[ExM Users] Can not diagnose Swift/T script failure
    Justin M Wozniak
    wozniak at mcs.anl.gov
    Thu Oct 16 13:44:14 CDT 2014
I'm working on it.  I'm having trouble getting the modules-based cc
wrapper to compile simple things.  I'm reading posts like this one from
people with similar issues:
http://public.kitware.com/pipermail/paraview/2013-June/028679.html
On 10/16/2014 01:21 PM, Michael Wilde wrote:
> Tim, Justin, have you done the static build on Titan, and if so, has
> it resolved the problem?
> - Mike
> On 10/15/14 5:22 PM, Justin M Wozniak wrote:
>> Bisection showed that loading the Turbine so from plain Tcl breaks
>> the OS.
>> I had OLCF reset my shell to a blank bash so I can make pure use of
>> modules. I added support for this in the configuration.
>> I have been in touch with Tim today about doing a static build on the
>> Cray.
>> On October 15, 2014 4:31:50 PM CDT, Michael Wilde <wilde at anl.gov> wrote:
>>     Status as of Monday (but I know Justin did a few commits since...)
>>     -------- Forwarded Message --------
>>     Subject: 	Re: Latest on the Swift/T Titan problem?
>>     Date: 	Mon, 13 Oct 2014 16:11:31 -0500
>>     From: 	Justin M Wozniak <wozniak at mcs.anl.gov>
>>     To: 	Michael Wilde <wilde at anl.gov>
>>     Pure shell: works
>>     Pure Tcl: works
>>     ADLB batcher: works
>>     Swift/T: fails
>>     Something in Turbine breaks the OS.  I have been bisecting over a
>>     stripped-down Turbine to identify exactly what this is.  If I strip down
>>     the Turbine link step, I can get it to work.  So I think it is something
>>     in our use of Cray modules.  (I try to not use modules/softenv but it is
>>     affecting the link.)
>>     This may fix the Swift/NAMD issue, which would be a complementary
>>     positive outcome.
>>     On 10/13/2014 12:10 PM, Michael Wilde wrote:
>>     > One avenue I was wondering about for debugging:  What PrgEnv is the
>>     > Swift/T on Titan built for?
>>     > Im assuming gnu, but if so, how does that interact with the
>>     > PrgEnv-intel needed for the DISCUS app?
>>     > I would think to handle such cases we need to run Turbine under the
>>     > PrgEnv it needs, and then run any app( ) calls that needs a different
>>     > PrgEnv under a wrapper shell script that provides it, just for that
>>     > process.
>>     > Which may in turn raise the issue of whether "module load
>>     > PrgEnv-intel" for example is scalable to hundredes to tens of
>>     > thousands of concurrent invocations.
>>     > - Mike
>>     > On 10/13/14 11:38 AM, Justin M Wozniak wrote:
>>     >> Yes, I am testing launching tasks with a plain shell script and a
>>     >> plain Tcl script.  I will then move to the ADLB batcher program.
>>     >> On 10/13/2014 11:34 AM, Michael Wilde wrote:
>>     >>> Hi Justin,
>>     >>> I did not get to spend any time on this over the weekend.
>>     >>> What is your latest assessment of the issue?
>>     >>> I did some runs Fri night that were disturbing: two runs of 256
>>     >>> sleeps on 128 cores, each yielding a different number of output
>>     >>> files (but missing ~ 5 in one case and ~ 10 in the other).
>>     >>> I was going to do a test of a simple MPI app forking tasks with
>>     >>> system( ), to see if same failure pattern is seen or not, as #CPUs
>>     >>> increases from 128 to 1024.
>>     Justin M Wozniak
>>     On 10/15/14 4:29 PM, Michael Wilde wrote:
>>>     Justin, can you report on your latest findings on this?
>>>     (I will fwd Justin's latest notes from Monday...)
>>>     - Mike
>>>     On 10/15/14 4:27 PM, Tim Armstrong wrote:
>>>>     Did you reach a resolution on this?  I'm back in town now and
>>>>     could look at adding the ability to retrieve the exit code.
>>>>     - Tim
>>>>     On Fri, Oct 3, 2014 at 12:07 AM, Michael Wilde <wilde at anl.gov
>>>>     <mailto:wilde at anl.gov>> wrote:
>>>>         Also: identical code seems to run fine at this setting:
>>>>           PPN=16 turbine-cray-run.zsh -s titan.settings -n 64 $tcl
>>>>         # (4 nodes)
>>>>         but fails at this setting:
>>>>           PPN=16 turbine-cray-run.zsh -s titan.settings -n 128 $tcl
>>>>         # (8 nodes)
>>>>         Changing the app that calls DISCUS directly back to a shell
>>>>         wrapper around DISCUS shows that when the job  fails the
>>>>         app (shell wrapper) is indeed executed, and logs a message
>>>>         to the app stdout file which I see. But I dont see a
>>>>         message after DISCUS.
>>>>         To test if perhaps many concurrent DISCUS invocations (127)
>>>>         are causing a problem which is fatal to the whole job, I
>>>>         added a random sleep before DISCUS.  This had no effect on
>>>>         the problem.
>>>>         Next I eliminated the actual DISCUS call, and just did a
>>>>         random sleep from 0 to 9 seconds. Here I discovered that
>>>>         all the jobs with sleep > 0 failed in the same manner as
>>>>         with discus, while the sleep 0 cases all printed all their
>>>>         echos and exited.
>>>>         So there is something more deeply wrong going on, having
>>>>         nothing to do with the DISCUS app. I'll try to narrow this
>>>>         down, and see if perhaps its happening on other non-Cray
>>>>         systems like Midway.
>>>>         - Mike
>>>>         On 10/2/14 10:52 PM, Michael Wilde wrote:
>>>>>         Thanks, Tim. But, stderr and stdout were both redirected
>>>>>         to files, and all .err and .out files are empty.
>>>>>         I'll double-check that these redirects are working, but in
>>>>>         prior runs, I did indeed get app error and output in those
>>>>>         files.
>>>>>         It looks more to me like the app is failing to launch.
>>>>>         - Mike
>>>>>         On 10/2/14 10:22 PM, Tim Armstrong wrote:
>>>>>>         The app stderr/stdout should go to Swift/T stderr/stdout
>>>>>>         unless redirected.  The problem is most likely discus
>>>>>>         returning a non-zero error code.
>>>>>>         - Tim
>>>>>>         On Thu, Oct 2, 2014 at 8:42 PM, Michael Wilde
>>>>>>         <wilde at anl.gov <mailto:wilde at anl.gov>> wrote:
>>>>>>             Im getting a failure from a Swift/T run on Titan that
>>>>>>             I cant diagnose.
>>>>>>             The script is running 16K DISCUS simulations, about
>>>>>>             30 secs each, 16 per node, on 8 nodes. 127 workers, 1
>>>>>>             Server. It seems to run well at smaller scale (eg 1K
>>>>>>             simulations).
>>>>>>             My PBS output file shows that some of the initial
>>>>>>             round of simulations fail.  It seems that when this
>>>>>>             happens, the Swift script exits within the first
>>>>>>             round of simulations, and none seem to even start.
>>>>>>             Some of the logs are below.  I'll continue to
>>>>>>             experiment and add more logging to try to isolate the
>>>>>>             cause.
>>>>>>             I was initially suspicious of an OOM problem, but I
>>>>>>             dont see any sign of that.
>>>>>>             In the line below "Swift: external command failed:
>>>>>>             /lustre/atlas/proj-shared/mat049/scu/build/DiffuseCode/titan/discus/prog/discus
>>>>>>             --macro ../stacking-faults3.mac 0.004 0.264 1 0.75
>>>>>>             ../Si.cll 0.004_0.264.inte 0.004_0.264.stru" - is
>>>>>>             there a way to tell what Swift things the exit status
>>>>>>             of these failing apps are?  What is causing the whole
>>>>>>             run to abort?
>>>>>>             It almost looks like one app, or a small number of
>>>>>>             them, are generating a SIGABRT, but thats not clear,
>>>>>>             and I have no stdout/err info from the app processes.
>>>>>>             I'll look for some more detailed debug options,
>>>>>>             and/or add some wrappers around the apps.
>>>>>>             Thanks,
>>>>>>             - Mike
>>>>>>             T$ cat output.txt.2115044.out
>>>>>>             Swift: killing MPI job...
>>>>>>             ADLB_Abort(1)
>>>>>>             MPI_Abort(1)
>>>>>>             --macro ../stacking-faults3.mac 0.004 0.272 1 0.75
>>>>>>             ../Si.cll 0.004_0.272.inte 0.004_0.272.stru
>>>>>>             ADLB_Abort(1)
>>>>>>             MPI_Abort(1)
>>>>>>             --macro ../stacking-faults3.mac 0.26
>>>>>>             0.052000000000000005 1 0.75 ../Si.cll
>>>>>>             0.260_0.052.inte 0.260_0.052.stru
>>>>>>             ADLB_Abort(1)
>>>>>>             MPI_Abort(1)
>>>>>>             --macro ../stacking-faults3.mac 0.004 0.084 1 0.75
>>>>>>             ../Si.cll 0.004_0.084.inte 0.004_0.084.stru
>>>>>>             ADLB_Abort(1)
>>>>>>             MPI_Abort(1)
>>>>>>             --macro ../stacking-faults3.mac 0.26 0.024 1 0.75
>>>>>>             ../Si.cll 0.260_0.024.inte 0.260_0.024.stru
>>>>>>             ADLB_Abort(1)
>>>>>>             MPI_Abort(1)
>>>>>>             --macro ../stacking-faults3.mac 0.004 0.056 1 0.75
>>>>>>             ../Si.cll 0.004_0.056.inte 0.004_0.056.stru
>>>>>>             ADLB_Abort(1)
>>>>>>             MPI_Abort(1)
>>>>>>             --macro ../stacking-faults3.mac 0.004 0.364 1 0.75
>>>>>>             ../Si.cll 0.004_0.364.inte 0.004_0.364.stru
>>>>>>             ADLB_Abort(1)
>>>>>>             MPI_Abort(1)
>>>>>>             0.07200000000000001 1 0.75 ../Si.cll 0.004_0.072.inte
>>>>>>             0.004_0.072.stru
>>>>>>             ADLB_Abort(1)
>>>>>>             MPI_Abort(1)
>>>>>>             --macro ../stacking-faults3.mac 0.26 0.044 1 0.75
>>>>>>             ../Si.cll 0.260_0.044.inte 0.260_0.044.stru
>>>>>>             ADLB_Abort(1)
>>>>>>             MPI_Abort(1)
>>>>>>             Application 7706378 exit codes: 134
>>>>>>             Application 7706378 exit signals: Killed
>>>>>>             Application 7706378 resources: utime ~5s, stime ~19s,
>>>>>>             Rss ~11016, inblocks ~48986, outblocks ~205
>>>>>>             T$
>>>>>>             T$ cat output.txt
>>>>>>             bash_profile: loading modules
>>>>>>             DB /ccs/home/wildemj/.modules: loading modules...
>>>>>>             Turbine: turbine-aprun.sh
>>>>>>             10/02/2014 09:15PM
>>>>>>             TURBINE_HOME:
>>>>>>             /lustre/atlas2/mat049/proj-shared/sfw/compute/turbine
>>>>>>             SCRIPT:
>>>>>>             /lustre/atlas2/mat049/proj-shared/wildemj/swift-discus/stacking-faults3.tcl
>>>>>>             PROCS:        128
>>>>>>             NODES:        8
>>>>>>             PPN:          16
>>>>>>             WALLTIME:     00:15:00
>>>>>>             TURBINE_WORKERS: 127
>>>>>>             ADLB_SERVERS:    1
>>>>>>             TCLSH:
>>>>>>             /lustre/atlas2/mat049/proj-shared/sfw/tcl-8.6.2/bin/tclsh8.6
>>>>>>             JOB OUTPUT:
>>>>>>             Rank 2 [Thu Oct  2 21:15:32 2014] [c12-0c1s1n3]
>>>>>>             application called MPI_Abort(MPI_COMM_WORLD, 1) -
>>>>>>             process 2
>>>>>>             Rank 4 [Thu Oct  2 21:15:32 2014] [c14-0c1s1n3]
>>>>>>             process 4
>>>>>>             Rank 6 [Thu Oct  2 21:15:32 2014] [c14-0c1s1n1]
>>>>>>             process 6
>>>>>>             Rank 3 [Thu Oct  2 21:15:32 2014] [c14-0c1s1n2]
>>>>>>             process 3
>>>>>>             Rank 5 [Thu Oct  2 21:15:32 2014] [c14-0c1s1n0]
>>>>>>             process 5
>>>>>>             Rank 1 [Thu Oct  2 21:15:32 2014] [c12-0c1s1n2]
>>>>>>             process 1
>>>>>>             Rank 7 [Thu Oct  2 21:15:32 2014] [c14-0c1s0n0]
>>>>>>             process 7
>>>>>>             _pmiu_daemon(SIGCHLD): [NID 06114] [c14-0c1s1n0] [Thu
>>>>>>             Oct  2 21:15:32 2014] PE RANK 5 exit signal Aborted
>>>>>>             _pmiu_daemon(SIGCHLD): [NID 06076] [c14-0c1s1n2] [Thu
>>>>>>             Oct  2 21:15:32 2014] PE RANK 3 exit signal Aborted
>>>>>>             _pmiu_daemon(SIGCHLD): [NID 06077] [c14-0c1s1n3] [Thu
>>>>>>             Oct  2 21:15:32 2014] PE RANK 4 exit signal Aborted
>>>>>>             _pmiu_daemon(SIGCHLD): [NID 04675] [c12-0c1s1n3] [Thu
>>>>>>             Oct  2 21:15:32 2014] PE RANK 2 exit signal Aborted
>>>>>>             [NID 04675] 2014-10-02 21:15:32 Apid 7706378:
>>>>>>             initiated application termination
>>>>>>             _pmiu_daemon(SIGCHLD): [NID 06115] [c14-0c1s1n1] [Thu
>>>>>>             Oct  2 21:15:32 2014] PE RANK 6 exit signal Aborted
>>>>>>             T$
>>>>>>             T$
>>>>>>             T$
>>>>>>             T$ cat turbine.log
>>>>>>             JOB:               2115044
>>>>>>             COMMAND:  stacking-faults3.tcl
>>>>>>             HOSTNAME: ccs.ornl.gov <http://ccs.ornl.gov>
>>>>>>             SUBMITTED:         10/02/2014 09:14PM
>>>>>>             PROCS:             128
>>>>>>             PPN:               16
>>>>>>             NODES:             8
>>>>>>             TURBINE_WORKERS:
>>>>>>             ADLB_SERVERS:
>>>>>>             WALLTIME:          00:15:00
>>>>>>             ADLB_EXHAUST_TIME:
>>>>>>             T$
>>>>>>             Michael Wilde
>>>>>>             Mathematics and Computer Science          Computation
>>>>>>             Institute
>>>>>>             Argonne National Laboratory            The University
>>>>>>             of Chicago
>>>>>>             _______________________________________________
>>>>>>             ExM-user mailing list
>>>>>>             ExM-user at lists.mcs.anl.gov
>>>>>>             <mailto:ExM-user at lists.mcs.anl.gov>
>>>>>>             https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>>>>>         ExM-user at lists.mcs.anl.gov  <mailto:ExM-user at lists.mcs.anl.gov>
>>>>>         Michael Wilde
>>>>>         Mathematics and Computer Science          Computation Institute
>>>>>         Argonne National Laboratory               The University of Chicago
>>>>         Michael Wilde
>>>     Michael Wilde
>>     Michael Wilde
>> Justin M Wozniak (via phone)
> Michael Wilde
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20141016/a0b2777d/attachment-0001.html>
More information about the ExM-user
