[ExM Users] Can not diagnose Swift/T script failure
Michael Wilde
wilde at anl.gov
Thu Oct 2 22:52:57 CDT 2014
Thanks, Tim. But, stderr and stdout were both redirected to files, and
all .err and .out files are empty.
I'll double-check that these redirects are working, but in prior runs, I
did indeed get app error and output in those files.
It looks more to me like the app is failing to launch.
- Mike
On 10/2/14 10:22 PM, Tim Armstrong wrote:
> The app stderr/stdout should go to Swift/T stderr/stdout unless
> redirected. The problem is most likely discus returning a non-zero
> error code.
> - Tim
> On Thu, Oct 2, 2014 at 8:42 PM, Michael Wilde <wilde at anl.gov
> <mailto:wilde at anl.gov>> wrote:
> Im getting a failure from a Swift/T run on Titan that I cant diagnose.
> The script is running 16K DISCUS simulations, about 30 secs each,
> 16 per node, on 8 nodes. 127 workers, 1 Server. It seems to run
> well at smaller scale (eg 1K simulations).
> My PBS output file shows that some of the initial round of
> simulations fail. It seems that when this happens, the Swift
> script exits within the first round of simulations, and none seem
> to even start.
> Some of the logs are below. I'll continue to experiment and add
> more logging to try to isolate the cause.
> I was initially suspicious of an OOM problem, but I dont see any
> sign of that.
> In the line below "Swift: external command failed:
> /lustre/atlas/proj-shared/mat049/scu/build/DiffuseCode/titan/discus/prog/discus
> --macro ../stacking-faults3.mac 0.004 0.264 1 0.75 ../Si.cll
> 0.004_0.264.inte 0.004_0.264.stru" - is there a way to tell what
> Swift things the exit status of these failing apps are? What is
> causing the whole run to abort?
> It almost looks like one app, or a small number of them, are
> generating a SIGABRT, but thats not clear, and I have no
> stdout/err info from the app processes.
> I'll look for some more detailed debug options, and/or add some
> wrappers around the apps.
> Thanks,
> - Mike
> T$ cat output.txt.2115044.out
> Swift: killing MPI job...
> ADLB_Abort(1)
> MPI_Abort(1)
> --macro ../stacking-faults3.mac 0.004 0.272 1 0.75 ../Si.cll
> 0.004_0.272.inte 0.004_0.272.stru
> ADLB_Abort(1)
> MPI_Abort(1)
> --macro ../stacking-faults3.mac 0.26 0.052000000000000005 1 0.75
> ../Si.cll 0.260_0.052.inte 0.260_0.052.stru
> ADLB_Abort(1)
> MPI_Abort(1)
> --macro ../stacking-faults3.mac 0.004 0.084 1 0.75 ../Si.cll
> 0.004_0.084.inte 0.004_0.084.stru
> ADLB_Abort(1)
> MPI_Abort(1)
> --macro ../stacking-faults3.mac 0.26 0.024 1 0.75 ../Si.cll
> 0.260_0.024.inte 0.260_0.024.stru
> ADLB_Abort(1)
> MPI_Abort(1)
> --macro ../stacking-faults3.mac 0.004 0.056 1 0.75 ../Si.cll
> 0.004_0.056.inte 0.004_0.056.stru
> ADLB_Abort(1)
> MPI_Abort(1)
> --macro ../stacking-faults3.mac 0.004 0.364 1 0.75 ../Si.cll
> 0.004_0.364.inte 0.004_0.364.stru
> ADLB_Abort(1)
> MPI_Abort(1)
> --macro ../stacking-faults3.mac 0.004 0.07200000000000001 1 0.75
> ../Si.cll 0.004_0.072.inte 0.004_0.072.stru
> ADLB_Abort(1)
> MPI_Abort(1)
> --macro ../stacking-faults3.mac 0.26 0.044 1 0.75 ../Si.cll
> 0.260_0.044.inte 0.260_0.044.stru
> ADLB_Abort(1)
> MPI_Abort(1)
> Application 7706378 exit codes: 134
> Application 7706378 exit signals: Killed
> Application 7706378 resources: utime ~5s, stime ~19s, Rss ~11016,
> inblocks ~48986, outblocks ~205
> T$
> T$ cat output.txt
> bash_profile: loading modules
> DB /ccs/home/wildemj/.modules: loading modules...
> Turbine: turbine-aprun.sh
> 10/02/2014 09:15PM
> TURBINE_HOME: /lustre/atlas2/mat049/proj-shared/sfw/compute/turbine
> SCRIPT:
> /lustre/atlas2/mat049/proj-shared/wildemj/swift-discus/stacking-faults3.tcl
> PROCS: 128
> NODES: 8
> PPN: 16
> WALLTIME: 00:15:00
> TURBINE_WORKERS: 127
> ADLB_SERVERS: 1
> TCLSH: /lustre/atlas2/mat049/proj-shared/sfw/tcl-8.6.2/bin/tclsh8.6
> JOB OUTPUT:
> Rank 2 [Thu Oct 2 21:15:32 2014] [c12-0c1s1n3] application called
> MPI_Abort(MPI_COMM_WORLD, 1) - process 2
> Rank 4 [Thu Oct 2 21:15:32 2014] [c14-0c1s1n3] application called
> MPI_Abort(MPI_COMM_WORLD, 1) - process 4
> Rank 6 [Thu Oct 2 21:15:32 2014] [c14-0c1s1n1] application called
> MPI_Abort(MPI_COMM_WORLD, 1) - process 6
> Rank 3 [Thu Oct 2 21:15:32 2014] [c14-0c1s1n2] application called
> MPI_Abort(MPI_COMM_WORLD, 1) - process 3
> Rank 5 [Thu Oct 2 21:15:32 2014] [c14-0c1s1n0] application called
> MPI_Abort(MPI_COMM_WORLD, 1) - process 5
> Rank 1 [Thu Oct 2 21:15:32 2014] [c12-0c1s1n2] application called
> MPI_Abort(MPI_COMM_WORLD, 1) - process 1
> Rank 7 [Thu Oct 2 21:15:32 2014] [c14-0c1s0n0] application called
> MPI_Abort(MPI_COMM_WORLD, 1) - process 7
> _pmiu_daemon(SIGCHLD): [NID 06114] [c14-0c1s1n0] [Thu Oct 2
> 21:15:32 2014] PE RANK 5 exit signal Aborted
> _pmiu_daemon(SIGCHLD): [NID 06076] [c14-0c1s1n2] [Thu Oct 2
> 21:15:32 2014] PE RANK 3 exit signal Aborted
> _pmiu_daemon(SIGCHLD): [NID 06077] [c14-0c1s1n3] [Thu Oct 2
> 21:15:32 2014] PE RANK 4 exit signal Aborted
> _pmiu_daemon(SIGCHLD): [NID 04675] [c12-0c1s1n3] [Thu Oct 2
> 21:15:32 2014] PE RANK 2 exit signal Aborted
> [NID 04675] 2014-10-02 21:15:32 Apid 7706378: initiated
> application termination
> _pmiu_daemon(SIGCHLD): [NID 06115] [c14-0c1s1n1] [Thu Oct 2
> 21:15:32 2014] PE RANK 6 exit signal Aborted
> T$
> T$
> T$
> T$ cat turbine.log
> JOB: 2115044
> COMMAND: stacking-faults3.tcl
> HOSTNAME: ccs.ornl.gov <http://ccs.ornl.gov>
> SUBMITTED: 10/02/2014 09:14PM
> PROCS: 128
> PPN: 16
> NODES: 8
> TURBINE_WORKERS:
> ADLB_SERVERS:
> WALLTIME: 00:15:00
> ADLB_EXHAUST_TIME:
> T$
> Michael Wilde
> Mathematics and Computer Science Computation Institute
> Argonne National Laboratory The University of Chicago
> ExM-user mailing list
> ExM-user at lists.mcs.anl.gov <mailto:ExM-user at lists.mcs.anl.gov>
> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
Michael Wilde
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20141002/07ff455c/attachment-0001.html>
More information about the ExM-user
