[ExM Users] Return worker result to swift script
Scott Krieder
skrieder at iit.edu
Fri Mar 29 13:35:53 CDT 2013
I've created a modified worker that executes some work on a GPU:
/exm/apps/fake-gemtc/worker.tcl
But since I've replaced the eval $command with a GPU_eval $command I'm not
sure how to return my result back into the swift script.
In my particular case I call:
int r = gemtc_sleep(1) from a .swift script. // where gemtc is the gpu call
The worker now has a local int variable with a result from the GPU run but
I'm not sure how to pass this back to the variable r in my .swift script.
Any tips on how I might do this? Does this require modifying other files?
Scott
Scott J. Krieder
C: 419-685-0410
E: skrieder at iit.edu
http://datasys.cs.iit.edu/~skrieder/
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130329/b40108e2/attachment.html>
More information about the ExM-user
