[ExM Users] stc unsupported class error
Ketan Maheshwari
ketan at mcs.anl.gov
Mon Apr 28 12:58:44 CDT 2014
It appears so. I have my own java in PATH and am using the same for
building and running.
On Mon, Apr 28, 2014 at 11:15 AM, Tim Armstrong
<tim.g.armstrong at gmail.com>wrote:
> It should default to the java in PATH - is it not doing that for you?
> Currently it only uses two things to resolve java: the -j flag, and
> "which java" - other environment variables, etc, shouldn't affect it.
> - Tim
> On Mon, Apr 28, 2014 at 11:04 AM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>> Hi Tim,
>> stc -V does not seem to show which java it is running with:
>> $ stc -V user.swift
>> stc: Optimization level 2
>> Exception in thread "main" java.lang.UnsupportedClassVersionError:
>> exm/stc/ui/Main : Unsupported major.minor version 51.0
>> The -j option works but in my case, the stc call is part of a generic
>> script and this will involve detecting java on systems to run with. Is it
>> somehow possible to tell stc to use the same java in current env at the
>> time of build and run.
>> Thanks,
>> Ketan
>> On Mon, Apr 28, 2014 at 10:56 AM, Tim Armstrong <
>> tim.g.armstrong at gmail.com> wrote:
>>> I haven't seen that one before. It sounds like it's being run with
>>> an older version of Java than it was compiled with.
>>> Java class version 51.0 corresponds to java 7 (
>>> http://en.wikipedia.org/wiki/Java_class_file#General_layout), so it
>>> seems like it must be getting run with an older version.
>>> You could try the -V switch to STC to see which java it's being run
>>> with, and then -j /path/to/jvm/bin/java to force a different java version.
>>> - Tim
>>> On Mon, Apr 28, 2014 at 10:33 AM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>>>> Hi,
>>>> While running stc on MCS workstations, I get:
>>>> ./genleaf vanilla mockdock.c mockdock.h user.swift
>>>> Somehow the java versions at build and runtime are getting mixed up.
>>>> This is how I build:
>>>> export JAVA_HOME=/homes/ketan/jdk1.7.0_07
>>>> ant install -Ddist.dir=/home/ketan/exm-install/stc
>>>> I have the same java in my env:
>>>> $ which java
>>>> /homes/ketan/jdk1.7.0_07/bin/java
>>>> Any suggestions to fix this?
>>>> Thanks,
>>>> Ketan
>>>> _______________________________________________
>>>> ExM-user mailing list
>>>> ExM-user at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140428/0266ed78/attachment.html>
More information about the ExM-user
