[ExM Users] mkstatic questions
Ketan Maheshwari
ketan at mcs.anl.gov
Wed May 28 09:17:26 CDT 2014
Thanks. One more question:
I am not sure where should I provide the application source file in the
manifest files?
Ketan
On Tue, May 27, 2014 at 2:14 PM, Tim Armstrong <tim.g.armstrong at gmail.com>wrote:
> On Tue, May 27, 2014 at 1:50 PM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>> Hi,
>> Trying to get the Rosetta application static build for Turbine using
>> mkstatic.tcl.
>> I am a bit confused about the entries in the manifest file:
>> 1. The purpose of lib_script option is not very clear to me. What
>> scripts are supposed to go in there? The template lists user_stuff1.tcl,
>> user_stuff2.tcl.
>> Any Tcl scripts that you want to run when the library loads. E.g. if
> you set pkg_name=the_pkg and lib_script=the_pkg.tcl, then pkg.tcl will be
> included in the executable. It's run when the Tcl user script does a
> "package require the_pkg".
>> 2. The lib_include entry: does it accept both include dirs and header
>> files?
> It has to be a header file - it will just add a #include at the top of the
> C main file. You have to provide any include directory flags to the C
> compiler later when you compile it.
>> 3. From the documentation
>> http://www.mcs.anl.gov/exm/local/guides/swift.html#mkstatic, I see that
>> there are options at commandline such as --include-lib and
>> --include-system-lib. Are these in lieu of the ones in the manifest?
> These let you link in entire library directories.
> --include-system-lib is for the Tcl standard library directory that is
> always loaded on startup - it links the files into the executable so that
> it doesn't need to load them off disk. It's mainly for performance, but it
> can help build entirely self-contained executables.
> --include-lib lets you link in an external library, e.g. a directory of
> Tcl files, or a directory with a pkgIndex.tcl file. These are set up to to
> be loaded on demand with "package require". --include-lib <dir> is
> essentially an alternative to setting TURBINE_USER_LIB=<dir>.
>> Thanks,
>> Ketan
>> ExM-user mailing list
>> ExM-user at lists.mcs.anl.gov
>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140528/a376ea39/attachment.html>
More information about the ExM-user
