[ExM Users] multiple returns allowed in Swift/T
Ketan Maheshwari
ketancmaheshwari at gmail.com
Wed Aug 7 20:45:18 CDT 2013
Yep, thanks. I added _outB4 to arg list which fixed it.
On Wed, Aug 7, 2013 at 8:36 PM, Tim Armstrong <tim.g.armstrong at gmail.com>wrote:
> I think the problem is _outB4, which is an undeclared variable. This
> shouldn't result in a null pointer exception: I'll create a ticket to fix
> it and produce a more helpful error.
> Tim
> On Wed, Aug 7, 2013 at 8:31 PM, Ketan Maheshwari <
> ketancmaheshwari at gmail.com> wrote:
>> Hi Tim,
>> I made the change as you suggested but now I am getting java NPE:
>> $ stc mimo.swift > mimo.tcl
>> STC INTERNAL ERROR
>> Please report this
>> java.lang.NullPointerException
>> at exm.stc.frontend.ASTWalker.evalAppCmdArgs(ASTWalker.java:2431)
>> at exm.stc.frontend.ASTWalker.genAppFunctionBody(ASTWalker.java:2188)
>> at exm.stc.frontend.ASTWalker.compileAppFunction(ASTWalker.java:2155)
>> at exm.stc.frontend.ASTWalker.walkTopLevelCompile(ASTWalker.java:327)
>> at exm.stc.frontend.ASTWalker.walkTopLevel(ASTWalker.java:237)
>> at exm.stc.frontend.ASTWalker.walkFile(ASTWalker.java:199)
>> at exm.stc.frontend.ASTWalker.loadModule(ASTWalker.java:385)
>> at exm.stc.frontend.ASTWalker.walk(ASTWalker.java:168)
>> at exm.stc.ui.STCompiler.compile(STCompiler.java:76)
>> at exm.stc.ui.Main.main(Main.java:93)
>> The script is as below:
>> import files;
>> import io;
>> import string;
>> import sys;
>> app (file _outB1, file _outB2, file _outB3) A (file _inA1, file _inA2,
>> file _inA3){
>> "mimo.sh" @_inA1 @_inA2 @_inA3 @_outB1 @_outB2 @_outB3 @_outB4;
>> main{
>> file in_a1=input_file("sample.txt");
>> file in_a2=input_file("sample.txt");
>> file in_a3=input_file("sample.txt");
>> file in_a4=input_file("sample.txt");
>> foreach i in [0:1]{
>> string outb1=sprintf("/tmp/swift.work/outb1-%i.dat", i);
>> string outb2=sprintf("/tmp/swift.work/outb2-%i.dat", i);
>> string outb3=sprintf("/tmp/swift.work/outb3-%i.dat", i);
>> string outb4=sprintf("/tmp/swift.work/outb4-%i.dat", i);
>> file o1 <outb1>;
>> file o2 <outb2>;
>> file o3 <outb3>;
>> file o4 <outb4>;
>> (o1, o2, o3, o4) = A (in_a1, in_a2, in_a3, in_a4);
>> Thanks,
>> Ketan
>> On Wed, Aug 7, 2013 at 8:06 PM, Tim Armstrong <tim.g.armstrong at gmail.com>wrote:
>>> You can't declare variables inside a multiple return, you'll have to
>>> declare them first, then assign them in a separate statement.
>>> - Tim
>>> On Wed, Aug 7, 2013 at 8:03 PM, Ketan Maheshwari <
>>>> Hi,
>>>> I am writing some benchmark scripts. One of them is SIMO for single
>>>> input multiple output for which an app looks as follows:
>>>> app (file _outB1, file _outB2, file _outB3, file _outB4) A (file _inA1){
>>>> "simo.sh" @_inA1 @_outB1 @_outB2 @_outB3 @_outB4;
>>>> Wondering if this is the right way to define multiple outputs to an app?
>>>> I am getting error message when I call the app in main{} as follows:
>>>> (file outb1 <outb1>, file outb2 <outb2>, file outb3 <outb3>, file outb4
>>>> <outb4>) = A (in_a);
>>>> The error is:
>>>> simo.swift l.22:9 mismatched input 'outb1' expecting RPAREN
>>>> simo.swift l.22:49 no viable alternative at input 'outb3'
>>>> simo.swift l.22:82 no viable alternative at input ')'
>>>> simo.swift l.22:86 mismatched input 'A' expecting GT
>>>> simo.swift l.24:0 mismatched input '}' expecting EOF
>>>> Error occurred during parsing.
>>>> Thanks for suggestions to fix this.
>>>> Ketan
>>>> _______________________________________________
>>>> ExM-user mailing list
>>>> ExM-user at lists.mcs.anl.gov
>>>> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
>> Ketan
Ketan
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130807/87c651be/attachment.html>
More information about the ExM-user
