[ExM Users] debugging suggestions for non-static main-wrap segfault
Ketan Maheshwari
ketan at mcs.anl.gov
Tue Jul 29 15:08:58 CDT 2014
Here is the tcl script with puts messages:
package provide leaf_main 0.0
# dnl Receive USER_LEAF from environment for m4 processing
set USER_LEAF dock_wrap
puts hello1
namespace eval leaf_main {
puts hello2
proc leaf_main_wrap { rc A } {
deeprule $A 1 0 "leaf_main::leaf_main_wrap_impl $rc $A" type
$::turbine::WORK
proc leaf_main_wrap_impl { rc A } {
global USER_LEAF
set length [ adlb::container_size $A ]
set tds [ adlb::enumerate $A dict all 0 ]
set argv [ list ]
puts hello3
# Fill argv with blanks
dict for { i v } $tds {
lappend argv 0
# Set values at ordered list positions
lset argv $i $v
set rc_value [ ${USER_LEAF}_extension {*}$argv ]
turbine::store_integer $rc $rc_value
puts hello4
puts hello5
It prints:
hello1
hello2
hello5
I see that it is not going in the proc_leaf_main_wrap_impl but I am not
familiar enough with TCL to understand why.
On Tue, Jul 29, 2014 at 2:41 PM, Tim Armstrong <tim.g.armstrong at gmail.com>
wrote:
> I don't see any reason why that invocation of tclsh would silently fail
> to run the tcl script. Have you attempted to confirm your hypothesis that
> it's not running the script, for example by modifying the script to print
> something at the beginning or end?
> On Tue, Jul 29, 2014 at 1:42 PM, Ketan Maheshwari <ketan at mcs.anl.gov>
> wrote:
>> I expect it to run the application or crash on segfault. Nothing happens.
>> On Tue, Jul 29, 2014 at 1:39 PM, Tim Armstrong <
>> tim.g.armstrong at gmail.com> wrote:
>>> That looks right, it should run dock_wrap.tcl fine. And it runs
>>> successfully to completion with no output? Is that what you expected it to
>>> do?
>>> Backtracking to your original problem, if you could work out which
>>> "package require" statement was failing and provide some info about that
>>> package it might help understand the issue.
>>> - Tim
>>> On Tue, Jul 29, 2014 at 1:32 PM, Ketan Maheshwari <ketan at mcs.anl.gov>
>>> wrote:
>>>> I run tclsh as follows:
>>>> /home/ketan/tcl-install/bin/tclsh8.5 dock_wrap.tcl -i rigid.in
>>>> and
>>>> mpiexec -n 3 /home/ketan/tcl-install/bin/tclsh8.5 dock_wrap.tcl -i
>>>> rigid.in
>>>> On Tue, Jul 29, 2014 at 1:28 PM, Tim Armstrong <
>>>>> I forgot to reply all earlier, re-including the list.
>>>>> How are you running tclsh?
>>>>> On Tue, Jul 29, 2014 at 11:53 AM, Ketan Maheshwari <ketan at mcs.anl.gov>
>>>>> wrote:
>>>>>> when I try tclsh, it does not do anything. Just returns with an exit
>>>>>> status 0.
>>>>>> On Tue, Jul 29, 2014 at 11:02 AM, Tim Armstrong <
>>>>>>> You can run it directly with tclsh or mpiexec tclsh, which is
>>>>>>> what turbine eventually does after setting up environment variables, etc.
>>>>>>> - Tim
>>>>>>> On Tue, Jul 29, 2014 at 10:57 AM, Ketan Maheshwari <
>>>>>>> ketan at mcs.anl.gov> wrote:
>>>>>>>> Is it possible to run the dock_wrap.tcl outside of turbine just as
>>>>>>>> in the case of static build?
>>>>>>>> On Tue, Jul 29, 2014 at 10:45 AM, Wozniak, Justin M. <
>>>>>>>> wozniak at mcs.anl.gov> wrote:
>>>>>>>>> Ok, it's in. The Swift/K SVN is apparently down so it's not on
>>>>>>>>> the web yet but see the asciidoc.
>>>>>>>>> On 07/29/2014 10:21 AM, Justin M Wozniak wrote:
>>>>>>>>> I thought VALGRIND was in the manual already but it isn't. I will
>>>>>>>>> add it now. I will also talk about our GDB feature.
>>>>>>>>> On 07/29/2014 10:17 AM, Ketan Maheshwari wrote:
>>>>>>>>> Thanks! Seems turbine script already had a placeholder for
>>>>>>>>> Valgrind so I tried that and from the output, it seems tcl libraries are
>>>>>>>>> causing segfault but I may be wrong. Attached is the Valgrind output.
>>>>>>>>> On Tue, Jul 29, 2014 at 10:05 AM, Tim Armstrong <
>>>>>>>>>> I don't have any particular insight into the cause of the
>>>>>>>>>> segfault, I can help with the debugger though.
>>>>>>>>>> You need to point gdb at the tclsh that is being used by turbine
>>>>>>>>>> (which is just a shell script). You can locate the correct tclsh by
>>>>>>>>>> looking at TCLSH in scripts/turbine-config.sh in the turbine install
>>>>>>>>>> directory.
>>>>>>>>>> - TIm
>>>>>>>>>> On Tue, Jul 29, 2014 at 10:00 AM, Ketan Maheshwari <
>>>>>>>>>>> Hi,
>>>>>>>>>>> Trying to main-wrap DOCK 6.6 application for ATPESC, I get the
>>>>>>>>>>> build right (seems) but things fail at runtime giving segfault:
>>>>>>>>>>> $ turbine -n 4 user-code.tcl
>>>>>>>>>>> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>>>>>>>>>>> = EXIT CODE: 139
>>>>>>>>>>> = CLEANING UP REMAINING PROCESSES
>>>>>>>>>>> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>>>>>>>>>>> YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation
>>>>>>>>>>> fault (signal 11)
>>>>>>>>>>> This typically refers to a problem with your application.
>>>>>>>>>>> Please see the FAQ page for debugging suggestions
>>>>>>>>>>> This is on MCS machine. Any suggestion to debug this? I tried
>>>>>>>>>>> gdb but it gives:
>>>>>>>>>>> "/nfs2/ketan/exm-install/turbine/bin/turbine": not in
>>>>>>>>>>> executable format: File format not recognized
>>>>>>>>>>> With strace, I see some signs of missing files but not sure if
>>>>>>>>>>> that is the cause of segfault. Attached is the strace output of:
>>>>>>>>>>> strace -o strace.out turbine -n 4 user-code.tcl
>>>>>>>>>>> The code has some MPI and pthread elements but does not use
>>>>>>>>>>> them as far as I understand.
>>>>>>>>>>> Thanks for any suggestions.
>>>>>>>>>>> Ketan
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> ExM-user mailing list
>>>>>>>>>>> ExM-user at lists.mcs.anl.gov
>>>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>>>>>>>> ExM-user mailing listExM-user at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>>>>>>>> Justin M Wozniak
>>>>>>>>> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140729/4d673791/attachment-0001.html>
More information about the ExM-user
