[ExM Users] [EXTERNAL] Re: Generating Blobs in Swift/T
Knight, Samuel
sknigh at sandia.gov
Mon Jul 14 16:42:02 CDT 2014
Thanks for the speedy response.
We are currently building 0.5.0 from source.
I have three additional questions;
1. Is there a float -> int function? I crating a workaround by casting float -> string -> (parse on decimal) string -> int. It is wasteful, and it only works when there is no exponential component.
2. Is there a single, comprehensive place to read about the '@' directives? For example, I cannot determine the difference between '@dispatch=WORKER' and '@dispatch=LEAF' from the documentation I have found.
3. Is a roadmap posted online? It is relevant to my project to know about this programming-model's direction. It would be particularly helpful to know when 0.6.0 and 1.0 are planned for release and what will be added to the implementation.
Thank You,
Samuel Knight
From: Tim Armstrong <tim.g.armstrong at gmail.com<mailto:tim.g.armstrong at gmail.com>>
Date: Monday, July 14, 2014 at 2:08 PM
To: Justin M Wozniak <wozniak at mcs.anl.gov<mailto:wozniak at mcs.anl.gov>>
Cc: "exm-user at lists.mcs.anl.gov<mailto:exm-user at lists.mcs.anl.gov>" <exm-user at lists.mcs.anl.gov<mailto:exm-user at lists.mcs.anl.gov>>
Subject: [EXTERNAL] Re: [ExM Users] Generating Blobs in Swift/T
I just wanted to add that if you built the release from source you can safely comment out the offending line (line 2178 of tcl-adlb.c, I believe, if you are using the exm-0.5.0 release). As Justin said, this made it into the release on accident and doesn't have any useful purpose.
Tim
On Mon, Jul 14, 2014 at 4:05 PM, Justin M Wozniak <wozniak at mcs.anl.gov<mailto:wozniak at mcs.anl.gov>> wrote:
Hi
Sorry- that message is a debugging line that unfortunately made it into the release. It is already removed from our trunk and will not be in the next release- you can just remove it from your source.
I will fix the blob doc issue now but feel free to post any additional questions here in the meantime...
Justin
On 07/14/2014 03:52 PM, Knight, Samuel wrote:
Hello,
I am writing a program in Swift/T that generates blob objects inside a leaf function. Binary data is generated with a Swig-wrapped C function, and the blob construct is produced by making a list out of the pointer and length in the Tcl wrapper.
Here is a sample from my Tcl script:
proc c_initVect { s o } {
set len [ expr $s * [blobutils_sizeof_int32] ]
set ptr [ blobutils_malloc $len ]
initVect [blobutils_cast_to_int_ptr $ptr] $s $o # C leaf function
return [ list [ blobutils_cast_to_int $ptr] $len ] # creating the blob
When I run the program with this snippet, my output fills with 'uncache_blob' messages.
Here is an example:
uncache_blob: 67376368 4000 3uncache_blob: 67380384 4000 4
Which is the output from a program that generates 2 blobs with the function above.
The output is automatically generated by the runtime, and I have no control over when blobs are uncached.
I've traced that output to ADLB_Local_Blob_Free_Cmd function in src/tcl/adlb/tcl-adlb.c
For programs that allocate a large number of blobs, the output from the runtime becomes overwhelming, and I am starting to think my snippet is generating blobs incorrectly. So far, the only example I can find that generates blobs that are returned to Swift/T is a the fortran example from the leaf functions guide (Section 3.4 www.mcs.anl.gov/exm/local/guides/leaf.html<http://www.mcs.anl.gov/exm/local/guides/leaf.html>). There is a promising link in Section 3.3.3 of the leaf guide that explains blobs, but when I click on it I get a 403 error.
Is anyone aware of additional examples or tutorials that explain how to generate and manage blobs in Swift/T.
Thank you,
Samuel Knight
ExM-user mailing list
ExM-user at lists.mcs.anl.gov<mailto:ExM-user at lists.mcs.anl.gov>https://lists.mcs.anl.gov/mailman/listinfo/exm-user
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140714/f49241ef/attachment.html>
More information about the ExM-user
