[ExM Users] stc unsupported class error
Tim Armstrong tim.g.armstrong at gmail.com
Mon Apr 28 16:43:35 CDT 2014
Hmm, the code that decides which java to use when -j isn't set is really
simple:
JVM=$( which java || true )
It doesn't seem like anything could possibly go wrong, but i've been able
to replicate the problem on the mcs login hosts.  I'll investigate.
- Tim
On Mon, Apr 28, 2014 at 3:21 PM, Ketan Maheshwari <ketan at mcs.anl.gov> wrote:
> It shows the following:
> declare -x
> PATH="/homes/ketan/cloud/ec2-api-tools-1.6.12.2/bin:/homes/ketan/apache-maven-3.2.1/bin:/homes/ketan/jdk1.7.0_07/bin:/homes/ketan/globus-install/bin:/homes/ketan/swift-0.94/cog/modules/swift/dist/swift-svn/bin:/homes/ketan/escience_2013/swift:/home/ketan/CoinIpopt/bin:/homes/ketan/cctools-install/bin:/home/neosotc/neos-bin:/home/ketan/tcl-install/bin:/home/ketan/mpich3-install/bin:/home/ketan/exm-install/turbine/bin:/home/ketan/exm-install/stc/bin:/homes/ketan/swig-install/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/mcs/bin:/usr/local/bin:/software/common/bin:/soft/apps/bin:/soft/gnu/bin:/soft/com/bin:/soft/adm/bin:/homes/ketan/bin/linux-Ubuntu_12.04-x86_64:/homes/ketan/bin"
> It does have both /usr/bin and /homes/ketan/jdk1.7.0_07/bin and seems
> /homes/ketan/jdk1.7.0_07/bin appears before /usr/bin which makes
> /homes/ketan/jdk1.7.0_07/bin appear as default java.
> On Mon, Apr 28, 2014 at 3:16 PM, Tim Armstrong <tim.g.armstrong at gmail.com>wrote:
>>  Can you check that the PATH is exported, e.g:
>> export | grep PATH
>> On Mon, Apr 28, 2014 at 2:25 PM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>>> Strange:
>>>  $ stc -v
>>> STC: Swift-Turbine Compiler
>>> for Turbine: 0.3.0
>>> TURBINE_INSTALL=
>>> TURBINE_HOME=/home/ketan/exm-install/turbine
>>> Using Java: /usr/bin/java
>>> $ which java
>>> /homes/ketan/jdk1.7.0_07/bin/java
>>>  On Mon, Apr 28, 2014 at 2:11 PM, Tim Armstrong <
>>> tim.g.armstrong at gmail.com> wrote:
>>>>   Hmm, the code to locate java is really simple, it does a "which
>>>> java" and that's all.  Is your path variable being exported after you add
>>>> Java to it?
>>>> You can get stc to report which java it's using with the lower case -v
>>>> flag too.
>>>>   - Tim
>>>>  On Mon, Apr 28, 2014 at 12:58 PM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>>>>> It appears so. I have my own java in PATH and am using the same for
>>>>> building and running.
>>>>>  On Mon, Apr 28, 2014 at 11:15 AM, Tim Armstrong <
>>>>>>   It should default to the java in PATH - is it not doing that for
>>>>>> you?
>>>>>>  Currently it only uses two things to resolve java: the -j flag, and
>>>>>> "which java" - other environment variables, etc, shouldn't affect it.
>>>>>>  - Tim
>>>>>> On Mon, Apr 28, 2014 at 11:04 AM, Ketan Maheshwari <ketan at mcs.anl.gov
>>>>>> > wrote:
>>>>>>> Hi Tim,
>>>>>>>  stc -V does not seem to show which java it is running with:
>>>>>>>  $ stc -V user.swift
>>>>>>> stc: Optimization level 2
>>>>>>>  Exception in thread "main" java.lang.UnsupportedClassVersionError:
>>>>>>> exm/stc/ui/Main : Unsupported major.minor version 51.0
>>>>>>>  The -j option works but in my case, the stc call is part of a
>>>>>>> generic script and this will involve detecting java on systems to run with.
>>>>>>> Is it somehow possible to tell stc to use the same java in current env at
>>>>>>> the time of build and run.
>>>>>>>  Thanks,
>>>>>>> Ketan
>>>>>>>  On Mon, Apr 28, 2014 at 10:56 AM, Tim Armstrong <
>>>>>>>>   I haven't seen that one before.  It sounds like it's being run
>>>>>>>> with an older version of Java than it was compiled with.
>>>>>>>> Java class version 51.0 corresponds to java 7 (
>>>>>>>> http://en.wikipedia.org/wiki/Java_class_file#General_layout), so
>>>>>>>> it seems like it must be getting run with an older version.
>>>>>>>>  You could try the -V switch to STC to see which java it's being
>>>>>>>> run with, and then -j /path/to/jvm/bin/java to force a different java
>>>>>>>> version.
>>>>>>>>  - Tim
>>>>>>>>   On Mon, Apr 28, 2014 at 10:33 AM, Ketan Maheshwari <
>>>>>>>>>   Hi,
>>>>>>>>>  While running stc on MCS workstations, I get:
>>>>>>>>>  ./genleaf vanilla mockdock.c mockdock.h user.swift
>>>>>>>>> java.lang.UnsupportedClassVersionError: exm/stc/ui/Main : Unsupported
>>>>>>>>>  Somehow the java versions at build and runtime are getting mixed
>>>>>>>>> up.
>>>>>>>>>  This is how I build:
>>>>>>>>>  export JAVA_HOME=/homes/ketan/jdk1.7.0_07
>>>>>>>>>  ant install -Ddist.dir=/home/ketan/exm-install/stc
>>>>>>>>>  I have the same java in my env:
>>>>>>>>>  $ which java
>>>>>>>>>  Any suggestions to fix this?
>>>>>>>>>  Thanks,
>>>>>>>>> Ketan
>>>>>>>>>   _______________________________________________
>>>>>>>>> ExM-user mailing list
>>>>>>>>> ExM-user at lists.mcs.anl.gov
>>>>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140428/6a78d08f/attachment.html>
More information about the ExM-user mailing list
