[ExM Users] Trouble with Swift/T Installation
Justin M Wozniak
wozniak at mcs.anl.gov
Tue Mar 5 21:38:20 CST 2013
Hi Dustin
I haven't seen that one before. Just guessing here: Which MPICH
version are you using? Are you sure your MPICH installation works? Are
you sure you compiled against the same MPICH that is running here?
Justin
On 3/5/2013 8:57 PM, Dustin Shahidehpour wrote:
> Hello all,
> I am running into a peculiar when trying to run the "Hello World"
> example code. Here is the error:
> dustin at fusion:> turbine -n 4 program.tcl
> couldn't load file
> "/home/dustin/sfw/exm/turbine/lib/libtclturbine.so":
> /home/dustin/sfw/mpich-install/lib/libmpich.so.10: undefined symbol:
> PMIU_Set_rank
> while executing
> "load /home/dustin/sfw/exm/turbine/lib/libtclturbine.so"
> ("package ifneeded turbine 0.1.0" script)
> invoked from within
> "package require turbine 0.1.0"
> (file "program.tcl" line 41)
> couldn't load file
> PMIU_Set_rank
> while executing
> invoked from within
> couldn't load file
> PMIU_Set_rank
> while executing
> invoked from within
> couldn't load file
> PMIU_Set_rank
> while executing
> invoked from within
> = BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> = EXIT CODE: 1
> = CLEANING UP REMAINING PROCESSES
> = YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> Any ideas?
> Thanks,
> Dustin Shahidehpour
> ExM-user mailing list
> ExM-user at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
Justin M Wozniak
More information about the ExM-user
