[ExM Users] warnings on c-utils install
Tim Armstrong tga at uchicago.edu
Thu Apr 25 10:42:38 CDT 2013
You can ignore these for now, unless you run into further issues.  It
may be a good idea to also update and recompile adlb and turbine.
I enabled an additional compiler warning for implicit conversions, and
fixed all the warnings that cropped up on my machines, but it appears
you are getting some additional ones. What version of gcc are you using?
- Tim
On 4/25/2013 10:18 AM, Scott Krieder wrote:
> Hi Tim,
> I noticed that when installing c-utils from the latest svn version it
> gives several warnings.
> I did do a make clean, and my uname -a gives:
> Linux skrieder 2.6.32-43-generic #97-Ubuntu SMP Wed Sep 5 16:42:26 UTC
> 2012 x86_64 GNU/Linux
> Here is what make produces:
> make
>   DEPsrc/list_d.d
>   DEPsrc/log.d
>   DEPsrc/list_ip.d
>   DEPsrc/reader.d
>   DEPsrc/list_i.d
>   DEPsrc/list2.d
>   DEPsrc/list_l.d
>   DEPsrc/table_ip.d
>   DEPsrc/tree.d
>   DEPsrc/version.d
>   DEPsrc/lookup3.d
>   DEPsrc/table.d
>   DEPsrc/exm-string.d
>   DEPsrc/tools.d
>   DEPsrc/list_sp.d
>   DEPsrc/c-utils.d
>   DEPsrc/memory.d
>   DEPsrc/list.d
>   DEPsrc/list_lp.d
>   DEPsrc/rbtree.d
>   DEPsrc/table_lp.d
>   DEPsrc/profile.d
>   CCsrc/profile.o
> src/profile.c: In function ‘profile_entry’:
> src/profile.c:64: warning: passing argument 3 of ‘__builtin_strncpy’
> with different width due to prototype
>   CCsrc/table_lp.o
> src/table_lp.c: In function ‘table_lp_dump’:
> src/table_lp.c:169: warning: passing argument 2 of ‘list_lp_tostring’
>   CCsrc/rbtree.o
>   CCsrc/list_lp.o
>   CCsrc/list.o
>   CCsrc/memory.o
> src/memory.c: In function ‘mm_create’:
> src/memory.c:86: warning: passing argument 2 of ‘strnlen’ with
>   CCsrc/c-utils.o
>   CCsrc/list_sp.o
>   CCsrc/tools.o
>   CCsrc/exm-string.o
>   CCsrc/table.o
> src/table.c: In function ‘table_dump’:
> src/table.c:211: warning: passing argument 2 of ‘list_sp_tostring’
>   CCsrc/lookup3.o
>   CCsrc/version.o
>   CCsrc/tree.o
>   CCsrc/table_ip.o
> src/table_ip.c: In function ‘table_ip_dump’:
> src/table_ip.c:136: warning: passing argument 2 of ‘list_ip_snprintf’
>   CCsrc/list_l.o
>   CCsrc/list2.o
>   CCsrc/list_i.o
>   CCsrc/reader.o
> src/reader.c: In function ‘reader_read’:
> src/reader.c:88: warning: passing argument 2 of ‘fread’ with different
> src/reader.c:99: warning: passing argument 2 of ‘table_lp_add’ with
>   CCsrc/list_ip.o
> src/list_ip.c: In function ‘list_ip_snprintf’:
> src/list_ip.c:597: warning: passing argument 2 of ‘snprintf’ with
>   CCsrc/log.o
> src/log.c: In function ‘log_printf’:
> src/log.c:95: warning: passing argument 2 of ‘vsnprintf’ with
>   CCsrc/list_d.o
>   LINKlib/libexmcutils.so
> Scott J. Krieder
> C: 419-685-0410
> E: skrieder at iit.edu <mailto:skrieder at iit.edu>
> http://datasys.cs.iit.edu/~skrieder/
> <http://datasys.cs.iit.edu/%7Eskrieder/>
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130425/37b27a16/attachment-0001.html>
More information about the ExM-user mailing list
