[ExM Users] foreach bounds resulting in seg fault
Scott Krieder skrieder at iit.edu
Wed Oct 24 14:45:05 CDT 2012
Hi Justin,
I installed from the exm-0.1.0 tarball.
$ stc -v
STC: Swift-Turbine Compiler
 for Turbine: 0.0.6
TURBINE_INSTALL=/usr/local/exm-install/turbine
TURBINE_HOME=
$ turbine -v
Turbine 0.0.6
 in: /usr/local/exm-install/turbine
Is there anything I need to update?
Thank you,
Scott
On Wed, Oct 24, 2012 at 2:41 PM, Justin M Wozniak <wozniak at mcs.anl.gov>wrote:
>  Hi Scott,
>     This script works for me up to at least 10,000 iterations.  Which
> version are you running?
>     Justin
> On 10/24/2012 01:20 PM, Scott Krieder wrote:
> Hi All,
>  I am encountering an error when the bound on my foreach loop exceeds
> 1,021.
>  #include <builtins.swift>
> #include <io.swift>
> #include <sys.swift>
> main{
>       int bound = toint(argv("bound"));
>      float sleepTime = tofloat(argv("sleeptime"));
>       // print for debug
>      printf("The number of arguments is: %i\n", argc());
>      printf("The bound is: %i\n", bound);
>      printf("The sleeptime is: %f\n", sleepTime);
>       // run the sleep
>      foreach i in [1:bound:1]{
>                 sleep(sleepTime);
>  Running with the bound set to 1022 and above results in the following
> error:
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   EXIT CODE: 11
> =   CLEANING UP REMAINING PROCESSES
> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
> YOUR APPLICATION TERMINATED WITH THE EXIT STRING: Segmentation fault
> (signal 11)
> This typically refers to a problem with your application.
> Please see the FAQ page for debugging suggestions
>  Could someone point me to the FAQ page with debugging suggestions? Are
> there any limits to the sizes of the foreach loops?
>  Thank you,
> Scott
> Exm-user mailing listExm-user at lists.mcs.anl.govhttps://lists.mcs.anl.gov/mailman/listinfo/exm-user
> Justin M Wozniak
URL: <http://lists.mcs.anl.gov/pipermail/exm-user/attachments/20121024/3f5d9f0e/attachment.html>
More information about the Exm-user mailing list
