[ExM Users] UNFILLED CONTAINER SUBSCRIBE
Tim Armstrong
tim.g.armstrong at gmail.com
Sun Sep 28 15:55:50 CDT 2014
The unfilled subscribe message occurs when there's an unfilled dependency
on an array entry, e.g. if X[0] is read but not written.
The debug output has the logical names and array keys, e.g.
"ens_priors_transposed[0]", along with the source file/line number, e.g.
"aidi_EnKF:main():169:4". Those are the ones to look at:
On Sun, Sep 28, 2014 at 2:01 PM, Ozik, Jonathan <jozik at anl.gov> wrote:
> Hello all,
> I’m getting UNFILLED CONTAINER SUBSCRIBE messages when running my script.
> Based on the error output below, is there a (relatively) easy way to track
> this down that you’d recommend?
> Jonathan
> WAITING WORK: 34
> {16} params_to_priors-foreach-wait3 (/<37>:upf_lines
> (aidi_EnKF:params_to_priors():46:4)/)
> {17} params_to_priors-foreach-wait5 (/<38>:aggNewIs
> (aidi_EnKF:params_to_priors():59:4)/)
> {18} params_to_priors-call-size0
> (/<39>:ens_priors_transposed[0] (aidi_EnKF:params_to_priors():77:4)/)
> {19} params_to_priors-call_foreign-size-1
> (/<39>:ens_priors_transposed (aidi_EnKF:params_to_priors():77:4)/)
> {22} posteriors_to_params-call-size0 (/<27>:__t:67[0]
> (aidi_EnKF:main():186:5)/)
> {27} priors_to_posteriors-call-size0 (/<25>:__t:61[0]
> (aidi_EnKF:main():184:8)/)
> {28} priors_to_posteriors-call_foreign-size-1 (/<25>:__t:61
> {29} priors_to_posteriors-call_sync-blob_from_floats
> (/<46>:one_dim_ens_priors (aidi_EnKF:priors_to_posteriors():123:1)/)
> {30} shape_one_dim-async_op-minus_int (/<44>:rows
> (aidi_EnKF:priors_to_posteriors():121:3)/)
> {31} shape_one_dim-async_op-minus_int-1 (/<45>:cols
> (aidi_EnKF:priors_to_posteriors():122:1)/)
> {32} flatten_two_dim-call-size0 (/<25>:__t:61[0]
> {33} flatten_two_dim-call_foreign-size-1 (/<25>:__t:61
> {34} posteriors_to_params-wait-range3 (/<43>:__t:6
> (aidi_EnKF:posteriors_to_params():138:30)/)
> {36} posteriors_to_params-wait-range3 (/<43>:__t:6
> {44} posteriors_to_params-wait-range1 (/<43>:__t:6
> {45} posteriors_to_params-wait-range1 (/<43>:__t:6
> {46} posteriors_to_params-wait-range1 (/<43>:__t:6
> {47} posteriors_to_params-wait-range1 (/<43>:__t:6
> {48} posteriors_to_params-wait-range1 (/<43>:__t:6
> {49} posteriors_to_params-wait-range1 (/<43>:__t:6
> {50} posteriors_to_params-wait-range1 (/<43>:__t:6
> {51} posteriors_to_params-wait-range1 (/<43>:__t:6
> {52} posteriors_to_params-wait-range1 (/<43>:__t:6
> {53} posteriors_to_params-wait-range1 (/<43>:__t:6
> {54} posteriors_to_params-wait-range1 (/<43>:__t:6
> {55} posteriors_to_params-wait-range1 (/<43>:__t:6
> {56} posteriors_to_params-wait-range1 (/<43>:__t:6
> {57} posteriors_to_params-wait-range1 (/<43>:__t:6
> {535} params_to_priors-call_sync-string_join (/<215>:ips
> (aidi_EnKF:params_to_priors():48:8)/)
> {538} params_to_priors-call_sync-string_join (/<217>:ips
> {551} params_to_priors-async_op-plus_int (<218>:offset
> (aidi_EnKF:params_to_priors():52:8) /<14>:float_var_names[-14]
> (aidi_EnKF:main():169:4)/)
> {552} params_to_priors-async_op-plus_int (<218>:offset
> (aidi_EnKF:params_to_priors():52:8) /<14>:float_var_names[-13]
> {553} params_to_priors-async_op-plus_int (<216>:offset
> {554} params_to_priors-async_op-plus_int (<216>:offset
> UNFILLED CONTAINER SUBSCRIBE <27>:__t:67[0] (aidi_EnKF:main():186:5) rank:
> 2 work_type: 0
> UNFILLED CONTAINER SUBSCRIBE <14>:float_var_names[-13]
> (aidi_EnKF:main():169:4) rank: 2 work_type: 0
> UNFILLED CONTAINER SUBSCRIBE <25>:__t:61[0] (aidi_EnKF:main():184:8) rank:
> 2 work_type: 0
> UNFILLED CONTAINER SUBSCRIBE <14>:float_var_names[-14]
> UNFILLED CONTAINER SUBSCRIBE <39>:ens_priors_transposed[0]
> (aidi_EnKF:params_to_priors():77:4) rank: 2 work_type: 0
> FAILED: EXIT(1)
> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> = PID 66444 RUNNING AT XioMBP.local
> = EXIT CODE: 1
> = CLEANING UP REMAINING PROCESSES
> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> ExM-user mailing list
> ExM-user at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140928/caacd6d6/attachment.html>
More information about the ExM-user
