[ExM Users] mkstatic questions
Tim Armstrong tim.g.armstrong at gmail.com
Thu May 29 12:03:53 CDT 2014
Yeah, with static linking it wants everything to be available as a .a
archive.  It's a pain, since if you're static linking, everything needs to
be static, but if you're using any dynamic linking, it defaults to using
the .so and it's difficult to override.
- Tim
On Thu, May 29, 2014 at 10:11 AM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
> I just fixed the perms on libtclturbine.a
> For Tcl, there is currently no static archive in that directory- I will
> try to make one.
> On 05/29/2014 09:59 AM, Ketan Maheshwari wrote:
> Thanks! Trying to link with the following:
>  /soft/compilers/wrappers/xl/mpixlcxx -o static_leaf_main
> static_leaf_main.o /home/ketan/rosetta/flexpep_docking/leaf_main.a \
>  -pg -qsmp=omp -g -O0 -qarch=qp -qtune=qp -qhot
> -Wl,--allow-multiple-definition \
>  /projects/ExM/ketan/openmp-gnu-july16-mini/build/src/debug/linux/2.6/64/ppc64/xlc/static-mpi/apps/public/flexpep_docking/FlexPepDocking.o
>  -L$TCL_HOME/lib -L$TURBINE_HOME/lib
> -L/projects/ExM/ketan/openmp-gnu-july16-mini/external/lib \
>  -L/projects/ExM/ketan/openmp-gnu-july16-mini/build/src/debug/linux/2.6/64/ppc64/xlc/static-mpi
>  -Lsrc
> -L/projects/ExM/ketan/openmp-gnu-july16-mini/build/external/debug/linux/2.6/64/ppc64/xlc/static-mpi
>  -Lexternal -L/home/vsachde/ROSETTA/zlib/lib -ldevel -lprotocols.7
> -lprotocols.6 -lprotocols_f.5 -lprotocols_e.5 \
>  -lprotocols_d.5 -lprotocols_c.5 -lprotocols_b.5 -lprotocols_a.5
> -lprotocols_h.4 -lprotocols_g.4 -lprotocols_f.4 \
>  -lprotocols_e.4 -lprotocols_d.4 -lprotocols_c.4 -lprotocols_b.4
> -lprotocols_a.4 -lprotocols.3 -lprotocols_b.2 \
>  -lprotocols_a.2 -lprotocols.1 -lcore.5 -lcore.4 -lcore.3 -lcore.2
> -lcore.1 -lbasic -lnumeric -lutility -lObjexxFCL \
>  -lz -lcppdb -lsqlite3 -lz -ltclstub8.5 -ltcl8.5 -ltclturbine
> -ltclturbinestatic -ltclturbinestaticres
>  Getting the error message:
>  /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld: cannot
> find -ltcl8.5
> /bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld: cannot find
> -ltclturbine
>  $TCL_HOME is /home/wozniak/Public/sfw/ppc64/tcl-8.5.12
> $TURBINE_HOME is /home/wozniak/Public/sfw/ppc64/turbine/lib
>  and the libs that ld is complaining about does seem to be available at
> the above locations. Any suggestions?
>  Thanks,
> Ketan
> On Thu, May 29, 2014 at 9:09 AM, Tim Armstrong <tim.g.armstrong at gmail.com>wrote:
>>  Forgot to send this to the list.
>>  On Thu, May 29, 2014 at 8:06 AM, Tim Armstrong <
>> tim.g.armstrong at gmail.com> wrote:
>>>   Another thing I should mention is that you can source the
>>> turbine-build-config,sh script under turbine to get many of the variables
>>> you need e.g. install dirs, tcl version, linker flags.
>>>  - Tim
>>>  On Wed, May 28, 2014 at 9:40 AM, Tim Armstrong <
>>>>   main_script lets you specify the Tcl script that's run on
>>>> application startup.  To run a compiled Swift program, you set main_script
>>>> to point to the Tcl output file.  mkstatic.tcl doesn't need Swift source
>>>> files.
>>>>  Note that you only need to fill in the fields in the "Manifest info"
>>>> section to generate the C main program.  You probably only need the follow
>>>> to generate the C code:
>>>> # Name and version of Tcl package
>>>> pkg_name=flex_pep_docking_or_whatever
>>>> pkg_version=0.0
>>>> # C function names to initialise Tcl modules
>>>> # These follow the Tcl naming convention, e.g., Userlib_Init
>>>> # Use nm on your extension object code to find this symbol
>>>> lib_init=_Z24FlexPepDocking_wrap_InitP10Tcl_Interp
>>>> # lib scripts are executed in specified order, before main_script and
>>>> # after lib_inits
>>>> lib_script=../flexpep_docking/user-code.tcl
>>>> # headers for user Tcl code, e.g. lib_init functions
>>>> lib_include=../flexpep_docking/FlexPepDocking_wrap.h
>>>> # main script (generated by STC).
>>>> # If provided, always runs this main script.
>>>> # Otherwise, the script file is specified at run time as the
>>>> # first command line argument (like tclsh)
>>>> main_script = stc_output_file.tcl
>>>>  - Tim
>>>>  On Wed, May 28, 2014 at 9:17 AM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>>>>> Thanks. One more question:
>>>>>  I am not sure where should I provide the application source file in
>>>>> the manifest files?
>>>>>  Thanks,
>>>>> Ketan
>>>>>  On Tue, May 27, 2014 at 2:14 PM, Tim Armstrong <
>>>>>>  On Tue, May 27, 2014 at 1:50 PM, Ketan Maheshwari <ketan at mcs.anl.gov
>>>>>> > wrote:
>>>>>>> Hi,
>>>>>>>  Trying to get the Rosetta application static build for Turbine
>>>>>>> using mkstatic.tcl.
>>>>>>>  I am a bit confused about the entries in the manifest file:
>>>>>>>  1. The purpose of lib_script option is not very clear to me. What
>>>>>>> scripts are supposed to go in there? The template lists user_stuff1.tcl,
>>>>>>> user_stuff2.tcl.
>>>>>>>    Any Tcl scripts that you want to run when the library loads.
>>>>>> E.g. if you set pkg_name=the_pkg and lib_script=the_pkg.tcl, then pkg.tcl
>>>>>> will be included in the executable.  It's run when the Tcl user script does
>>>>>> a "package require the_pkg".
>>>>>>>  2. The lib_include entry: does it accept both include dirs and
>>>>>>> header files?
>>>>>>  It has to be a header file - it will just add a #include at the top
>>>>>> of the C main file.  You have to provide any include directory flags to the
>>>>>> C compiler later when you compile it.
>>>>>>>  3. From the documentation
>>>>>>> http://www.mcs.anl.gov/exm/local/guides/swift.html#mkstatic, I see
>>>>>>> that there are options at commandline such as --include-lib and
>>>>>>> --include-system-lib. Are these in lieu of the ones in the manifest?
>>>>>>  These let you link in entire library directories.
>>>>>> --include-system-lib is for the Tcl standard library directory that
>>>>>> is always loaded on startup - it links the files into the executable so
>>>>>> that it doesn't need to load them off disk.  It's mainly for performance,
>>>>>> but it can help build entirely self-contained executables.
>>>>>>  --include-lib  lets you link in an external library, e.g. a
>>>>>> directory of Tcl files, or a directory with a pkgIndex.tcl file.  These are
>>>>>> set up to to be loaded on demand with "package require".  --include-lib
>>>>>> <dir> is essentially an alternative to setting TURBINE_USER_LIB=<dir>.
>>>>>>>  Thanks,
>>>>>>> Ketan
>>>>>>> _______________________________________________
>>>>>>> ExM-user mailing list
>>>>>>> ExM-user at lists.mcs.anl.gov
>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
> ExM-user mailing listExM-user at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/exm-user
> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140529/09c13ad6/attachment-0001.html>
More information about the ExM-user mailing list
