[ExM Users] debugging suggestions for non-static main-wrap segfault
Justin M Wozniak
wozniak at mcs.anl.gov
Fri Aug 1 11:09:06 CDT 2014
Try now.
On 08/01/2014 10:40 AM, Ketan Maheshwari wrote:
> Now working on BG. Justin, can you push the latest genleaf with
> objlist on BG.
> On Thu, Jul 31, 2014 at 4:34 PM, Tim Armstrong
> <tim.g.armstrong at gmail.com <mailto:tim.g.armstrong at gmail.com>> wrote:
> Hm, ok, interesting. I'm surprised that the compiler/linker
> didn't kick up a fuss, but I guess it snuck by it somehow.
> - Tim
> On Thu, Jul 31, 2014 at 4:29 PM, Ketan Maheshwari
> <ketan at mcs.anl.gov <mailto:ketan at mcs.anl.gov>> wrote:
> Justin caught 1 by copying all the .o files from FS into
> objfiles directory, no subdirs. Which lead to me adding -fPIC
> in Makefile. Later, I explicitly made the dir hierarchy mkdir
> -p objfiles/nab, pulled in respective .o files and built the
> .so with them. The invalid address was likely from one of the
> nab/*.o files (most likely molio.o) which got fixed.
> On Thu, Jul 31, 2014 at 4:25 PM, Ketan Maheshwari
> Two things:
> 1. The nab module was not being compiled with -fPIC.
> 2. I did not use the object files from this module as they
> end up in a subdir and I was just saying objfiles/*.o
> instead of objfiles/*.o objfiles/nab/*.o.
> On Thu, Jul 31, 2014 at 4:21 PM, Tim Armstrong
> What was the diagnosis in the end?
> On Thu, Jul 31, 2014 at 3:51 PM, Justin M Wozniak
> <wozniak at mcs.anl.gov <mailto:wozniak at mcs.anl.gov>> wrote:
> Oh good.
> On 07/31/2014 03:49 PM, Ketan Maheshwari wrote:
>> This has worked!
>> Thanks,
>> Ketan
>> On Thu, Jul 31, 2014 at 3:41 PM, Maheshwari,
>> Ketan C. <ketan at mcs.anl.gov
>> Fixed now.
>> On Thu, Jul 31, 2014 at 3:37 PM, Wozniak,
>> Justin M. <wozniak at mcs.anl.gov
>> On 07/31/2014 03:33 PM, Ketan Maheshwari
>> wrote:
>> > The make output shows things were
>> compiled with
>> > -fPIC:
>> /homes/ketan/dock6/install/makedock.out
>> I get:
>> /usr/bin/ld: objfiles/molio.o: relocation
>> R_X86_64_32 against
>> `.rodata.str1.1' can not be used when
>> making a shared object; recompile
>> with -fPIC
>> objfiles/molio.o: could not read symbols:
>> Bad value
>> makedock.out contains:
>> gcc -c -O3 -D_ANSI_SOURCE molio.c
>> Justin M Wozniak
> Justin M Wozniak
> ExM-user mailing list
> ExM-user at lists.mcs.anl.gov
> <mailto:ExM-user at lists.mcs.anl.gov>
> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140801/a9b3863a/attachment-0001.html>
More information about the ExM-user
