[ExM Users] app fails
Ketan Maheshwari
ketan at mcs.anl.gov
Thu Jun 26 13:53:36 CDT 2014
The following T script with app def fails for me:
import files;
import io;
import string;
app (file o) cmd (string acmd, string arg) {
"/bin/bash -c" acmd arg @stdout=o
main {
file output<sprintf("s.txt")> = cmd("echo", "hello");
CAUGHT ERROR:
external command failed: /bin/bash -c echo hello
while executing
"error $msg"
(procedure "turbine_error" line 6)
invoked from within
"turbine_error "external command failed: $cmd $args""
(procedure "turbine::exec_external" line 16)
invoked from within
"turbine::exec_external "/bin/bash -c" [ dict create "stdout"
${v:__filename:o} ] ${v:acmd} ${v:arg}"
(procedure "cmd-app-leaf0" line 17)
invoked from within
"cmd-app-leaf0 0 {7.0} 1 {1} {4} {file 7 is_mapped 1}"
Turbine worker task error in: cmd-app-leaf0 0 {7.0} 1 {1} {4} {file 7
is_mapped 1}
invoked from within
"c::worker_loop $WORK_TYPE(WORK)"
(procedure "worker" line 28)
invoked from within
"worker $rules $startup_cmd"
(procedure "enter_mode_unchecked" line 5)
invoked from within
"enter_mode_unchecked $rules $startup_cmd"
(procedure "enter_mode" line 10)
invoked from within
"enter_mode $rules $startup_cmd "
CALLING adlb::abort
ADLB_Abort(1)
MPI_Abort(1)
application called MPI_Abort(MPI_COMM_WORLD, 1) - process 1
I want to run an arbitrary command with arbitrary args via /bin/bash or
/bin/sh.
Any suggestions?
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140626/b02ef88d/attachment.html>
More information about the ExM-user
