g.armstrong at gmail.com>
>>>> wrote:
>>>> It might be helpful to get some linker information from your
>>>> installation to see which Python version it's linking against.
>>>> In linux:
>>>> ldd  /path/to/turbine/lib/libtclturbine.so
>>>> In OS X I think it's something like:
>>>> otool -L /path/to/turbine/lib/libtclturbine.dylib
>>>> - Tim
>>>> On 19 April 2015 at 15:55, Ozik, Jonathan <jozik at anl.gov> wrote:
>>>>> An update. I looked to see whether this was a PATH issue, and saw that
>>>>> there was a difference between how my bash and zsh shells populate the PATH
>>>>> variable. I have made them compatible now, but am still seeing the same
>>>>> issue with the wrong python being picked up.
>>>>> Jonathan
>>>>> > On Apr 18, 2015, at 11:21 PM, Ozik, Jonathan <jozik at anl.gov> wrote:
>>>>> > Hi all,
>>>>> > I’ve run up against an issue where Swift/T’s python and
>>>>> > python_persist are using the wrong Python version. I’ve checked and rebuilt
>>>>> > and it looks like the Python install location specified in exm-settings.sh
>>>>> > is being used in the build log but when I run a simple test:
>>>>> > string ss = python_persist("import sys\nsys.version”);
>>>>> > I’m getting the Python installation at /usr/bin/python rather than
>>>>> > the Python version installed as part of the Anaconda distribution (which is
>>>>> > what the exm-settings.sh is configured to use).
>>>>> > Any advice on how I might better diagnose this would be appreciated.
>>>>> > I’m on Mac OS X (10.10.3).
>>>>> > Jonathan
>>>>> > _______________________________________________
>>>>> > ExM-user mailing list
>>>>> > ExM-user at lists.mcs.anl.gov
>>>>> > https://lists.mcs.anl.gov/mailman/listinfo/exm-user
More information about the ExM-user mailing list
