[Darshan-users] Module contains incomplete data
    Snyder, Shane
    ssnyder at mcs.anl.gov
    Wed Apr 27 11:23:38 CDT 2022
Great, I'm glad that you were able to get the instrumentation mostly working!
I think it's sensible to ignore Python source/compiled code for most cases -- I doubt there's any insight to gain and you'll just end up trying to filter them out when analyzing logs anyways.
I'm not sure what's going on with the installation issues you mention. If you think something might be wrong with Darshan's build, then would you mind sharing how you ran configure, etc.? I could see if I'm able to reproduce anything.
If you wouldn't mind starting a new thread related to the HDF5 issue, I think that would be helpful -- it might help if other users ever want to search the list archive for h5py/HDF5 related issues if you include those in the title.
--Shane
Sent: Wednesday, April 27, 2022 11:06 AM
To: Snyder, Shane <ssnyder at mcs.anl.gov>
Cc: darshan-users at lists.mcs.anl.gov <darshan-users at lists.mcs.anl.gov>
Subject: Re: [Darshan-users] Module contains incomplete data
yes, that NAMEMEM got it done. I also excluded .py and .pyc files - those reads are only loading of them, right? No data access itself (and no, I'm not reading and manually interpreting my own python files :), so I'm not interested into that ). Actually, I'm reading thousands of small files which I'm ingesting into HDF5 and I'm interested into how many reads, etc. are happening.
I'm trying to make some sense of what I see but for now I'm just going to say it's very valuable data for me. Pity I can't get the Hdf5 module, if it would give me more granularity it would be very helpful.
Regarding the darshan-utils you were right, I didn't reinstall them. I actually ran into an install problem - for some reason, the git installation takes the .lib/darshan-parser when installing it to /usr/local/... and that one throws:
darshan-parser: error while loading shared libraries: libdarshan-util.so.0: cannot open shared object file: No such file or directory
But if I run the darshan-parser within darshan_root_folder/darshan-util/ then the error is gone and --show-incomplete |grep incomplete prints nothing.
Could we now focus on the HDF5 issue or should I create a new thread for clarity?
Cheers,
Jiri
st 27. 4. 2022 v 17:21 odesílatel Snyder, Shane <ssnyder at mcs.anl.gov<mailto:ssnyder at mcs.anl.gov>> napsal:
Thanks for working through the build issues and giving this a shot.
A couple of things stand out to me (ignoring your HDF5 issue for now):
  *   It looks like at least the MPI-IO module is no longer reporting partial data? Small progress...
  *   There is a new warning about there being no log utility handlers for a "null" module. Are you perhaps parsing a log generated by your prior Darshan install? Maybe you have not completely re-installed a new darshan-util? We should figure out what's going on there, too, to be safe.
I'd also suggest two things for your config file:
  *   Dial back MODMEM and MAX_RECORDS values. Your MODMEM value is asking Darshan to allocate a GiB of memory (it is expressed in MiB units and you set to 1024), which Darshan will happily try to do, I'm not sure it's a good idea though. I'd probably start with a MODMEM value of 8 and MAX_RECORDS of 2000, and just double those again if needed -- anything beyond that would be surprising unless you know your workload is really opening hundreds of thousands of files. You might also have a look at the files Darshan is currently instrumenting and see if you really want it to -- I've noticed when instrumenting Python frameworks that you can get tons of records for things like shared libraries, source files, etc. that can just be ignored using NAME_EXCLUDE mechanisms.
  *   Add "NAMEMEM  2" to your config file to force Darshan to allocate more memory (2 MiB) for storing the filenames associated with each record. This might actually be the main reason your log is reporting partial data rather than actually running out of module data, which is another reason not to get too aggressive with the MODMEM/MAX_RECORDS parameters. I should have mentioned this setting originally as there have been other users who have reported exceeding it recently.
Hopefully that gets you further along and we can move onto the HDF5 issue you mention.
--Shane
From: Jiří Nádvorník <nadvornik.ji at gmail.com<mailto:nadvornik.ji at gmail.com>>
Sent: Wednesday, April 27, 2022 6:37 AM
To: Snyder, Shane <ssnyder at mcs.anl.gov<mailto:ssnyder at mcs.anl.gov>>
Cc: darshan-users at lists.mcs.anl.gov<mailto:darshan-users at lists.mcs.anl.gov> <darshan-users at lists.mcs.anl.gov<mailto:darshan-users at lists.mcs.anl.gov>>
Aha! I just realized there is an obvious "prepare.sh" script that I didn't run, I found out by trial and error though, could be more documented :).
Now I'm further.. With a config file:
MAX_RECORDS     102400     POSIX,MPI-IO,STDIO
MODMEM  1024
APP_EXCLUDE     git,ls
I'm getting for:
darshan-parser --show-incomplete  caucau_python_id127447-127447_4-27-48556-1842455298968263838_1.darshan |grep incomplete
output:
# *WARNING*: The POSIX module contains incomplete data!
# *WARNING*: The STDIO module contains incomplete data!
Warning: no log utility handlers defined for module (null), SKIPPING.
I don't think I have more than 100000 files to be touched by my poor tiny python script, right?
By the way I've encountered another problem, not sure whether to put it to another thread. If I compile with HDF5 (the results above are without it):
./configure --with-log-path=/gpfs/raid/darshan-logs --with-jobid-env=PBS_JOBID CC=mpicc --enable-hdf5-mod --with-hdf5=/gpfs/raid/SDSSCube/ext_lib//hdf5-1.12.0/hdf5/
It messes up my runtime and causes python to crash:
mpirun -x DARSHAN_CONFIG_PATH=/gpfs/raid/SDSSCube/darshan.conf -x LD_PRELOAD=/gpfs/raid/shared_libs/darshan/darshan-runtime/lib/.libs/libdarshan.so:/gpfs/raid/SDSSCube/ext_lib/hdf5-1.12.0/hdf5/lib/libhdf5.so -np 65 --hostfile hosts --map-by node /gpfs/raid/SDSSCube/venv_par/bin/python hisscube.py --truncate ../sdss_data/ results/SDSS_cube_c_par.h5
Resulting in:
INFO:rank[0]:Rank 0 pid: 137058
Darshan HDF5 module error: runtime library version (1.12) incompatible with Darshan module (1.10-).
Traceback (most recent call last):
  File "hisscube.py", line 74, in <module>
    writer.ingest(fits_image_path, fits_spectra_path, truncate_file=args.truncate)
  File "/gpfs/raid/SDSSCube/hisscube/ParallelWriterMWMR.py", line 45, in ingest
    self.process_metadata(image_path, image_pattern, spectra_path, spectra_pattern, truncate_file)
  File "/gpfs/raid/SDSSCube/hisscube/CWriter.py", line 150, in process_metadata
    h5_file = self.open_h5_file_serial(truncate_file)
  File "/gpfs/raid/SDSSCube/hisscube/CWriter.py", line 170, in open_h5_file_serial
    return h5py.File(self.h5_path, 'w', fs_strategy="page", fs_page_size=4096, libver="latest")
  File "/gpfs/raid/SDSSCube/venv_par/lib/python3.8/site-packages/h5py-3.6.0-py3.8-linux-x86_64.egg/h5py/_hl/files.py", line 533, in __init__
    fid = make_fid(name, mode, userblock_size, fapl, fcpl, swmr=swmr)
  File "/gpfs/raid/SDSSCube/venv_par/lib/python3.8/site-packages/h5py-3.6.0-py3.8-linux-x86_64.egg/h5py/_hl/files.py", line 232, in make_fid
    fid = h5f.create(name, h5f.ACC_TRUNC, fapl=fapl, fcpl=fcpl)
  File "h5py/_objects.pyx", line 54, in h5py._objects.with_phil.wrapper
  File "h5py/_objects.pyx", line 55, in h5py._objects.with_phil.wrapper
  File "h5py/h5f.pyx", line 126, in h5py.h5f.create
  File "h5py/defs.pyx", line 693, in h5py.defs.H5Fcreate
RuntimeError: Unspecified error in H5Fcreate (return value <0)
You are saying that darshan should be compatible with HDF5 > 1.8, which 1.12 should be, right?
Thanks for help!
Cheers,
Jiri
st 27. 4. 2022 v 8:43 odesílatel Jiří Nádvorník <nadvornik.ji at gmail.com<mailto:nadvornik.ji at gmail.com>> napsal:
I think I will chew through the documentation just fine but two things are not clear:
  1.  Does the darshan library provide its own config file that I need to change or do I need to always create my own?
  2.  How can I build the git version? I didn't find any instructions and the usual autoconf just throws:
     *   root at kub-b1:/gpfs/raid/shared_libs/darshan/darshan-runtime# autoconf
configure.ac:19<http://configure.ac:19>: error: possibly undefined macro: AC_CONFIG_MACRO_DIRS
      If this token and others are legitimate, please use m4_pattern_allow.
      See the Autoconf documentation.
configure.ac:21<http://configure.ac:21>: error: possibly undefined macro: AM_INIT_AUTOMAKE
configure.ac:22<http://configure.ac:22>: error: possibly undefined macro: AM_SILENT_RULES
configure.ac:23<http://configure.ac:23>: error: possibly undefined macro: AM_MAINTAINER_MODE
configure.ac:713<http://configure.ac:713>: error: possibly undefined macro: AM_CONDITIONAL
root at kub-b1:/gpfs/raid/shared_libs/darshan/darshan-runtime# ./configure
configure: error: cannot find install-sh, install.sh, or shtool in ../maint/scripts "."/../maint/scripts
Thanks for help.
Cheers,
Jiri
út 26. 4. 2022 v 17:43 odesílatel Snyder, Shane <ssnyder at mcs.anl.gov<mailto:ssnyder at mcs.anl.gov>> napsal:
Hi Jiri,
For some background, Darshan enforces some internal memory limits to avoid ballooning memory usage at runtime. Specifically, all of our instrumentation modules should pre-allocate file records for up to 1,024 files opened by the app -- if your app opens more than 1,024 files per-process, Darshan stops instrumenting and issues those warning messages when parsing the log file.
We have users hit this issue pretty frequently now, and we actually just wrapped up development of some new mechanisms to help out with this. They were just merged into our main branch, and we will be formally releasing a pre-release version of this code in the next week or so. For the time being, you should be able to use the 'main' branch of our repo (https://github.com/darshan-hpc/darshan) to leverage this new functionality.
There are 2 new mechanisms that can help out, both of which require you to provide a configuration file to Darshan at runtime:
  *   MAX_RECORDS setting can be used to bump up the number of pre-allocated records for different modules. In your case, you might try to bump up the default number of records for the POSIX, MPI-IO, and STDIO modules  by setting something like this in your config file (this would allow you to instrument up to 4000 files per-process for each of these modules):
     *   MAX_RECORDS    4000    POSIX,MPI-IO,STDIO
  *   An alternative (or complementary) approach to bumping up the record limit is to limit instrumentation to particular files. You can use the NAME_EXCLUDE setting to avoid instrumenting specific directory paths, file extensions, etc by specifying regular expressions. E.g, the following settings would avoid instrumenting files with .so prefixes or files located in a directory we don't care about for all modules (* denotes all modules):
     *   NAME_EXCLUDE    .so$    *
     *   NAME_EXCLUDE    ^/path/to/avoid    *
I'm attaching the updated runtime documentation for Darshan for your reference. Section 8 provides a ton of details on how to provide a config file to Darshan that should help clear up any missing gaps in my description above.
Please let us know if you have any further questions or issues, though!
--Shane
From: Darshan-users <darshan-users-bounces at lists.mcs.anl.gov<mailto:darshan-users-bounces at lists.mcs.anl.gov>> on behalf of Jiří Nádvorník <nadvornik.ji at gmail.com<mailto:nadvornik.ji at gmail.com>>
Sent: Sunday, April 24, 2022 3:00 PM
To: darshan-users at lists.mcs.anl.gov<mailto:darshan-users at lists.mcs.anl.gov> <darshan-users at lists.mcs.anl.gov<mailto:darshan-users at lists.mcs.anl.gov>>
Subject: [Darshan-users] Module contains incomplete data
Hi All,
I just tried out Darshan and the potential output seems perfect for my HDF5 MPI application! Although I'm not able to get there :(.
I have a log that has a big stamp "This darshan log contains incomplete data".
When I run:
darshan-parser --show-incomplete  mylog.darshan |grep incomplete
Output is:
# *WARNING*: The MPI-IO module contains incomplete data!
Would you be able to point me to some setting that would improve the measurements? Can I actually rely on the profiling results if it says the data is incomplete in some of the categories?
Thank you very much for your help!
Cheers,
Jiri
URL: <http://lists.mcs.anl.gov/pipermail/darshan-users/attachments/20220427/e6c20484/attachment-0001.html>
More information about the Darshan-users
