[ExM Users] 2D arrays
Tim Armstrong
tim.g.armstrong at gmail.com
Thu Jun 26 15:57:08 CDT 2014
Yes, the arrays are just nested arrays, so this works: pickle[outer]
On Thu, Jun 26, 2014 at 3:47 PM, Ketan Maheshwari <ketan at mcs.anl.gov> wrote:
> Thanks Tim. That makes sense. One more question:
> Is it possible to consume the resulting 2D array in an outer loop of a
> nested loop such that for each outer dimension all elements of inner
> dimension are passed to a function. eg:
> foreach outer in outerlist{
> foreach inner in innerlist{
> pickle[outer][inner] = producearray(args);
> dumpedout[outer] = consume(pickle[outer][*]);
> So, the synchronization is partial here: as soon as a round of inner loop
> is done the result can be used by consume.
> Thanks,
> Ketan
> On Thu, Jun 26, 2014 at 3:04 PM, Tim Armstrong <tim.g.armstrong at gmail.com>
> wrote:
>> Yes 2D arrays are supported with the same declaration syntax as
>> Swift/K. You're trying to declare a 2D array with key types i and j in
>> each loop iteration. The compiler is correctly pointing out that i isn't a
>> type. You need to declare it outside of the loops then assign it inside
>> the loops.
>> - Tim
>> On Thu, Jun 26, 2014 at 2:44 PM, Ketan Maheshwari <ketan at mcs.anl.gov>
>> wrote:
>>> Are 2D arrays of this style supported in T:
>>> main {
>>> foreach i in [0:31]{
>>> /*string commands[] = ["head","tail","wc","stat"];*/
>>> foreach j in [0:24]{
>>> string pyline=sprintf("import cPickle as
>>> pickle\n\nrepr(pickle.dumps({'foo1':%s,'foo2':%s}))", i, j);
>>> string pickle[i][j] = python(pyline);
>>> stc gives following error:
>>> stc error:
>>> multi-map-reduce.swift:15:3: The following type was not defined in the
>>> current context: j
>>> _______________________________________________
>>> ExM-user mailing list
>>> ExM-user at lists.mcs.anl.gov
>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140626/6af4d262/attachment-0001.html>
More information about the ExM-user
