[ExM Users] mkstatic questions
Ketan Maheshwari
ketan at mcs.anl.gov
Thu May 29 09:59:20 CDT 2014
Thanks! Trying to link with the following:
/soft/compilers/wrappers/xl/mpixlcxx -o static_leaf_main static_leaf_main.o
/home/ketan/rosetta/flexpep_docking/leaf_main.a \
-pg -qsmp=omp -g -O0 -qarch=qp -qtune=qp -qhot
-Wl,--allow-multiple-definition \
/projects/ExM/ketan/openmp-gnu-july16-mini/build/src/debug/linux/2.6/64/ppc64/xlc/static-mpi/apps/public/flexpep_docking/FlexPepDocking.o
-L$TCL_HOME/lib -L$TURBINE_HOME/lib
-L/projects/ExM/ketan/openmp-gnu-july16-mini/external/lib \
-L/projects/ExM/ketan/openmp-gnu-july16-mini/build/src/debug/linux/2.6/64/ppc64/xlc/static-mpi
-Lsrc
-L/projects/ExM/ketan/openmp-gnu-july16-mini/build/external/debug/linux/2.6/64/ppc64/xlc/static-mpi
-Lexternal -L/home/vsachde/ROSETTA/zlib/lib -ldevel -lprotocols.7
-lprotocols.6 -lprotocols_f.5 -lprotocols_e.5 \
-lprotocols_d.5 -lprotocols_c.5 -lprotocols_b.5 -lprotocols_a.5
-lprotocols_h.4 -lprotocols_g.4 -lprotocols_f.4 \
-lprotocols_e.4 -lprotocols_d.4 -lprotocols_c.4 -lprotocols_b.4
-lprotocols_a.4 -lprotocols.3 -lprotocols_b.2 \
-lprotocols_a.2 -lprotocols.1 -lcore.5 -lcore.4 -lcore.3 -lcore.2 -lcore.1
-lbasic -lnumeric -lutility -lObjexxFCL \
-lz -lcppdb -lsqlite3 -lz -ltclstub8.5 -ltcl8.5 -ltclturbine
-ltclturbinestatic -ltclturbinestaticres
Getting the error message:
/bgsys/drivers/ppcfloor/gnu-linux/powerpc64-bgq-linux/bin/ld: cannot find
-ltcl8.5
-ltclturbine
$TCL_HOME is /home/wozniak/Public/sfw/ppc64/tcl-8.5.12
$TURBINE_HOME is /home/wozniak/Public/sfw/ppc64/turbine/lib
and the libs that ld is complaining about does seem to be available at the
above locations. Any suggestions?
Ketan
On Thu, May 29, 2014 at 9:09 AM, Tim Armstrong <tim.g.armstrong at gmail.com>
wrote:
> Forgot to send this to the list.
> On Thu, May 29, 2014 at 8:06 AM, Tim Armstrong <tim.g.armstrong at gmail.com>
> wrote:
>> Another thing I should mention is that you can source the
>> turbine-build-config,sh script under turbine to get many of the variables
>> you need e.g. install dirs, tcl version, linker flags.
>> - Tim
>> On Wed, May 28, 2014 at 9:40 AM, Tim Armstrong <tim.g.armstrong at gmail.com
>> > wrote:
>>> main_script lets you specify the Tcl script that's run on application
>>> startup. To run a compiled Swift program, you set main_script to point to
>>> the Tcl output file. mkstatic.tcl doesn't need Swift source files.
>>> Note that you only need to fill in the fields in the "Manifest info"
>>> section to generate the C main program. You probably only need the follow
>>> to generate the C code:
>>> # Name and version of Tcl package
>>> pkg_name=flex_pep_docking_or_whatever
>>> pkg_version=0.0
>>> # C function names to initialise Tcl modules
>>> # These follow the Tcl naming convention, e.g., Userlib_Init
>>> # Use nm on your extension object code to find this symbol
>>> lib_init=_Z24FlexPepDocking_wrap_InitP10Tcl_Interp
>>> # lib scripts are executed in specified order, before main_script and
>>> # after lib_inits
>>> lib_script=../flexpep_docking/user-code.tcl
>>> # headers for user Tcl code, e.g. lib_init functions
>>> lib_include=../flexpep_docking/FlexPepDocking_wrap.h
>>> # main script (generated by STC).
>>> # If provided, always runs this main script.
>>> # Otherwise, the script file is specified at run time as the
>>> # first command line argument (like tclsh)
>>> main_script = stc_output_file.tcl
>>> - Tim
>>> On Wed, May 28, 2014 at 9:17 AM, Ketan Maheshwari <ketan at mcs.anl.gov>
>>> wrote:
>>>> Thanks. One more question:
>>>> I am not sure where should I provide the application source file in
>>>> the manifest files?
>>>> Thanks,
>>>> Ketan
>>>> On Tue, May 27, 2014 at 2:14 PM, Tim Armstrong <
>>>> tim.g.armstrong at gmail.com> wrote:
>>>>> On Tue, May 27, 2014 at 1:50 PM, Ketan Maheshwari <ketan at mcs.anl.gov>
>>>>> wrote:
>>>>>> Hi,
>>>>>> Trying to get the Rosetta application static build for Turbine
>>>>>> using mkstatic.tcl.
>>>>>> I am a bit confused about the entries in the manifest file:
>>>>>> 1. The purpose of lib_script option is not very clear to me. What
>>>>>> scripts are supposed to go in there? The template lists user_stuff1.tcl,
>>>>>> user_stuff2.tcl.
>>>>>> Any Tcl scripts that you want to run when the library loads.
>>>>> E.g. if you set pkg_name=the_pkg and lib_script=the_pkg.tcl, then pkg.tcl
>>>>> will be included in the executable. It's run when the Tcl user script does
>>>>> a "package require the_pkg".
>>>>>> 2. The lib_include entry: does it accept both include dirs and
>>>>>> header files?
>>>>> It has to be a header file - it will just add a #include at the top
>>>>> of the C main file. You have to provide any include directory flags to the
>>>>> C compiler later when you compile it.
>>>>>> 3. From the documentation
>>>>>> http://www.mcs.anl.gov/exm/local/guides/swift.html#mkstatic, I see
>>>>>> that there are options at commandline such as --include-lib and
>>>>>> --include-system-lib. Are these in lieu of the ones in the manifest?
>>>>> These let you link in entire library directories.
>>>>> --include-system-lib is for the Tcl standard library directory that is
>>>>> always loaded on startup - it links the files into the executable so that
>>>>> it doesn't need to load them off disk. It's mainly for performance, but it
>>>>> can help build entirely self-contained executables.
>>>>> --include-lib lets you link in an external library, e.g. a directory
>>>>> of Tcl files, or a directory with a pkgIndex.tcl file. These are set up to
>>>>> to be loaded on demand with "package require". --include-lib <dir> is
>>>>> essentially an alternative to setting TURBINE_USER_LIB=<dir>.
>>>>>> Thanks,
>>>>>> Ketan
>>>>>> _______________________________________________
>>>>>> ExM-user mailing list
>>>>>> ExM-user at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140529/bfd23b27/attachment-0001.html>
More information about the ExM-user
