[ExM Users] debugging suggestions for non-static main-wrap segfault
Justin M Wozniak
wozniak at mcs.anl.gov
Tue Jul 29 10:45:08 CDT 2014
Ok, it's in. The Swift/K SVN is apparently down so it's not on the web
yet but see the asciidoc.
On 07/29/2014 10:21 AM, Justin M Wozniak wrote:
> I thought VALGRIND was in the manual already but it isn't. I will add
> it now. I will also talk about our GDB feature.
> On 07/29/2014 10:17 AM, Ketan Maheshwari wrote:
>> Thanks! Seems turbine script already had a placeholder for Valgrind
>> so I tried that and from the output, it seems tcl libraries are
>> causing segfault but I may be wrong. Attached is the Valgrind output.
>> On Tue, Jul 29, 2014 at 10:05 AM, Tim Armstrong
>> <tim.g.armstrong at gmail.com <mailto:tim.g.armstrong at gmail.com>> wrote:
>> I don't have any particular insight into the cause of the
>> segfault, I can help with the debugger though.
>> You need to point gdb at the tclsh that is being used by turbine
>> (which is just a shell script). You can locate the correct tclsh
>> by looking at TCLSH in scripts/turbine-config.sh in the turbine
>> install directory.
>> - TIm
>> On Tue, Jul 29, 2014 at 10:00 AM, Ketan Maheshwari
>> <ketan at mcs.anl.gov <mailto:ketan at mcs.anl.gov>> wrote:
>> Hi,
>> Trying to main-wrap DOCK 6.6 application for ATPESC, I get
>> the build right (seems) but things fail at runtime giving
>> segfault:
>> $ turbine -n 4 user-code.tcl
>> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>> = EXIT CODE: 139
>> = CLEANING UP REMAINING PROCESSES
>> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>> YOUR APPLICATION TERMINATED WITH THE EXIT STRING:
>> Segmentation fault (signal 11)
>> This typically refers to a problem with your application.
>> Please see the FAQ page for debugging suggestions
>> This is on MCS machine. Any suggestion to debug this? I tried
>> gdb but it gives:
>> "/nfs2/ketan/exm-install/turbine/bin/turbine": not in
>> executable format: File format not recognized
>> With strace, I see some signs of missing files but not sure
>> if that is the cause of segfault. Attached is the strace
>> output of:
>> strace -o strace.out turbine -n 4 user-code.tcl
>> The code has some MPI and pthread elements but does not use
>> them as far as I understand.
>> Thanks for any suggestions.
>> Ketan
>> ExM-user mailing list
>> ExM-user at lists.mcs.anl.gov <mailto:ExM-user at lists.mcs.anl.gov>
>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
> Justin M Wozniak
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140729/57d5f750/attachment.html>
More information about the ExM-user
