[Darshan-users] HDF5 version support
Snyder, Shane
ssnyder at mcs.anl.gov
Thu Apr 28 16:20:36 CDT 2022
Hi Jiri,
HDF5 should be generally supported for any version greater than 1.8.
The Darshan error you're seeing indicates that Darshan believes it was configured with a version less than 1.10 (which it then complains about since it sees version 1.12 at runtime). You should see a line like this in the configure output for darshan-runtime:
HDF5 module support - no
In my case above, HDF5 support wasn't enabled, but if HDF5 is enabled it will indicate what version it found at configure time. We should make sure that says 1.12 as a starting point. Darshan is indirectly determining the version by running 'h5dump --version', so might be good to sanity check that 'h5dump' in PATH is associated with the 1.12 HDF5 install you are trying to use.
I should note that in my experience, getting h5py working right with Darshan was a challenge. I tried once and had some issues, but one of our Python contributors indicated they have gotten it to work in the past -- in their case, they recommended building h5py from source according to these directions: https://docs.h5py.org/en/stable/build.html#custom-installation
Maybe you are already doing that? The trick is to use an external HDF5 install (i.e., not one packaged with h5py python wheels) that you then use to build both h5py and Darshan. I could try to get further myself if we can't figure out how to get it working for you.
--Shane
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov> on behalf of Jiří Nádvorník <nadvornik.ji at gmail.com>
Sent: Wednesday, April 27, 2022 12:29 PM
To: darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
Subject: [Darshan-users] HDF5 version support
Hi all,
I was able to successfully run the darshan runtime without any warnings withou HDF5.
Now when I compile with HDF5 (the results above are without it):
./configure --with-log-path=/gpfs/raid/darshan-logs --with-jobid-env=PBS_JOBID CC=mpicc --enable-hdf5-mod --with-hdf5=/gpfs/raid/SDSSCube/ext_lib//hdf5-1.12.0/hdf5/
It messes up my runtime and causes python to crash:
mpirun -x DARSHAN_CONFIG_PATH=/gpfs/raid/SDSSCube/darshan.conf -x LD_PRELOAD=/gpfs/raid/shared_libs/darshan/darshan-runtime/lib/.libs/libdarshan.so:/gpfs/raid/SDSSCube/ext_lib/hdf5-1.12.0/hdf5/lib/libhdf5.so -np 65 --hostfile hosts --map-by node /gpfs/raid/SDSSCube/venv_par/bin/python hisscube.py --truncate ../sdss_data/ results/SDSS_cube_c_par.h5
Resulting in:
INFO:rank[0]:Rank 0 pid: 137058
Darshan HDF5 module error: runtime library version (1.12) incompatible with Darshan module (1.10-).
Traceback (most recent call last):
File "hisscube.py", line 74, in <module>
writer.ingest(fits_image_path, fits_spectra_path, truncate_file=args.truncate)
File "/gpfs/raid/SDSSCube/hisscube/ParallelWriterMWMR.py", line 45, in ingest
self.process_metadata(image_path, image_pattern, spectra_path, spectra_pattern, truncate_file)
File "/gpfs/raid/SDSSCube/hisscube/CWriter.py", line 150, in process_metadata
h5_file = self.open_h5_file_serial(truncate_file)
File "/gpfs/raid/SDSSCube/hisscube/CWriter.py", line 170, in open_h5_file_serial
return h5py.File(self.h5_path, 'w', fs_strategy="page", fs_page_size=4096, libver="latest")
File "/gpfs/raid/SDSSCube/venv_par/lib/python3.8/site-packages/h5py-3.6.0-py3.8-linux-x86_64.egg/h5py/_hl/files.py", line 533, in __init__
fid = make_fid(name, mode, userblock_size, fapl, fcpl, swmr=swmr)
File "/gpfs/raid/SDSSCube/venv_par/lib/python3.8/site-packages/h5py-3.6.0-py3.8-linux-x86_64.egg/h5py/_hl/files.py", line 232, in make_fid
fid = h5f.create(name, h5f.ACC_TRUNC, fapl=fapl, fcpl=fcpl)
File "h5py/_objects.pyx", line 54, in h5py._objects.with_phil.wrapper
File "h5py/_objects.pyx", line 55, in h5py._objects.with_phil.wrapper
File "h5py/h5f.pyx", line 126, in h5py.h5f.create
File "h5py/defs.pyx", line 693, in h5py.defs.H5Fcreate
RuntimeError: Unspecified error in H5Fcreate (return value <0)
You are saying that darshan should be compatible with HDF5 > 1.8, which 1.12 should be, right? I checked the source and there is hardcoded if minor version > 10: not supported.
Thanks for explaining what's supported.
Cheers,
Jiri Nadvornik
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20220428/4e201a89/attachment.html>
More information about the Darshan-users
