[ExM Users] stc unsupported class error
Ketan Maheshwari ketan at mcs.anl.gov
Mon Apr 28 14:25:59 CDT 2014
Strange:
$ stc -v
STC: Swift-Turbine Compiler
 for Turbine: 0.3.0
TURBINE_INSTALL=
TURBINE_HOME=/home/ketan/exm-install/turbine
Using Java: /usr/bin/java
$ which java
/homes/ketan/jdk1.7.0_07/bin/java
On Mon, Apr 28, 2014 at 2:11 PM, Tim Armstrong <tim.g.armstrong at gmail.com>wrote:
>  Hmm, the code to locate java is really simple, it does a "which java"
> and that's all.  Is your path variable being exported after you add Java to
> it?
> You can get stc to report which java it's using with the lower case -v
> flag too.
>  - Tim
> On Mon, Apr 28, 2014 at 12:58 PM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>> It appears so. I have my own java in PATH and am using the same for
>> building and running.
>>  On Mon, Apr 28, 2014 at 11:15 AM, Tim Armstrong <
>> tim.g.armstrong at gmail.com> wrote:
>>>   It should default to the java in PATH - is it not doing that for
>>> you?
>>>  Currently it only uses two things to resolve java: the -j flag, and
>>> "which java" - other environment variables, etc, shouldn't affect it.
>>>  - Tim
>>> On Mon, Apr 28, 2014 at 11:04 AM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>>>> Hi Tim,
>>>>  stc -V does not seem to show which java it is running with:
>>>>  $ stc -V user.swift
>>>> stc: Optimization level 2
>>>>  Exception in thread "main" java.lang.UnsupportedClassVersionError:
>>>> exm/stc/ui/Main : Unsupported major.minor version 51.0
>>>>  The -j option works but in my case, the stc call is part of a generic
>>>> script and this will involve detecting java on systems to run with. Is it
>>>> somehow possible to tell stc to use the same java in current env at the
>>>> time of build and run.
>>>>  Thanks,
>>>> Ketan
>>>>  On Mon, Apr 28, 2014 at 10:56 AM, Tim Armstrong <
>>>>>   I haven't seen that one before.  It sounds like it's being run with
>>>>> an older version of Java than it was compiled with.
>>>>> Java class version 51.0 corresponds to java 7 (
>>>>> http://en.wikipedia.org/wiki/Java_class_file#General_layout), so it
>>>>> seems like it must be getting run with an older version.
>>>>>  You could try the -V switch to STC to see which java it's being run
>>>>> with, and then -j /path/to/jvm/bin/java to force a different java version.
>>>>>  - Tim
>>>>>   On Mon, Apr 28, 2014 at 10:33 AM, Ketan Maheshwari <
>>>>> ketan at mcs.anl.gov> wrote:
>>>>>>   Hi,
>>>>>>  While running stc on MCS workstations, I get:
>>>>>>  ./genleaf vanilla mockdock.c mockdock.h user.swift
>>>>>>  Somehow the java versions at build and runtime are getting mixed up.
>>>>>>  This is how I build:
>>>>>>  export JAVA_HOME=/homes/ketan/jdk1.7.0_07
>>>>>>  ant install -Ddist.dir=/home/ketan/exm-install/stc
>>>>>>  I have the same java in my env:
>>>>>>  $ which java
>>>>>>  Any suggestions to fix this?
>>>>>>  Thanks,
>>>>>> Ketan
>>>>>>   _______________________________________________
>>>>>> ExM-user mailing list
>>>>>> ExM-user at lists.mcs.anl.gov
>>>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140428/5afac18f/attachment-0001.html>
More information about the ExM-user mailing list
