[ExM Users] Can not diagnose Swift/T script failure
Justin M Wozniak
wozniak at mcs.anl.gov
Wed Oct 15 17:22:10 CDT 2014
Bisection showed that loading the Turbine so from plain Tcl breaks the OS.
I had OLCF reset my shell to a blank bash so I can make pure use of modules. I added support for this in the configuration.
I have been in touch with Tim today about doing a static build on the Cray.
On October 15, 2014 4:31:50 PM CDT, Michael Wilde <wilde at anl.gov> wrote:
>Status as of Monday (but I know Justin did a few commits since...)
>-------- Forwarded Message --------
>Subject: Re: Latest on the Swift/T Titan problem?
>Date: Mon, 13 Oct 2014 16:11:31 -0500
>From: Justin M Wozniak <wozniak at mcs.anl.gov>
>To: Michael Wilde <wilde at anl.gov>
>Pure shell: works
>Pure Tcl: works
>ADLB batcher: works
>Swift/T: fails
>Something in Turbine breaks the OS. I have been bisecting over a
>stripped-down Turbine to identify exactly what this is. If I strip
>down
>the Turbine link step, I can get it to work. So I think it is
>something
>in our use of Cray modules. (I try to not use modules/softenv but it
>is
>affecting the link.)
>This may fix the Swift/NAMD issue, which would be a complementary
>positive outcome.
>On 10/13/2014 12:10 PM, Michael Wilde wrote:
>> One avenue I was wondering about for debugging: What PrgEnv is the
>> Swift/T on Titan built for?
>> Im assuming gnu, but if so, how does that interact with the
>> PrgEnv-intel needed for the DISCUS app?
>> I would think to handle such cases we need to run Turbine under the
>> PrgEnv it needs, and then run any app( ) calls that needs a different
>> PrgEnv under a wrapper shell script that provides it, just for that
>> process.
>> Which may in turn raise the issue of whether "module load
>> PrgEnv-intel" for example is scalable to hundredes to tens of
>> thousands of concurrent invocations.
>> - Mike
>> On 10/13/14 11:38 AM, Justin M Wozniak wrote:
>>> Yes, I am testing launching tasks with a plain shell script and a
>>> plain Tcl script. I will then move to the ADLB batcher program.
>>> On 10/13/2014 11:34 AM, Michael Wilde wrote:
>>>> Hi Justin,
>>>> I did not get to spend any time on this over the weekend.
>>>> What is your latest assessment of the issue?
>>>> I did some runs Fri night that were disturbing: two runs of 256
>>>> sleeps on 128 cores, each yielding a different number of output
>>>> files (but missing ~ 5 in one case and ~ 10 in the other).
>>>> I was going to do a test of a simple MPI app forking tasks with
>>>> system( ), to see if same failure pattern is seen or not, as #CPUs
>>>> increases from 128 to 1024.
>Justin M Wozniak
>On 10/15/14 4:29 PM, Michael Wilde wrote:
>> Justin, can you report on your latest findings on this?
>> (I will fwd Justin's latest notes from Monday...)
>> - Mike
>> On 10/15/14 4:27 PM, Tim Armstrong wrote:
>>> Did you reach a resolution on this? I'm back in town now and could
>>> look at adding the ability to retrieve the exit code.
>>> - Tim
>>> On Fri, Oct 3, 2014 at 12:07 AM, Michael Wilde <wilde at anl.gov
>>> <mailto:wilde at anl.gov>> wrote:
>>> Also: identical code seems to run fine at this setting:
>>> PPN=16 turbine-cray-run.zsh -s titan.settings -n 64 $tcl # (4
>>> nodes)
>>> but fails at this setting:
>>> PPN=16 turbine-cray-run.zsh -s titan.settings -n 128 $tcl # (8
>>> nodes)
>>> Changing the app that calls DISCUS directly back to a shell
>>> wrapper around DISCUS shows that when the job fails the app
>>> (shell wrapper) is indeed executed, and logs a message to the
>app
>>> stdout file which I see. But I dont see a message after DISCUS.
>>> To test if perhaps many concurrent DISCUS invocations (127) are
>>> causing a problem which is fatal to the whole job, I added a
>>> random sleep before DISCUS. This had no effect on the problem.
>>> Next I eliminated the actual DISCUS call, and just did a random
>>> sleep from 0 to 9 seconds. Here I discovered that all the jobs
>>> with sleep > 0 failed in the same manner as with discus, while
>>> the sleep 0 cases all printed all their echos and exited.
>>> So there is something more deeply wrong going on, having nothing
>>> to do with the DISCUS app. I'll try to narrow this down, and see
>>> if perhaps its happening on other non-Cray systems like Midway.
>>> - Mike
>>> On 10/2/14 10:52 PM, Michael Wilde wrote:
>>>> Thanks, Tim. But, stderr and stdout were both redirected to
>>>> files, and all .err and .out files are empty.
>>>> I'll double-check that these redirects are working, but in
>prior
>>>> runs, I did indeed get app error and output in those files.
>>>> It looks more to me like the app is failing to launch.
>>>> - Mike
>>>> On 10/2/14 10:22 PM, Tim Armstrong wrote:
>>>>> The app stderr/stdout should go to Swift/T stderr/stdout
>unless
>>>>> redirected. The problem is most likely discus returning a
>>>>> non-zero error code.
>>>>> - Tim
>>>>> On Thu, Oct 2, 2014 at 8:42 PM, Michael Wilde <wilde at anl.gov
>>>>> Im getting a failure from a Swift/T run on Titan that I
>>>>> cant diagnose.
>>>>> The script is running 16K DISCUS simulations, about 30
>secs
>>>>> each, 16 per node, on 8 nodes. 127 workers, 1 Server. It
>>>>> seems to run well at smaller scale (eg 1K simulations).
>>>>> My PBS output file shows that some of the initial round of
>>>>> simulations fail. It seems that when this happens, the
>>>>> Swift script exits within the first round of simulations,
>>>>> and none seem to even start.
>>>>> Some of the logs are below. I'll continue to experiment
>>>>> and add more logging to try to isolate the cause.
>>>>> I was initially suspicious of an OOM problem, but I dont
>>>>> see any sign of that.
>>>>> In the line below "Swift: external command failed:
>/lustre/atlas/proj-shared/mat049/scu/build/DiffuseCode/titan/discus/prog/discus
>>>>> --macro ../stacking-faults3.mac 0.004 0.264 1 0.75
>>>>> ../Si.cll 0.004_0.264.inte 0.004_0.264.stru" - is there a
>>>>> way to tell what Swift things the exit status of these
>>>>> failing apps are? What is causing the whole run to abort?
>>>>> It almost looks like one app, or a small number of them,
>>>>> are generating a SIGABRT, but thats not clear, and I have
>>>>> no stdout/err info from the app processes.
>>>>> I'll look for some more detailed debug options, and/or add
>>>>> some wrappers around the apps.
>>>>> Thanks,
>>>>> - Mike
>>>>> T$ cat output.txt.2115044.out
>>>>> Swift: killing MPI job...
>>>>> ADLB_Abort(1)
>>>>> MPI_Abort(1)
>>>>> --macro ../stacking-faults3.mac 0.004 0.272 1 0.75
>>>>> ../Si.cll 0.004_0.272.inte 0.004_0.272.stru
>>>>> ADLB_Abort(1)
>>>>> MPI_Abort(1)
>>>>> --macro ../stacking-faults3.mac 0.26 0.052000000000000005
>1
>>>>> 0.75 ../Si.cll 0.260_0.052.inte 0.260_0.052.stru
>>>>> ADLB_Abort(1)
>>>>> MPI_Abort(1)
>>>>> --macro ../stacking-faults3.mac 0.004 0.084 1 0.75
>>>>> ../Si.cll 0.004_0.084.inte 0.004_0.084.stru
>>>>> ADLB_Abort(1)
>>>>> MPI_Abort(1)
>>>>> --macro ../stacking-faults3.mac 0.26 0.024 1 0.75
>../Si.cll
>>>>> 0.260_0.024.inte 0.260_0.024.stru
>>>>> ADLB_Abort(1)
>>>>> MPI_Abort(1)
>>>>> --macro ../stacking-faults3.mac 0.004 0.056 1 0.75
>>>>> ../Si.cll 0.004_0.056.inte 0.004_0.056.stru
>>>>> ADLB_Abort(1)
>>>>> MPI_Abort(1)
>>>>> --macro ../stacking-faults3.mac 0.004 0.364 1 0.75
>>>>> ../Si.cll 0.004_0.364.inte 0.004_0.364.stru
>>>>> ADLB_Abort(1)
>>>>> MPI_Abort(1)
>>>>> --macro ../stacking-faults3.mac 0.004 0.07200000000000001
>1
>>>>> 0.75 ../Si.cll 0.004_0.072.inte 0.004_0.072.stru
>>>>> ADLB_Abort(1)
>>>>> MPI_Abort(1)
>>>>> --macro ../stacking-faults3.mac 0.26 0.044 1 0.75
>../Si.cll
>>>>> 0.260_0.044.inte 0.260_0.044.stru
>>>>> ADLB_Abort(1)
>>>>> MPI_Abort(1)
>>>>> Application 7706378 exit codes: 134
>>>>> Application 7706378 exit signals: Killed
>>>>> Application 7706378 resources: utime ~5s, stime ~19s, Rss
>>>>> ~11016, inblocks ~48986, outblocks ~205
>>>>> T$
>>>>> T$ cat output.txt
>>>>> bash_profile: loading modules
>>>>> DB /ccs/home/wildemj/.modules: loading modules...
>>>>> Turbine: turbine-aprun.sh
>>>>> 10/02/2014 09:15PM
>>>>> TURBINE_HOME:
>>>>> /lustre/atlas2/mat049/proj-shared/sfw/compute/turbine
>>>>> SCRIPT:
>/lustre/atlas2/mat049/proj-shared/wildemj/swift-discus/stacking-faults3.tcl
>>>>> PROCS: 128
>>>>> NODES: 8
>>>>> PPN: 16
>>>>> WALLTIME: 00:15:00
>>>>> TURBINE_WORKERS: 127
>>>>> ADLB_SERVERS: 1
>>>>> TCLSH:
>/lustre/atlas2/mat049/proj-shared/sfw/tcl-8.6.2/bin/tclsh8.6
>>>>> JOB OUTPUT:
>>>>> Rank 2 [Thu Oct 2 21:15:32 2014] [c12-0c1s1n3]
>application
>>>>> called MPI_Abort(MPI_COMM_WORLD, 1) - process 2
>>>>> Rank 4 [Thu Oct 2 21:15:32 2014] [c14-0c1s1n3]
>application
>>>>> called MPI_Abort(MPI_COMM_WORLD, 1) - process 4
>>>>> Rank 6 [Thu Oct 2 21:15:32 2014] [c14-0c1s1n1]
>application
>>>>> called MPI_Abort(MPI_COMM_WORLD, 1) - process 6
>>>>> Rank 3 [Thu Oct 2 21:15:32 2014] [c14-0c1s1n2]
>application
>>>>> called MPI_Abort(MPI_COMM_WORLD, 1) - process 3
>>>>> Rank 5 [Thu Oct 2 21:15:32 2014] [c14-0c1s1n0]
>application
>>>>> called MPI_Abort(MPI_COMM_WORLD, 1) - process 5
>>>>> Rank 1 [Thu Oct 2 21:15:32 2014] [c12-0c1s1n2]
>application
>>>>> called MPI_Abort(MPI_COMM_WORLD, 1) - process 1
>>>>> Rank 7 [Thu Oct 2 21:15:32 2014] [c14-0c1s0n0]
>application
>>>>> called MPI_Abort(MPI_COMM_WORLD, 1) - process 7
>>>>> _pmiu_daemon(SIGCHLD): [NID 06114] [c14-0c1s1n0] [Thu Oct
>>>>> 2 21:15:32 2014] PE RANK 5 exit signal Aborted
>>>>> _pmiu_daemon(SIGCHLD): [NID 06076] [c14-0c1s1n2] [Thu Oct
>>>>> 2 21:15:32 2014] PE RANK 3 exit signal Aborted
>>>>> _pmiu_daemon(SIGCHLD): [NID 06077] [c14-0c1s1n3] [Thu Oct
>>>>> 2 21:15:32 2014] PE RANK 4 exit signal Aborted
>>>>> _pmiu_daemon(SIGCHLD): [NID 04675] [c12-0c1s1n3] [Thu Oct
>>>>> 2 21:15:32 2014] PE RANK 2 exit signal Aborted
>>>>> [NID 04675] 2014-10-02 21:15:32 Apid 7706378: initiated
>>>>> application termination
>>>>> _pmiu_daemon(SIGCHLD): [NID 06115] [c14-0c1s1n1] [Thu Oct
>>>>> 2 21:15:32 2014] PE RANK 6 exit signal Aborted
>>>>> T$
>>>>> T$
>>>>> T$
>>>>> T$ cat turbine.log
>>>>> JOB: 2115044
>>>>> COMMAND: stacking-faults3.tcl
>>>>> HOSTNAME: ccs.ornl.gov <http://ccs.ornl.gov>
>>>>> SUBMITTED: 10/02/2014 09:14PM
>>>>> PROCS: 128
>>>>> PPN: 16
>>>>> NODES: 8
>>>>> TURBINE_WORKERS:
>>>>> ADLB_SERVERS:
>>>>> WALLTIME: 00:15:00
>>>>> ADLB_EXHAUST_TIME:
>>>>> T$
>>>>> Michael Wilde
>>>>> Mathematics and Computer Science Computation Institute
>>>>> Argonne National Laboratory The University of Chicago
>>>>> _______________________________________________
>>>>> ExM-user mailing list
>>>>> ExM-user at lists.mcs.anl.gov
><mailto:ExM-user at lists.mcs.anl.gov>
>>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>>> Michael Wilde
>Chicago
>>> Michael Wilde
>Chicago
>>> ExM-user at lists.mcs.anl.gov <mailto:ExM-user at lists.mcs.anl.gov>
>> Michael Wilde
>Michael Wilde
Justin M Wozniak (via phone)
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20141015/22a6cfc9/attachment-0001.html>
More information about the ExM-user
