[ExM Users] Passing two dimensional numerical arrays to leaf functions
Tim Armstrong
tim.g.armstrong at gmail.com
Tue Sep 23 11:18:31 CDT 2014
Oops, one additional fix was needed:
- proc blob_read_body { result input } {
+ proc blob_read_body { result src } {
set val [ retrieve_decr_file $src ]
- set input_name [ dict get $val path ]
+ set input_name [ local_file_path $val ]
On Tue, Sep 23, 2014 at 11:08 AM, Ozik, Jonathan <jozik at anl.gov> wrote:
> Thanks Tim!
> On Sep 23, 2014, at 10:51 AM, Tim Armstrong <tim.g.armstrong at gmail.com>
> wrote:
> There's a bug in one of our library functions. Thanks for reporting.
> I've fixed it in the repository so it'll get into the next point release.
> If you want to quickly patch your version as a workaround, you can edit
> line 535 of turbine/lib/files.tcl in the Swift/T source as below, then run
> "make install" to install the fixed version of the file.
> - Tim
> On Tue, Sep 23, 2014 at 9:47 AM, Ozik, Jonathan <jozik at anl.gov> wrote:
>> I’m attempting the blob example (
>> http://swift-lang.org/Swift-T/leaf.html#_complete_example_3_c_function_with_binary_data)
>> and am seeing this error:
>> >> turbine test-b-simple.tcl
>> 0.000 MODE: SERVER
>> 0.000 MODE: WORKER
>> 0.000 WORKERS: 2 RANKS: 0 - 1
>> 0.000 SERVERS: 1 RANKS: 2 - 2
>> 0.000 MODE: WORKER
>> 0.001 function:swift:constants
>> 0.001 enter function: main
>> 0.002 allocated u:b=<1> u:v=<2>
>> 0.002 allocated file: u:data=<3>
>> 0.002 store: <3>=path input.data
>> CAUGHT ERROR:
>> can't read "src": no such variable
>> while executing
>> "retrieve_decr_file $src "
>> (procedure "blob_read_body" line 2)
>> invoked from within
>> "blob_read_body 1 {file 3 is_mapped 0}"
>> Turbine worker task error in: blob_read_body 1 {file 3 is_mapped 0}
>> invoked from within
>> "c::worker_loop $WORK_TYPE(WORK)"
>> (procedure "worker" line 28)
>> invoked from within
>> "worker $rules $startup_cmd"
>> (procedure "enter_mode_unchecked" line 5)
>> invoked from within
>> "enter_mode_unchecked $rules $startup_cmd"
>> (procedure "enter_mode" line 5)
>> invoked from within
>> "enter_mode $rules $startup_cmd "
>> CALLING adlb::abort
>> ADLB_Abort(1)
>> MPI_Abort(1)
>> application called MPI_Abort(MPI_COMM_WORLD, 1) - process 0
>> It appears that this is being triggered by the line:
>> printf("size(v) = %i", size(v));
>> Any thoughts on what might be going on?
>> I’m testing this on a Mac OS X setup.
>> Jonathan
>> On Sep 22, 2014, at 10:20 PM, Ozik, Jonathan <jozik at anl.gov> wrote:
>> > Thank you Justin. That should work great.
>> > Jonathan
>> > On Sep 22, 2014, at 8:05 PM, Justin M Wozniak <wozniak at mcs.anl.gov>
>> wrote:
>> >> Hi
>> >> You can do this based on the instructions for C binary data:
>> >> The Swift blob is a void* - you can cast to whatever you want. You
>> can cast it to a double* that is actually a 2D array (following BLAS
>> conventions).
>> >> Justin
>> >> On 9/22/2014 6:32 PM, Ozik, Jonathan wrote:
>> >>> Hello all,
>> >>> I’m curious about how people generally go about passing (and
>> returning) two (or n-) dimensional arrays to leaf functions. Are there
>> simple examples using SWIG and Tcl? Or are file based approaches used via
>> app fuctions?
>> >>> Any thoughts would be appreciated,
>> >>> Jonathan
>> >>> _______________________________________________
>> >>> ExM-user mailing list
>> >>> ExM-user at lists.mcs.anl.gov
>> >>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>> >> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140923/acc86f69/attachment.html>
More information about the ExM-user
