[ExM Users] Passing two dimensional numerical arrays to leaf functions
Tim Armstrong
tim.g.armstrong at gmail.com
Wed Sep 24 13:49:44 CDT 2014
Hi Jonathan,
This looks like another bug that hadn't manifested in our tests. I've
got a fix for it and am in the process of putting together a new release.
In the meantime, you can patch the source if needed with the attached patch.
cd turbine
patch -p 5 < turbine-0.5.1-pointer-fix.patch
- Tim
On Tue, Sep 23, 2014 at 3:54 PM, Ozik, Jonathan <jozik at anl.gov> wrote:
> I’m now seeing this error regarding pointer length:
> $ turbine test-b-simple.tcl
> 0.000 MODE: WORKER
> 0.000 MODE: WORKER
> 0.000 MODE: SERVER
> 0.000 WORKERS: 2 RANKS: 0 - 1
> 0.000 SERVERS: 1 RANKS: 2 - 2
> 0.001 function:swift:constants
> 0.001 enter function: main
> 0.002 allocated u:b=<1> u:v=<2>
> 0.002 allocated file: u:data=<3>
> 0.003 store: <3>=path input.data
> 0.003 blob_read: input.data
> valgrind_assert(): failed: src/tcl/blob/blob.c:142
> valgrind_assert(): pointer is too long for int!
> Jonathan
> On Sep 23, 2014, at 11:18 AM, Tim Armstrong <tim.g.armstrong at gmail.com>
> wrote:
> Oops, one additional fix was needed:
> - proc blob_read_body { result input } {
> + proc blob_read_body { result src } {
> set val [ retrieve_decr_file $src ]
> - set input_name [ dict get $val path ]
> + set input_name [ local_file_path $val ]
> On Tue, Sep 23, 2014 at 11:08 AM, Ozik, Jonathan <jozik at anl.gov> wrote:
>> Thanks Tim!
>> On Sep 23, 2014, at 10:51 AM, Tim Armstrong <tim.g.armstrong at gmail.com>
>> wrote:
>> There's a bug in one of our library functions. Thanks for reporting.
>> I've fixed it in the repository so it'll get into the next point release.
>> If you want to quickly patch your version as a workaround, you can edit
>> line 535 of turbine/lib/files.tcl in the Swift/T source as below, then run
>> "make install" to install the fixed version of the file.
>> - Tim
>> On Tue, Sep 23, 2014 at 9:47 AM, Ozik, Jonathan <jozik at anl.gov> wrote:
>>> I’m attempting the blob example (
>>> http://swift-lang.org/Swift-T/leaf.html#_complete_example_3_c_function_with_binary_data)
>>> and am seeing this error:
>>> 0.000 MODE: SERVER
>>> 0.000 MODE: WORKER
>>> 0.000 MODE: WORKER
>>> 0.002 store: <3>=path input.data
>>> CAUGHT ERROR:
>>> can't read "src": no such variable
>>> while executing
>>> "retrieve_decr_file $src "
>>> (procedure "blob_read_body" line 2)
>>> invoked from within
>>> "blob_read_body 1 {file 3 is_mapped 0}"
>>> Turbine worker task error in: blob_read_body 1 {file 3 is_mapped 0}
>>> invoked from within
>>> "c::worker_loop $WORK_TYPE(WORK)"
>>> (procedure "worker" line 28)
>>> invoked from within
>>> "worker $rules $startup_cmd"
>>> (procedure "enter_mode_unchecked" line 5)
>>> invoked from within
>>> "enter_mode_unchecked $rules $startup_cmd"
>>> (procedure "enter_mode" line 5)
>>> invoked from within
>>> "enter_mode $rules $startup_cmd "
>>> CALLING adlb::abort
>>> ADLB_Abort(1)
>>> MPI_Abort(1)
>>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>>> It appears that this is being triggered by the line:
>>> printf("size(v) = %i", size(v));
>>> Any thoughts on what might be going on?
>>> I’m testing this on a Mac OS X setup.
>>> Jonathan
>>> On Sep 22, 2014, at 10:20 PM, Ozik, Jonathan <jozik at anl.gov> wrote:
>>> > Thank you Justin. That should work great.
>>> > Jonathan
>>> > On Sep 22, 2014, at 8:05 PM, Justin M Wozniak <wozniak at mcs.anl.gov>
>>> wrote:
>>> >> Hi
>>> >> You can do this based on the instructions for C binary data:
>>> >> The Swift blob is a void* - you can cast to whatever you want. You
>>> can cast it to a double* that is actually a 2D array (following BLAS
>>> conventions).
>>> >> Justin
>>> >> On 9/22/2014 6:32 PM, Ozik, Jonathan wrote:
>>> >>> Hello all,
>>> >>> I’m curious about how people generally go about passing (and
>>> returning) two (or n-) dimensional arrays to leaf functions. Are there
>>> simple examples using SWIG and Tcl? Or are file based approaches used via
>>> app fuctions?
>>> >>> Any thoughts would be appreciated,
>>> >>> Jonathan
>>> >>> _______________________________________________
>>> >>> ExM-user mailing list
>>> >>> ExM-user at lists.mcs.anl.gov
>>> >>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>> >> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140924/f582a5dc/attachment.html>
Type: text/x-patch
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140924/f582a5dc/attachment.bin>
More information about the ExM-user
