[ExM Users] OS X
Ketan Maheshwari
ketan at mcs.anl.gov
Fri Apr 25 10:43:28 CDT 2014
Trying to run Swift/T on mac OS X. The script compiles and runs with
correct results, but produces the following line in the end and exits with
error:
alloc: invalid block: 0x106775930: 0 0
This is followed by the BAD TERMINATION .. block. Any clues how to debug
this further. Enabled logging which produces a log as follows:
$ turbine -n 3 user-code.tcl
0.000 MODE: ENGINE
0.000 MODE: WORKER
0.000 MODE: SERVER
0.000 ENGINES: 1 RANKS: 0 - 0
0.000 WORKERS: 1 RANKS: 1 - 1
0.000 SERVERS: 1 RANKS: 2 - 2
0.005 function:swift:constants
0.005 allocated string: c:s_2=<1>
0.005 store: <1>="2"
0.005 allocated string: c:s_prot_txt=<2>
0.005 store: <2>="prot.txt"
0.005 enter function: main
0.005 allocated t:5:1=<3> t:6:1=<4> t:8:1=<5> t:5:2=<6> t:6:2=<7>
0.005 allocated t:8:2=<8>
running Swift...
0.005 store: <5>="peptides/pept1.txt"
0.005 array_kv_build: <4> 3 elems, write_decr 1
0.005 allocated void: <9>
0.005 store: <8>="peptides/pept2.txt"
0.005 array_kv_build: <7> 3 elems, write_decr 1
0.006 allocated void: <10>
0.006 Container <4> deep closed
0.006 store: <9>=void
0.006 Container <7> deep closed
0.006 store: <10>=void
0.006 control: close 9
0.006 control: close 10
0.006 deeprule_finish: 9
result number: 6000028
alloc: invalid block: 0x1018d6930: 0 0
But from the log, I am not sure, what the problem might be.
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20140425/50e2c266/attachment.html>
More information about the ExM-user
