[ExM Users] OS X
Tim Armstrong
tim.g.armstrong at gmail.com
Fri Apr 25 13:30:27 CDT 2014
Hmm haven't been able to replicate it yet. Do you know what version of Tcl
you're using?
One thing that would be helpful is to confirm that it's not getting linked
against multiple different versions of Tcl. E.g.:
ldd userlib.so
ldd /path/to/libtclturbine.so
If you could add this code to extension.c after the result Tcl_Obj is
created, I'd be curious to know if the pointer value was the same (or near
to) the value it's complaining about.
printf("result: %p\n", result);
- Tim
On Fri, Apr 25, 2014 at 1:18 PM, Tim Armstrong <tim.g.armstrong at gmail.com>wrote:
> Ok, looking now.
> It was a bit of a headache getting the build system setup working since
> the autodetection for vanilla only works for particular cases - e.g. on
> Ubuntu the system tcl libraries get put in an architecture-specific
> subdirectory. The machine files thing is a good idea, but using
> scripts/turbine-build-config.sh in the turbine directory would simplify it
> further - it provides most of the information needed without any guesswork.
> - Tim
> On Fri, Apr 25, 2014 at 12:57 PM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>> This happens in main-wrap: exp/apps/main-wrap
>> Here is what I do:
>> ./gendata 100 5
>> ./genleaf -v vanilla mockdock.[ch] user.swift
>> turbine -n 3 user-code.tcl
>> On Fri, Apr 25, 2014 at 11:51 AM, Tim Armstrong <
>> tim.g.armstrong at gmail.com> wrote:
>>> It may not be mac-specific - I'll try to replicate the problem
>>> elsewhere if you can give me a pointer to the script that caused the
>>> problem.
>>> - Tim
>>> On Fri, Apr 25, 2014 at 11:30 AM, Ketan Maheshwari <ketan at mcs.anl.gov>wrote:
>>>> This is on my Mac. May be we can replicate on frisbee or someone's
>>>> Mac if you have access. Assuming you are not a Mac user.
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140425/49355a41/attachment.html>
More information about the ExM-user
