[ExM Users] Installing Swift/T 0.3.0 on Mac OS X Mountain Lion
Justin M Wozniak wozniak at mcs.anl.gov
Thu Jun 13 17:30:36 CDT 2013
Great!  We will look into the preprocessing issue.
On 06/13/2013 05:23 PM, Fan Zhang wrote:
> Hi Justin,
>     Thank you very much for your help! Now I can generate the tcl file
> and execute it with turbine on my macbook pro.
> Regards,
> Fan
> On Thu, Jun 13, 2013 at 5:54 PM, Justin M Wozniak <wozniak at mcs.anl.gov
> <mailto:wozniak at mcs.anl.gov>> wrote:
>     Ah- there is some bug in our CPP preprocessing on the Mac.
>     You can disable preprocessing by running:
>     stc -p hello.swift hello.tcl
>     On 06/13/2013 04:46 PM, Fan Zhang wrote:
>>     Please see attached file. Also, I tried to print the string
>>     variable 'inputFile' right before line
>>     exm.stc.ui.STCompiler.parseFile(STCompiler.java:130). My command
>>     is "stc hello.swift hello.tcl", the 'inputFile' value is
>>     "/var/folders/_8/qky8fqpn6_578_gmy5j1qxr00000gn/T/stc-preproc148496063582809381.swift",
>>     which does not exist (at least after the command failed). Thanks
>>     a lot.
>>     Regards,
>>     Fan
>>     On Thu, Jun 13, 2013 at 5:01 PM, Justin M Wozniak
>>     <wozniak at mcs.anl.gov <mailto:wozniak at mcs.anl.gov>> wrote:
>>         Can you send hello.swift?
>>         On 06/13/2013 03:15 PM, Fan Zhang wrote:
>>>         Hi Justin,
>>>             Thanks for your testing and reply. I just made a clean
>>>         reinstall and can successfully build turbine and stc now. I
>>>         have been only using the exm-setup.zsh to build it, probably
>>>         there are some object files were not cleared after I
>>>         installed the mpich 3.0.4.
>>>             However, when I was running stc to compile a simple
>>>         swift script, it gave the error below. The command I used is
>>>         "stc hello.swift hello.tcl".
>>>         STC INTERNAL ERROR
>>>         Please report this
>>>         java.lang.NullPointerException
>>>         at
>>>         org.antlr.runtime.ANTLRStringStream.rewind(ANTLRStringStream.java:179)
>>>         at
>>>         org.antlr.runtime.ANTLRStringStream.rewind(ANTLRStringStream.java:189)
>>>         at exm.stc.frontend.SwiftModule.parse(SwiftModule.java:46)
>>>         at exm.stc.ui.STCompiler.parseFile(STCompiler.java:130)
>>>         at exm.stc.ui.STCompiler.compile(STCompiler.java:63)
>>>         at exm.stc.ui.Main.main(Main.java:93)
>>>             Thanks for your time.
>>>         Regards,
>>>         Fan
>>>         On Thu, Jun 13, 2013 at 11:39 AM, Justin M Wozniak
>>>             I just tested this on darwin12 with SWIG 2.0.9 and could
>>>             not reproduce it.
>>>             Can you send the generated SwiftBlob_wrap.c file and the
>>>             output of make clean ; make V=1
>>>             On 06/12/2013 01:30 PM, Fan Zhang wrote:
>>>>             Hi Justin,
>>>>                 I go the same errors after updating SWIG to 2.0.9.
>>>>             SWIG Version 2.0.9
>>>>             Compiled with /usr/bin/clang++ [i386-apple-darwin12.2.0]
>>>>             Regards,
>>>>             Fan
>>>>             On Wed, Jun 12, 2013 at 2:07 PM, Justin M Wozniak
>>>>                 Hi
>>>>                    I think the issue may be that we have not tested
>>>>                 with SWIG prior to 2.0.4.  Can you update SWIG to
>>>>                 2.0.4 or newer and try again?  If this is the
>>>>                 issue, I will update the installation guides and
>>>>                 checks.
>>>>                     Thanks
>>>>                     Justin
>>>>                 On 06/12/2013 10:45 AM, Fan Zhang wrote:
>>>>>                 Hi All,
>>>>>                 I'm trying to install Swift/T 0.3.0 on my macbook pro.
>>>>>                 When the setup script is building turbine, it gave
>>>>>                 the following errors:
>>>>>                   CCsrc/tcl/blob/SwiftBlob_wrap.o
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:126: error: expected
>>>>>                 ‘=’, ‘,’, ‘;’, ‘asm’ or ‘__attribute__’ before ‘*’
>>>>>                 token
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:127: error: expected
>>>>>                 ‘swig_module’
>>>>>                 In file included from
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:138:
>>>>>                 src/tcl/blob/blob.h:54: error: expected ‘)’ before
>>>>>                 ‘bytes’
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:144: error: expected
>>>>>                 ‘)’ before ‘clientData’
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:156: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:168: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:180: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:192: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:203: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c: In function
>>>>>                 ‘swig_delete_turbine_blob’:
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:215: warning:
>>>>>                 implicit declaration of function ‘free’
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c: At top level:
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:217: error: expected
>>>>>                 ‘swig_turbine_blob_methods’
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:220: error: expected
>>>>>                 ‘swig_turbine_blob_attributes’
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:225: error: expected
>>>>>                 token
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:227: error: expected
>>>>>                 ‘_wrap_class_turbine_blob’
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:229: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:242: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:255: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:267: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:278: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:289: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:301: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:313: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:325: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:337: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:349: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:361: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:373: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:386: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:399: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:412: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:423: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:436: error: expected
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:449: error: expected
>>>>>                 ‘swig_commands’
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:478: error: expected
>>>>>                 ‘swig_variables’
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:482: error: expected
>>>>>                 ‘swig_constants’
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:488: error: expected
>>>>>                 ‘_swigt__p_turbine_blob’
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:490: error: expected
>>>>>                 token
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:494: error: expected
>>>>>                 ‘_swigc__p_turbine_blob’
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:496: error: expected
>>>>>                 token
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:506: error: expected
>>>>>                 identifier or ‘(’ before ‘return’
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:507: error: expected
>>>>>                 identifier or ‘(’ before ‘}’ token
>>>>>                 src/tcl/blob/SwiftBlob_wrap.c:508: error: expected
>>>>>                 ‘)’ before ‘*’ token
>>>>>                 make: *** [src/tcl/blob/SwiftBlob_wrap.o] Error 1
>>>>>                 exm-setup.zsh: turbine: make FAILED
>>>>>                 Below is the configure command for turbine:
>>>>>                 ./configure --config-cache
>>>>>                 --prefix=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/turbine
>>>>>                 --with-tcl=/usr/ --with-mpi=/opt/local
>>>>>                 --with-c-utils=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/c-utils--with-adlb=/Users/zhangfan/Documents/open-source-software/Active/exm-0.3.0/exm-install/lb
>>>>>                 I have mpich-3.0.4, Swig 1.3.40, Tcl 8.5
>>>>>                 installed. What could be the problems? Thanks a lot.
>>>>>                 Regards,
>>>>>                 Fan
>>>>>                 The Applied Software Systems Laboratory (TASSL)
>>>>>                 Department of Electrical and Computer Engineering
>>>>>                 Rutgers, The State University of New Jersey
>>>>>                 Email: zhangfan at cac.rutgers.edu
>>>>>                 <mailto:zhangfan at cac.rutgers.edu>
>>>>>                 Personal web:
>>>>>                 http://sites.google.com/site/zhangfan198538
>>>>>                 Lab web: http://nsfcac.rutgers.edu/TASSL/
>>>>>                 _______________________________________________
>>>>>                 ExM-user mailing list
>>>>>                 ExM-user at lists.mcs.anl.gov  <mailto:ExM-user at lists.mcs.anl.gov>
>>>>>                 https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>>>>                 Justin M Wozniak
>>>>             Personal web: http://sites.google.com/site/zhangfan198538
>>>             Justin M Wozniak
>>         Justin M Wozniak
>>     Email: zhangfan at cac.rutgers.edu <mailto:zhangfan at cac.rutgers.edu>
>     Justin M Wozniak
Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130613/f95801dd/attachment-0001.html>
More information about the ExM-user mailing list
