[ExM Users] Submitting tasks on Raven
Michael Wilde wilde at mcs.anl.gov
Thu Apr 25 16:13:23 CDT 2013
What was causing the error message "apsched: claim exceeds reservation's memory" ?
----- Original Message -----
> From: "Justin M Wozniak" <wozniak at mcs.anl.gov>
> To: exm-user at lists.mcs.anl.gov
> Sent: Thursday, April 25, 2013 1:19:19 PM
> Subject: Re: [ExM Users] Submitting tasks on Raven
> This definitely works now- we were able to launch tasks on 6 GPUs on
> Raven.
> On 04/25/2013 09:40 AM, Michael Wilde wrote:
> > Can someone help Scott with this?
> > Scott, I think #PBS -m is the email notification flag, not memory.
> > Its complaining that your aprun command is asking for more
> > resources
> > than the qsub command requested for the job.
> > Check that the aprun -n -N -d do not exceed mppwidth etc from pns
> > Test your aprun args with a qsub -I asking for the correct numnber
> > of
> > nodes and cores
> > On 4/24/13, Scott Krieder <skrieder at iit.edu> wrote:
> >> Hi All,
> >> I'm trying to run noop.tcl with turbine on Raven. I keep getting a
> >> memory
> >> error:
> >> I tried a few different values(100, 100M) for
> >> #PBS -m
> >> but I keep getting the error.
> >> Is there a way to let the PBS job take as much memory as it needs?
> >> Thanks,
> >> Scott
> >> =====aprun.sh script that I'm running=====
> >> # USAGE: qsub aprun.sh
> >> # The user should copy and edit the parameters throughout this
> >> script
> >> # marked USER:
> >> # USER: Directory available from compute nodes:
> >> USER_WORK=/ufs/home/users/p01684
> >> # USER: (optional) Change the qstat name
> >> #PBS -N turbine
> >> # USER: Set the job size
> >> #PBS -l mppwidth=1,mppnppn=3,mppdepth=1
> >> # USER: Set the wall time
> >> #PBS -l walltime=10:00
> >> # USER: (optional) Redirect output from its default location
> >> ($PWD)
> >> #PBS -o /ufs/home/users/p01684/pbs.out
> >> #PBS -j oe
> >> #PBS -m n
> >> # USER: Set configuration of Turbine processes
> >> export TURBINE_ENGINES=1
> >> export ADLB_SERVERS=1
> >> echo "Turbine: aprun.sh"
> >> date "+%m/%d/%Y %I:%M%p"
> >> echo
> >> # Be sure we are in an accessible directory
> >> cd $PBS_O_WORKDIR
> >> set -x
> >> # USER: Set Turbine installation path
> >> export TURBINE_HOME=${USER_WORK}/Public/sfw/turbine
> >> # USER: Select program name
> >> # PROGRAM=${USER_WORK}/adlb-data.tcl
> >> PROGRAM=${TURBINE_HOME}/test/noop.tcl
> >> source ${TURBINE_HOME}/scripts/turbine-config.sh
> >> if [[ ${?} != 0 ]]
> >> then
> >>    echo "turbine: configuration error!"
> >>    exit 1
> >> fi
> >> # Send environment variables to PBS job:
> >> #PBS -v TURBINE_ENGINES ADLB_SERVERS TURBINE_HOME
> >> # USER: Set aprun parameters to agree with PBS -l settings
> >> # aprun -n 1 -N 1 -cc none -d 1 ${TCLSH} ${PROGRAM}
> >> aprun -n 3 -N 3 -cc none -d 1 ${TURBINE_HOME}/bin/turbine
> >> ${PROGRAM}
> >> Scott J. Krieder
> >> C: 419-685-0410
> >> E: skrieder at iit.edu
> >> http://datasys.cs.iit.edu/~skrieder/
> Justin M Wozniak
> ExM-user mailing list
> ExM-user at lists.mcs.anl.gov
> https://lists.mcs.anl.gov/mailman/listinfo/exm-user
More information about the ExM-user mailing list
