[ExM Users] Installing Swift/T on Raven
Scott Krieder
skrieder at iit.edu
Fri Apr 12 11:05:59 CDT 2013
Hi All,
I'm trying to install Swift/T on Raven. I followed the notes about Cray
systems.
When I configure turbine with:
./configure --prefix=/home/users/p01684/Public/sfw/turbine --enable-custom
--with-mpi-dir=/opt/cray/mpt/default/xt/gemini/mpich2-gnu/46
I get a long error about "could not find directory" in reference to mpicc.
Is there something I should do in addition to the --with-mpi flag?
Scott
==Error Message==
checking for /ufs/home/users/p01684/Public/sfw/c-utils/include/c-utils.h...
yes
which: no mpicc in
(/opt/pbs/10.4.0.101257/bin:/opt/cray/atp/1.6.2/bin:/opt/cray/rca/1.0.0-2.0401.38656.2.2.gem/bin:/opt/cray/pmi/4.0.1-1.0000.9421.73.3.gem/bin:/opt/toolworks/totalview.8.11.0-1/bin:/opt/totalview-support/1.1.4/bin:/opt/cray/cce/8.1.4/cray-binutils/x86_64-unknown-linux-gnu/bin:/opt/cray/cce/8.1.4/craylibs/x86-64/bin:/opt/cray/cce/8.1.4/cftn/bin:/opt/cray/cce/8.1.4/CC/bin:/opt/cray/xt-asyncpe/5.20.11/bin:/opt/cray/llm/default/bin:/opt/cray/llm/default/etc:/opt/cray/xpmem/0.1-2.0401.36790.4.3.gem/bin:/opt/cray/dmapp/3.2.1-1.0401.5983.4.5.gem/bin:/opt/cray/ugni/4.0-1.0401.5928.9.5.gem/bin:/opt/cray/udreg/2.3.2-1.0401.5929.3.3.gem/bin:/opt/cray/lustre-cray_gem_s/1.8.6_2.6.32.59_0.7.1_1.0401.6845.9.1-1.0401.38658.11.3/sbin:/opt/cray/lustre-cray_gem_s/1.8.6_2.6.32.59_0.7.1_1.0401.6845.9.1-1.0401.38658.11.3/bin:/opt/cray/MySQL/5.0.64-1.0000.5053.22.1/sbin:/opt/cray/MySQL/5.0.64-1.0000.5053.22.1/bin:/opt/cray/sdb/1.0-1.0401.38148.4.27.gem/bin:/opt/cray/nodestat/2.2-1.0401.37252.2.1.gem/bin:/opt/modules/
3.2.6.7/bin:/usr/local/bin:/usr/bin:/bin:/usr/bin/X11:/usr/X11R6/bin:/usr/games:/usr/lib64/jvm/jre/bin:/usr/lib/mit/bin:/usr/lib/mit/sbin:.:/usr/lib/qt3/bin:/opt/cray/bin
./configure: line 4032: ((: ! : syntax error: operand expected (error
token is " ")
checking for 0... no
configure: error: Could not find directory
Scott J. Krieder
C: 419-685-0410
E: skrieder at iit.edu
http://datasys.cs.iit.edu/~skrieder/
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20130412/57b3f233/attachment.html>
More information about the ExM-user
