[ExM Users] debugging suggestions for non-static main-wrap segfault
Justin M Wozniak
wozniak at mcs.anl.gov
Tue Jul 29 10:21:56 CDT 2014
I thought VALGRIND was in the manual already but it isn't. I will add
it now. I will also talk about our GDB feature.
On 07/29/2014 10:17 AM, Ketan Maheshwari wrote:
> Thanks! Seems turbine script already had a placeholder for Valgrind so
> I tried that and from the output, it seems tcl libraries are causing
> segfault but I may be wrong. Attached is the Valgrind output.
> On Tue, Jul 29, 2014 at 10:05 AM, Tim Armstrong
> <tim.g.armstrong at gmail.com <mailto:tim.g.armstrong at gmail.com>> wrote:
> I don't have any particular insight into the cause of the
> segfault, I can help with the debugger though.
> You need to point gdb at the tclsh that is being used by turbine
> (which is just a shell script). You can locate the correct tclsh
> by looking at TCLSH in scripts/turbine-config.sh in the turbine
> install directory.
> - TIm
> On Tue, Jul 29, 2014 at 10:00 AM, Ketan Maheshwari
> <ketan at mcs.anl.gov <mailto:ketan at mcs.anl.gov>> wrote:
> Hi,
> Trying to main-wrap DOCK 6.6 application for ATPESC, I get the
> build right (seems) but things fail at runtime giving segfault:
> $ turbine -n 4 user-code.tcl
> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> = EXIT CODE: 139
> = CLEANING UP REMAINING PROCESSES
> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation
> fault (signal 11)
> This typically refers to a problem with your application.
> Please see the FAQ page for debugging suggestions
> This is on MCS machine. Any suggestion to debug this? I tried
> gdb but it gives:
> "/nfs2/ketan/exm-install/turbine/bin/turbine": not in
> executable format: File format not recognized
> With strace, I see some signs of missing files but not sure if
> that is the cause of segfault. Attached is the strace output of:
> strace -o strace.out turbine -n 4 user-code.tcl
> The code has some MPI and pthread elements but does not use
> them as far as I understand.
> Thanks for any suggestions.
> Ketan
> ExM-user mailing list
> ExM-user at lists.mcs.anl.gov <mailto:ExM-user at lists.mcs.anl.gov>
> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140729/fc043f60/attachment-0001.html>
More information about the ExM-user
