[Darshan-users] darshan_library_warning
Snyder, Shane
ssnyder at mcs.anl.gov
Mon Nov 18 08:50:13 CST 2024
Hi Zoya,
Did you run the darshan-mk-log-dirs.pl script that installs with darshan-runtime? That has to be run first to format the output log directory —when using --log-path option to Darshan, it will output files in year/month/day subdirectories in the file path you give it.
--Shane
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf of Zoya Masih <zoyamasih92 at gmail.com>
Sent: Monday, November 18, 2024 2:51 AM
To: darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
Subject: [Darshan-users] darshan_library_warning
Hello, I have installed Darshan version 3. 4. 6 on an HPC cluster with the following configuration: ./configure --enable-mmap-logs --with-log-path=/mnt/lustre-grete/usr/u11509/DARSHAN/darshan-logs --with-jobid-env=PBS_JOBID --prefix=/path/to/DARSHAN/
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
Hello,
I have installed Darshan version 3.4.6 on an HPC cluster with the following configuration:
./configure --enable-mmap-logs --with-log-path=/mnt/lustre-grete/usr/u11509/DARSHAN/darshan-logs --with-jobid-env=PBS_JOBID --prefix=/path/to/DARSHAN/ CC=mpicc
The installation of darshan-runtime and darshan-util is correctly done.
Then I followed the instructions:
1- export LD_PRELOAD=/path/to/lib/libdarshan.so
2- export DARSHAN_ENABLE_NONMPI=1
3- python Hello_world.py
I get this error: darshan_library_warning: unable to create log file /path/to/darshan-logs/2024/11/18/u11509_python_id1736997-1736997_11-18-34797-17835898535848440029.darshan_partial.
The code is siply a hello world code, and python package doesn't have any problem. The permissions are also met.
Would you please help me understand the issue?
Sincerely
Zoya Masih
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20241118/38303a3e/attachment-0001.html>
More information about the Darshan-users
